0005594 | ParaView | (No Category) | public | 2007-08-28 15:00 | 2007-09-13 16:23 | ||||
Assigned To | Yumin Yuan | ||||||||
Summary | 0005594: Set view direction buttons not updating view | ||||||||
Description | Load up any object (something without perfect symmetry, i.e. not the sphere source). Click on any of the Set View Direction buttons in the camera toolbar (+X, -X, etc.). Nothing happens on the button click. If you then click in the View, the view is updated to the appropriate view direction. Apparently, the button is correctly changing the camera orientation, but not doing a still render so that you cannot see the result. | ||||||||
(0008893) Yumin Yuan (developer) 2007-09-07 15:56 |
Note: pqRenderView::resetCamera, which is called by SetViewDirection(), used to trigger a render(). This behavior is changed during some bug fixes (according to Utkarsh), and now resetCamera() will not call render() anymore. The fix is add render() call to SetViewDirection(). cvs commit ... /Qt/Core/pqRenderView.cxx,v <-- pqRenderView.cxx new revision: 1.22; previous revision: 1.21 |
2007-08-28 15:00 | Ken Moreland | New Issue | |
2007-08-29 16:12 | Berk Geveci | Assigned To | => Yumin Yuan |
2007-08-29 16:12 | Berk Geveci | Priority | normal => high |
2007-08-29 16:12 | Berk Geveci | Status | backlog => tabled |
2007-09-07 15:56 | Yumin Yuan | Status | tabled => @80@ |
2007-09-07 15:56 | Yumin Yuan | Resolution | open => fixed |
2007-09-07 15:56 | Yumin Yuan | Note Added: 0008893 | |
2007-09-13 16:23 | Alan Scott | Status | @80@ => closed |
