0005730 | ParaView | (No Category) | public | 2007-09-18 10:57 | 2007-09-21 14:37 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0005730: Initial settings of immediate mode rendering do not match that shown in the dialog | ||||||||
Description | Try this: * Turn off immediate mode rendering * Restart paraview * Verify that is is shown off in the dialog * Save state - state shows that immediate mode rendering is on | ||||||||
(0009184) Utkarsh Ayachit (administrator) 2007-09-20 11:27 |
boolean settings get saved as "true"/"false" in the settings. For some reason QVariant::toInt() would fail for such strings (even though QVariant::canConvert(QVariant::Int) would return true). Overcame the issue by consider bools when setting int properties. /cvsroot/ParaView3/ParaView3/Qt/Core/pqSMAdaptor.cxx,v <-- pqSMAdaptor.cxx new revision: 1.36; previous revision: 1.35 |
2007-09-18 10:57 | Berk Geveci | New Issue | |
2007-09-18 10:58 | Berk Geveci | Status | backlog => tabled |
2007-09-18 10:58 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2007-09-20 11:27 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-20 11:27 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-20 11:27 | Utkarsh Ayachit | Note Added: 0009184 | |
2007-09-21 14:37 | Alan Scott | Status | @80@ => closed |
