0005685 | ParaView | (No Category) | public | 2007-09-12 11:36 | 2009-05-13 13:47 | ||||
Reporter | Jon Goldman | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Platform | OS | Windows | OS Version | XP | |||||
Summary | 0005685: X axis for XY plot on CSV data with zero values, zeroes out at 5.55e-17 instead of zero (window/viewport dependent) | ||||||||
Description | Note: I have not tested this on Linux, it shows on my Windows build. When loading CSV data (see below, and attached image) to show in XY plot, that has zero values in curve, the X-axis zeroes out at -5.55e-17, instead of 0. However, resizing the window fixes it, so it appears to be some sort of viewport scaling issue, and obviously is more annoying than urgent bug. This CSV data exhibts the problem: Time,V(FET_BIAS),V(RF_PWR5_TX),V(DA_VIDEO_DIG) 0.00E+00,0,0.5,-2 1.50E-11,0,0.5,-2.2 4.50E-11,0,0.7,-2.4 1.05E-10,1,0.7,-2.6 | ||||||||
Steps To Reproduce | 1. load data 2. show as XY plot 3. resize window to see effect | ||||||||
Attached Files | x-axis bad zero good zero.jpg [^] (264,411 bytes) 2007-09-12 11:36 newplot.png [^] (87,403 bytes) 2009-04-28 16:30 | ||||||||
(0011323) Berk Geveci (administrator) 2008-04-15 09:44 |
Putting this off until after we switch to new chart support |
(0014970) Ken Moreland (manager) 2009-02-16 16:18 |
The new charts do not seem to have this problem. |
(0015172) Alan Scott (manager) 2009-02-18 16:01 |
Ken, I am seeing the problem still. I did the following: Create file as listed above. Open this file. convert to >> XY Plot. On the left axis, where 0 should be, I see -5.55e-17. Trunk, local server, XP. |
(0016226) Utkarsh Ayachit (administrator) 2009-04-28 16:29 |
Tested with new plots. It's possible that Alan you were using the old chart before. Try again with updated ParaView. Attached is the new view. |
(0016261) Alan Scott (manager) 2009-04-29 20:16 |
Tested local server. |
2007-09-12 11:36 | Jon Goldman | New Issue | |
2007-09-12 11:36 | Jon Goldman | File Added: x-axis bad zero good zero.jpg | |
2007-09-12 14:20 | Mark Richardson | Status | backlog => tabled |
2007-09-12 14:20 | Mark Richardson | Assigned To | => Mark Richardson |
2008-04-15 09:44 | Berk Geveci | Note Added: 0011323 | |
2008-04-15 09:44 | Berk Geveci | Category | => 3.6 |
2009-02-16 16:18 | Ken Moreland | Note Added: 0014970 | |
2009-02-16 16:18 | Ken Moreland | Status | tabled => @80@ |
2009-02-16 16:18 | Ken Moreland | Resolution | open => fixed |
2009-02-18 16:01 | Alan Scott | Note Added: 0015172 | |
2009-02-18 16:01 | Alan Scott | Status | @80@ => @20@ |
2009-02-18 16:01 | Alan Scott | Resolution | fixed => reopened |
2009-02-18 16:01 | Alan Scott | Status | @20@ => tabled |
2009-02-18 16:01 | Alan Scott | Assigned To | Mark Richardson => Ken Moreland |
2009-02-18 16:02 | Alan Scott | Status | tabled => @20@ |
2009-02-18 16:46 | Ken Moreland | Status | @20@ => tabled |
2009-02-18 16:46 | Ken Moreland | Assigned To | Ken Moreland => Utkarsh Ayachit |
2009-04-28 16:29 | Utkarsh Ayachit | Note Added: 0016226 | |
2009-04-28 16:29 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-04-28 16:29 | Utkarsh Ayachit | Resolution | reopened => unable to reproduce |
2009-04-28 16:30 | Utkarsh Ayachit | File Added: newplot.png | |
2009-04-29 20:16 | Alan Scott | Note Added: 0016261 | |
2009-04-29 20:16 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:44 | Utkarsh Ayachit | Target Version | => 3.6 |
