0005678 | ParaView | (No Category) | public | 2007-09-11 16:42 | 2011-01-13 17:00 | ||||
Reporter | Berk Geveci | ||||||||
Assigned To | Amy Squillacote | ||||||||
Summary | 0005678: Cannot edit lookup table when scalar range = 0 | ||||||||
Description | To reproduce: * Create sphere * Apply calculator, eqn = 5 * Bring up the scalar bar * Bring up color map editor (Edit Color Map...) - no points on the editor - cannot create more points by clicking In this case, ParaView already added 2 points but the editor is not showing them. Also, if you click on the editor, the scalar bar values turn to nans. I am guessing there is a division by 0 somewhere. The color map editor should show all points even if they have the same scalar value. | ||||||||
(0009303) Amy Squillacote (reporter) 2007-09-26 15:15 |
This has been fixed on the CVS head. /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTransferFunctionEditorRepresentationSimple1D.cxx,v <-- vtkTransferFunctionEditorRepresentationSimple1D.cxx new revision: 1.19; previous revision: 1.18 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTransferFunctionEditorWidget.cxx,v <-- vtkTransferFunctionEditorWidget.cxx new revision: 1.17; previous revision: 1.16 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTransferFunctionEditorWidget.h,v <-- vtkTransferFunctionEditorWidget.h new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTransferFunctionEditorWidget1D.cxx,v <-- vtkTransferFunctionEditorWidget1D.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTransferFunctionEditorWidgetSimple1D.cxx,v <-- vtkTransferFunctionEditorWidgetSimple1D.cxx new revision: 1.34; previous revision: 1.33 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkColorTransferFunction.cxx,v <-- vtkColorTransferFunction.cxx new revision: 1.72; previous revision: 1.71 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkColorTransferFunction.h,v <-- vtkColorTransferFunction.h new revision: 1.54; previous revision: 1.53 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkPiecewiseFunction.h,v <-- vtkPiecewiseFunction.h new revision: 1.41; previous revision: 1.40 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkPiecewiseFunction.cxx,v <-- vtkPiecewiseFunction.cxx new revision: 1.49; previous revision: 1.48 Also Utkarsh committed Qt/Core/pqPipelineRepresentation.cxx for me (CVS rev. 1.14) I still need to copy this to the 3.2 branch. |
(0009309) Amy Squillacote (reporter) 2007-09-27 10:32 |
I copied my changes to the ParaView-3-2 branch, and Clint submitted the Qt-related change. |
(0009354) Alan Scott (manager) 2007-10-01 19:15 |
Tested locally, 3.2 and head. |
2007-09-11 16:42 | Berk Geveci | New Issue | |
2007-09-11 16:43 | Berk Geveci | Status | backlog => tabled |
2007-09-11 16:43 | Berk Geveci | Assigned To | => Amy Squillacote |
2007-09-26 15:15 | Amy Squillacote | Note Added: 0009303 | |
2007-09-27 10:32 | Amy Squillacote | Status | tabled => @80@ |
2007-09-27 10:32 | Amy Squillacote | Resolution | open => fixed |
2007-09-27 10:32 | Amy Squillacote | Note Added: 0009309 | |
2007-10-01 19:15 | Alan Scott | Status | @80@ => closed |
2007-10-01 19:15 | Alan Scott | Note Added: 0009354 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
