0005677 | ParaView | (No Category) | public | 2007-09-11 16:30 | 2007-09-17 17:04 | ||||
Priority | urgent | Severity | minor | Reproducibility | always | ||||
Summary | 0005677: Surface With Edges representation has incorrect replace input behavior | ||||||||
Description | Some filters, such as contour, are supposed to replace their input if their source shows an opaque surface. This is behavior is specified by setting the replace_input of the Visibility hint tag to 2. That all works fine for surface representation, but not the new surface with edges representation. The surface with edges representation remains visible after the filter is first applied. Here is a simple replication: 1. Create a sphere source. 2. Create a clip filter and apply. Everything is working fine. 3. Delete the clip filter. 4. Change the representation of the sphere to Surface With Edges. 5. Create and apply another clip filter. This time it looks like nothing was done because the sphere was not properly hidden. | ||||||||
(0008930) Utkarsh Ayachit (administrator) 2007-09-11 17:07 |
Surface with edges is treated a solid representation as far as input visibility goes. /cvsroot/ParaView3/ParaView3/Qt/Core/pqPendingDisplayManager.cxx,v <-- pqPendingDisplayManager.cxx new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- filters.xml new revision: 1.261; previous revision: 1.260 |
2007-09-11 16:30 | Ken Moreland | New Issue | |
2007-09-11 16:47 | Utkarsh Ayachit | Status | backlog => tabled |
2007-09-11 16:47 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2007-09-11 17:07 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-11 17:07 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-11 17:07 | Utkarsh Ayachit | Note Added: 0008930 | |
2007-09-17 17:04 | Alan Scott | Status | @80@ => closed |
