0005699 | ParaView | (No Category) | public | 2007-09-13 14:26 | 2007-09-17 19:36 | ||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Summary | 0005699: Creating or deleting 3D view sometimes crashes | ||||||||
Description | The following sequence of events will crash ParaView. 1. Create a Wavelet source. 2. Add the point over line filter. 3. Delete the 3D view. Only the X-Y plot will be left. 4. Split the view. 5. Make the new view a 3D view. ParaView crashes at this point. Occasionally a similar setup will cause ParaView to crash when deleting view. (I did that by skipping step 3 so that 2 3D views were created and then deleting the newer 3D view.) | ||||||||
Additional Information | I think the problem has to do with the 3D line widget. The debugger shows some methods of that widget in the stack trace, and if you replace the histogram filter for the line filter above, no crash occurs. | ||||||||
(0008980) Clinton Stimpson (developer) 2007-09-13 16:22 |
Or easier. Create a line source and hit apply. Close the 3d view. Click the 3d view button to put it back, and it crashes. vtkViewport::ViewToNormalizedViewport doesn't check for NULL pointers like most other *To* functions do. |
(0008983) Clinton Stimpson (developer) 2007-09-13 17:57 |
vtkViewport should watch for NULL pointers anyway. /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkViewport.cxx,v <-- vtkViewport.cxx new revision: 1.9; previous revision: 1.8 I notice no bad behavior not being able to momentarily make a good normalized viewport to view coordinate conversion. |
2007-09-13 14:26 | Ken Moreland | New Issue | |
2007-09-13 16:22 | Clinton Stimpson | Note Added: 0008980 | |
2007-09-13 17:54 | Clinton Stimpson | Status | backlog => tabled |
2007-09-13 17:54 | Clinton Stimpson | Assigned To | => Clinton Stimpson |
2007-09-13 17:57 | Clinton Stimpson | Status | tabled => @80@ |
2007-09-13 17:57 | Clinton Stimpson | Resolution | open => fixed |
2007-09-13 17:57 | Clinton Stimpson | Note Added: 0008983 | |
2007-09-17 19:36 | Alan Scott | Status | @80@ => closed |
