0005749 | ParaView | (No Category) | public | 2007-09-19 09:24 | 2007-10-02 15:41 | ||||
Summary | 0005749: Fix selection inspector tree control interaction. | ||||||||
Description | In the selection inspector panel, in the tree widget showing the selection ids, it must be possible to use tab to edit entires and add new ones. (spawned from BUG 0005565). | ||||||||
(0009288) Utkarsh Ayachit (administrator) 2007-09-25 11:55 |
It's now possible to navigate items correctly in the table widget when editing. When user navigates beyond the last row in the selection indices table, new row is automatically added. /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.h,v <-- pqSelectionInspectorPanel.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.cxx,v <-- pqSelectionInspectorPanel.cxx new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSelectionInspectorPanel.ui,v <-- pqSelectionInspectorPanel.ui new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqTreeWidget.cxx,v <-- pqTreeWidget.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqTreeWidget.h,v <-- pqTreeWidget.h new revision: 1.2; previous revision: 1.1 |
(0009353) Alan Scott (manager) 2007-10-01 18:58 |
Please correct the tab order in the main part of the selection inspector panel. Specifically around Selection Type/ Field Type. |
(0009361) Utkarsh Ayachit (administrator) 2007-10-02 11:55 |
Fixed tab order. /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSelectionInspectorPanel.ui,v <-- pqSelectionInspectorPanel.ui new revision: 1.8; previous revision: 1.7 |
2007-09-19 09:24 | Utkarsh Ayachit | New Issue | |
2007-09-19 09:25 | Utkarsh Ayachit | Status | backlog => tabled |
2007-09-19 09:25 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2007-09-25 11:55 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-25 11:55 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-25 11:55 | Utkarsh Ayachit | Note Added: 0009288 | |
2007-10-01 18:58 | Alan Scott | Status | @80@ => @20@ |
2007-10-01 18:58 | Alan Scott | Resolution | fixed => reopened |
2007-10-01 18:58 | Alan Scott | Note Added: 0009353 | |
2007-10-02 11:55 | Utkarsh Ayachit | Status | @20@ => @80@ |
2007-10-02 11:55 | Utkarsh Ayachit | Resolution | reopened => fixed |
2007-10-02 11:55 | Utkarsh Ayachit | Note Added: 0009361 | |
2007-10-02 15:41 | Alan Scott | Status | @80@ => closed |
