0005753 | ParaView | (No Category) | public | 2007-09-19 16:13 | 2016-08-12 09:57 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0005753: Clipping plane related rendering problem | ||||||||
Description | Clipping plane calculation seems to have problems when the data bounds include large numbers. Bug report from Renato below. To reproduce, load the attached dataset, zoom until close and rotate. A friend brought me a question about a rendering problem in ParaView. He created a very simple dataset in VTK legacy format (available in http://www.nacad.ufrj.br/~rnelias/paraview/Celula_reservatorio.vtk [^]) and loaded the data in PV (versions 2.6.2 and 3.1.0) without any problem but, when he tries to move and rotate the geometry it turns completely distorted and messed (as can be seen here http://www.nacad.ufrj.br/~rnelias/paraview/Celula_paraview2.JPG [^] and here http://www.nacad.ufrj.br/~rnelias/paraview/Celula_paraview.JPG [^]). My first thought was that it could be a driver problem so I tried to reproduced the same problem in my computer which showed me the same problematic geometry (only when I move and rotate the model). If you look into the data supplied you can see that the point coordinates are a bit large, here is another suspicious... __Maybe__ VTK or PV is getting a confused about so large point coordinates. Does anyone have any idea about what is happening? Thanks for any help PS.: Tests performed in: -- IBM workstation with Quadro FX 4550 video board; -- Dell Precision 370 workstation (Windows XP/x64 - Pentium 4 3.6GHz, 4GB of memory and Nvidia Quadro FX 3400); -- Laptop VAIO VGN-SZ430N (Windows Vista Business - Centrino Duo 2x2GHz, 2GB of memory and Nvidia Gforce Go 7400). Renato N. Elias | ||||||||
Attached Files | test.vtk [^] (477 bytes) 2007-09-19 16:13 | ||||||||
(0037543) Kitware Robot (administrator) 2016-08-12 09:57 |
2007-09-19 16:13 | Berk Geveci | New Issue | |
2007-09-19 16:13 | Berk Geveci | File Added: test.vtk | |
2008-04-15 10:06 | Berk Geveci | Status | backlog => @30@ |
2008-04-15 10:06 | Berk Geveci | Category | Development => 3.6 |
2008-04-15 10:06 | Berk Geveci | Status | @30@ => tabled |
2008-04-15 10:06 | Berk Geveci | Assigned To | => Berk Geveci |
2009-02-16 16:30 | Ken Moreland | Category | 3.6 => 3.8 |
2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037543 | |
