0005691 | ParaView | (No Category) | public | 2007-09-12 18:34 | 2007-09-17 19:22 | ||||
Summary | 0005691: Scale widget in color scale editor | ||||||||
Description | There are a couple of problems with the scale widget in the color scale editor dialog box. 1. It is a combo box. We have already found plenty of issues with using combo boxes for real numbers; let's try to avoid them. 2. The rendering does not update with focus leaves the scale box. Whenever the widget loses focus (for example the user finishes typing values and hits tab) the view should rerender to display the results. The opacity widget does this, but the scale widget does not. | ||||||||
(0008969) Utkarsh Ayachit (administrator) 2007-09-13 10:01 |
Changing scalar opacity scale widget to line edit and ensure that the view is updated when editing is done. /cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleEditor.cxx,v <-- pqColorScaleEditor.cxx new revision: 1.34; previous revision: 1.33 confused about file pqColorScaleEditor.h -- ignoring /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqColorScaleDialog.ui,v <-- pqColorScaleDialog.ui new revision: 1.9; previous revision: 1.8 |
2007-09-12 18:34 | Ken Moreland | New Issue | |
2007-09-13 09:32 | Utkarsh Ayachit | Status | backlog => tabled |
2007-09-13 09:32 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2007-09-13 10:01 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-13 10:01 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-13 10:01 | Utkarsh Ayachit | Note Added: 0008969 | |
2007-09-17 19:22 | Alan Scott | Status | @80@ => closed |
