0005666 | ParaView | (No Category) | public | 2007-09-07 15:57 | 2007-09-25 20:48 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0005666: 3D widgets should not render after EndInteractionEvent | ||||||||
Description | 3D widgets should not render after EndInteractionEvent. At EndInteractionEvent, paraview switches to still render mode and re-render. If widgets render after that, they cause a 2nd still render. | ||||||||
(0009277) Utkarsh Ayachit (administrator) 2007-09-24 16:29 |
Since there was major objection to change the order of events in the vtk widgets, fixed the "duplicate render on end interaction with 3d widgets" issue by SetInteractiveRenderEnabled not causing any render at all. This requires that render is explicitly called when the scalar bar is done interacting as well as the interactor style is done interacting. /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVGenericRenderWindowInteractor.h,v <-- vtkPVGenericRenderWindowInteractor.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVGenericRenderWindowInteractor.cxx,v <-- vtkPVGenericRenderWindowInteractor.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMScalarBarWidgetRepresentationProxy.cxx,v <-- vtkSMScalarBarWidgetRepresentationProxy.cxx new revision: 1.6; previous revision: 1.5 |
(0009295) Alan Scott (manager) 2007-09-25 20:48 |
Not sure how to test this, and since it looks internal to the code, I am marking it closed. |
2007-09-07 15:57 | Berk Geveci | New Issue | |
2007-09-07 15:58 | Berk Geveci | Status | backlog => tabled |
2007-09-07 15:58 | Berk Geveci | Assigned To | => Berk Geveci |
2007-09-18 15:26 | Berk Geveci | Assigned To | Berk Geveci => |
2007-09-18 15:26 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2007-09-24 16:29 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-24 16:29 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-24 16:29 | Utkarsh Ayachit | Note Added: 0009277 | |
2007-09-25 20:48 | Alan Scott | Status | @80@ => closed |
2007-09-25 20:48 | Alan Scott | Note Added: 0009295 | |
