0005697 | ParaView | (No Category) | public | 2007-09-13 12:48 | 2009-05-13 13:59 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0005697: LOD update modifies selection | ||||||||
Description | set LOD threshold to zero create a sphere make a selection rotate the sphere, and the selection changes when LOD temporarily removed some cells | ||||||||
(0011350) Utkarsh Ayachit (administrator) 2008-04-15 16:29 |
Not sure if this is a bug. When interacting with LOD is enabled, ParaView shows low-res models for both the sphere as well as the selected cells, hence the selection looks different. However, once done with interaction, the original selection is shown and remains unaffected. |
(0011352) Clinton Stimpson (developer) 2008-04-15 16:34 |
It used to be that the original selection was affected and modified. That doesn't seem to be the case anymore. |
(0011366) Alan Scott (manager) 2008-04-15 17:42 |
Tested local client. |
2007-09-13 12:48 | Clinton Stimpson | New Issue | |
2008-04-15 09:46 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2008-04-15 09:46 | Berk Geveci | Status | backlog => tabled |
2008-04-15 09:46 | Berk Geveci | Category | => 3.4 |
2008-04-15 16:29 | Utkarsh Ayachit | Note Added: 0011350 | |
2008-04-15 16:29 | Utkarsh Ayachit | Status | tabled => @20@ |
2008-04-15 16:34 | Clinton Stimpson | Note Added: 0011352 | |
2008-04-15 16:45 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-04-15 16:45 | Utkarsh Ayachit | Resolution | open => no change required |
2008-04-15 17:42 | Alan Scott | Status | @80@ => closed |
2008-04-15 17:42 | Alan Scott | Note Added: 0011366 | |
