0005672 | ParaView | (No Category) | public | 2007-09-10 13:10 | 2007-09-12 22:02 | ||||
Reporter | Amy Squillacote | ||||||||
Summary | 0005672: Undo Accept should be Undo Apply | ||||||||
Description | In the Edit menu, just after you've clicked the Apply button, the 1st entry in the Edit menu is "Undo Accept". This could be confusing to new ParaView users (i.e., folks who didn't use PV 2.*); it should say "Undo Apply" to be consistent with the naming of the Apply button. Similarly, "Redo Accept" should be "Redo Apply". | ||||||||
(0008910) Clinton Stimpson (developer) 2007-09-10 14:04 |
Fixed, and also moved some code around so that the undo set creation is done in the same code that handles the apply button. /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.216; previous revision: 1.215 /cvsroot/ParaView3/ParaView3/Qt/Components/pqObjectInspectorWidget.cxx,v <-- pqObjectInspectorWidget.cxx new revision: 1.53; previous revision: 1.52 /cvsroot/ParaView3/ParaView3/Qt/Core/pqUndoStack.cxx,v <-- pqUndoStack.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Core/pqUndoStack.h,v <-- pqUndoStack.h new revision: 1.5; previous revision: 1.4 |
2007-09-10 13:10 | Amy Squillacote | New Issue | |
2007-09-10 14:03 | Clinton Stimpson | Status | backlog => tabled |
2007-09-10 14:03 | Clinton Stimpson | Assigned To | => Clinton Stimpson |
2007-09-10 14:04 | Clinton Stimpson | Status | tabled => @80@ |
2007-09-10 14:04 | Clinton Stimpson | Resolution | open => fixed |
2007-09-10 14:04 | Clinton Stimpson | Note Added: 0008910 | |
2007-09-12 22:02 | Alan Scott | Status | @80@ => closed |
