0005686 | ParaView | (No Category) | public | 2007-09-12 13:39 | 2007-09-21 13:12 | ||||
Reporter | Mark Richardson | ||||||||
Summary | 0005686: Line chart is blank in client/server mode | ||||||||
Description | No data arrays are available to display in the line chart in client server mode. I used two exodus files that work in builtin mode. I also used a wavelet source. I can color by the arrays in the 3D view. I also tried a histogram. The server popped up some messages about no arrays available, but was still able to display the histogram. | ||||||||
Relationships | ||||||
(0008952) Alan Scott (manager) 2007-09-12 16:56 |
From 5683: Plots are not working client/server. * Client/server, XP/Linux, 3 6 processors. * Open disk_out_ref.exo. * Variables all on. Apply. * Data Analysis/ Plot over Line/ Apply. Nothing happens in the plotting window. Just a whole lot of empty. alan |
(0008968) Utkarsh Ayachit (administrator) 2007-09-13 09:30 |
Since the xy plot representation was changed to used data information from the post processor proxy which is a client only proxy, this issue surfaced. The problem was that vtkServerConnection did not implement gathering of data from client. Fixed that. /cvsroot/ParaView3/ParaView3/Servers/Common/vtkServerConnection.cxx,v <-- vtkServerConnection.cxx new revision: 1.14; previous revision: 1.13 I was not able to reproduce the histogram problem. |
(0009035) Alan Scott (manager) 2007-09-17 17:01 |
When I do client/server, Plot over Line, it barfs. Specifics are as follows: Nightly, September 17. XP client, Linux server. 6 nodes. open disk_out_ref.exo. Turn all variables on. Filter/ Plot over Line. I keep the server running, and have the probe line visible, but not plot. Output window looks like this: ERROR: In C:\alan\paraviewNightly\src\ParaView3\VTK\Filtering\vtkStreamingDemandDrivenPipeline.cxx, line 698 vtkCompositeDataPipeline (0AEAD288): The update extent specified in the information for output port 0 on algorithm vtkPolyLineToRectilinearGridFilter(0AEAA9E0) is 0 1431655765 0 2147483647 0 2147483647, which is outside the whole extent 0 -1 0 -1 0 -1. ERROR: In C:\alan\paraviewNightly\src\ParaView3\VTK\Filtering\vtkStreamingDemandDrivenPipeline.cxx, line 698 vtkCompositeDataPipeline (0AEAD288): The update extent specified in the information for output port 0 on algorithm vtkPolyLineToRectilinearGridFilter(0AEAA9E0) is 0 1431655765 0 2147483647 0 2147483647, which is outside the whole extent 0 -1 0 -1 0 -1. |
(0009194) Alan Scott (manager) 2007-09-21 13:12 |
Looks like there was a timing issue - this bug was fixed, I tested on old code. It is now fixed. |
2007-09-12 13:39 | Mark Richardson | New Issue | |
2007-09-12 14:14 | Mark Richardson | Relationship added | duplicate of 0005683 |
2007-09-12 16:56 | Alan Scott | Note Added: 0008952 | |
2007-09-13 09:30 | Utkarsh Ayachit | Status | backlog => tabled |
2007-09-13 09:30 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2007-09-13 09:30 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-13 09:30 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-13 09:30 | Utkarsh Ayachit | Note Added: 0008968 | |
2007-09-17 17:01 | Alan Scott | Note Added: 0009035 | |
2007-09-17 17:01 | Alan Scott | Status | @80@ => tabled |
2007-09-20 13:52 | Berk Geveci | Status | tabled => @80@ |
2007-09-21 13:12 | Alan Scott | Status | @80@ => closed |
2007-09-21 13:12 | Alan Scott | Note Added: 0009194 | |
