0005739 | ParaView | (No Category) | public | 2007-09-18 15:22 | 2007-09-21 14:19 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0005739: Error when changing components in line chart | ||||||||
Description | When plotting a vector in the line chart, I see a "edit: editing failed" error every time I change a component. Everything else seems to work fine. | ||||||||
(0009156) Mark Richardson (reporter) 2007-09-19 14:11 |
When pressing the tab key, the Qt delegate tells the view to edit the next item. The tree view says the next item is in column zero of the next row. In the line series model, column zero is never editable, so Qt spits out a warning. Since the next item will never be editable, I overrode the delegate to just close the editor instead of sending the edit next hint. |
2007-09-18 15:22 | Berk Geveci | New Issue | |
2007-09-18 15:22 | Berk Geveci | Status | backlog => tabled |
2007-09-18 15:22 | Berk Geveci | Assigned To | => Mark Richardson |
2007-09-19 14:11 | Mark Richardson | Status | tabled => @80@ |
2007-09-19 14:11 | Mark Richardson | Resolution | open => fixed |
2007-09-19 14:11 | Mark Richardson | Note Added: 0009156 | |
2007-09-21 14:19 | Alan Scott | Status | @80@ => closed |
