0005620 | ParaView | Bug | public | 2007-08-29 19:53 | 2016-07-13 15:49 | ||||
Target Version | WhenPossible | Fixed in Version | |||||||
Summary | 0005620: Allow user to disconnect client when saving geometry files | ||||||||
Description | I have a user that would like to be able to disconnect client/server when saving geometry files, and have the server continue saving those geometry files. This would be similar to saving a movie after a client/server disconnect. The use case here is when you have tens of million of cells to billions of cells, and the system is SLOW. | ||||||||
(0011299) Berk Geveci (administrator) 2008-04-14 17:25 |
I am delaying this to 3.4 unless there are objections. |
(0016303) Utkarsh Ayachit (administrator) 2009-05-05 16:29 |
Delaying to 3.8 unless there are objections. |
(0036411) Alan Scott (manager) 2016-07-13 15:49 |
With the ability to use remote blades (which can stay up forever, even in a restricted environment), this is no longer needed. Closing. |
2007-08-29 19:53 | Alan Scott | New Issue | |
2008-04-14 17:25 | Berk Geveci | Note Added: 0011299 | |
2008-04-14 17:25 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2008-04-14 17:25 | Berk Geveci | Status | backlog => tabled |
2008-04-14 17:25 | Berk Geveci | Category | => 3.6 |
2009-05-05 16:29 | Utkarsh Ayachit | Note Added: 0016303 | |
2009-05-05 16:29 | Utkarsh Ayachit | Category | 3.6 => 3.8 |
2009-05-13 13:39 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-11-05 14:29 | Utkarsh Ayachit | Category | => Bug |
2010-11-05 14:29 | Utkarsh Ayachit | Target Version | 3.8 => WhenPossible |
2016-07-13 15:49 | Alan Scott | Note Added: 0036411 | |
2016-07-13 15:49 | Alan Scott | Status | expired => closed |
2016-07-13 15:49 | Alan Scott | Resolution | open => fixed |
