0005667 | ParaView | (No Category) | public | 2007-09-07 16:30 | 2007-09-12 21:31 | ||||
Summary | 0005667: Edges not visible on surface parallel to view plane | ||||||||
Description | Start ParaView and create a Wavelet source. Change the representation to Surface With Edges. If the view is aligned with one of the axes (as with the +X, -X, +Y, etc. buttons), you will not be able to see the edge lines. Any slight rotation of the camera makes the lines visible again. | ||||||||
Additional Information | When fixing this bug, make sure that you do not unfix bug 0005583. | ||||||||
Relationships | ||||||
(0008897) Utkarsh Ayachit (administrator) 2007-09-07 17:16 |
Fixing factor and units for glPolygonOffset so that they can't add up to 0 in any case. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRenderViewProxy.cxx,v <-- vtkSMRenderViewProxy.cxx new revision: 1.49; previous revision: 1.48 |
2007-09-07 16:30 | Ken Moreland | New Issue | |
2007-09-07 16:30 | Ken Moreland | Relationship added | related to 0005583 |
2007-09-07 17:16 | Utkarsh Ayachit | Status | backlog => @80@ |
2007-09-07 17:16 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-07 17:16 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2007-09-07 17:16 | Utkarsh Ayachit | Note Added: 0008897 | |
2007-09-12 21:31 | Alan Scott | Status | @80@ => closed |
