0005746 | ParaView | (No Category) | public | 2007-09-18 21:44 | 2007-10-15 16:18 | ||||
Priority | high | Severity | crash | Reproducibility | always | ||||
Summary | 0005746: Client/Server consistantly, randomly crashes | ||||||||
Description | Ken and I are having random crashes using Client/Server. My setup is as follows: XP client/ Linux server. 3 nodes, which is 12 processors. Open up, then do nothing. Seems to only work if ParaView is left alone. After a random amount of time, ranging from about 5 minutes to 20 minutes, without bringing anything up or touching the mouse, the GUI will not respond. Server is still running, but the client states the following: ERROR: In C:\alan\paraviewNightly\src\ParaView3\Servers\Common\vtkServerConnection.cxx, line 67 vtkServerConnection (07305038): Server Connection Closed! The server doesn't think that it has lost the connection, and waits indefinitely. Could someone at Kitware try to replicate this? Give me a call if you need any other info. 9/17/2007 sourcecode. Sorry for being so vague, but I don't know how to repeatedly create this. | ||||||||
(0009454) Berk Geveci (administrator) 2007-10-12 16:38 |
I am trying to reproduce this problem, so far without any luck. I am guessing compositing is used? |
(0009477) Alan Scott (manager) 2007-10-15 12:31 |
To be honest, I don't know. I change too much in testing. I have not had this happen in a few weeks. Maybe we should mark it fixed, unless we start to see it again? It could have also been related to the network here... |
(0009481) Berk Geveci (administrator) 2007-10-15 13:40 |
Sounds good to time. I still haven't been able to reproduce it. I tested it for around 30 mins several times. |
(0009483) Alan Scott (manager) 2007-10-15 16:18 |
I am changing this to closed, since we cannot replicate it. It is also not known if it was a network problem at the user's location, or ParaView. |
2007-09-18 21:44 | Alan Scott | New Issue | |
2007-10-12 13:26 | Berk Geveci | Status | backlog => tabled |
2007-10-12 13:26 | Berk Geveci | Assigned To | => Berk Geveci |
2007-10-12 16:38 | Berk Geveci | Note Added: 0009454 | |
2007-10-15 12:31 | Alan Scott | Note Added: 0009477 | |
2007-10-15 13:41 | Berk Geveci | Note Added: 0009481 | |
2007-10-15 16:18 | Alan Scott | Status | tabled => closed |
2007-10-15 16:18 | Alan Scott | Note Added: 0009483 | |
2007-10-15 16:18 | Alan Scott | Resolution | open => fixed |
