0005756 | ParaView | (No Category) | public | 2007-09-20 12:53 | 2009-05-13 13:47 | ||||
Reporter | Jon Goldman | ||||||||
Assigned To | Burlen | ||||||||
Priority | normal | Severity | major | Reproducibility | sometimes | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0005756: sequence of operations with CTH data causes client *and* server to lock | ||||||||
Description | Note: This happens with a CVS trunk checkout of source from around Sept 17, and running client on Windows XP, server on linux cluster at Sandia. Note 2: We've repeatedly seen this error also on Linux client (with linux cluster) These were the steps that caused problems on windows client run: -- Opened Golevka CTH data. -- Checked the two Mass variables on. -- Threshold on Mass 1, resulting in about 28K cells. -- Clip on half of data. -- Probe on location (used default location). on Windows, the probe froze, did not return control to app within a few minutes, server spun. on Linux, only got to probe once, rotating before probe caused app to freeze, and server to die. On windows run we attached to the cluster/server root node, attached gdb, and saw the stack spinning on an open MPI call. | ||||||||
Additional Information | The stack trace on the linux cluster root node: (gdb) where #0 0x0000002a9f1276c8 in mca_btl_openib_component_progress () from /apps/x86_64/mpi/openmpi/gcc-3.4.6/openmpi-1.1.2-ofed/lib/openmpi/mca_btl_openib.so #1 0x0000002a9f01d092 in mca_bml_r2_progress () from /apps/x86_64/mpi/openmpi/gcc-3.4.6/openmpi-1.1.2-ofed/lib/openmpi/mca_bml_r2.so #2 0x0000002a9c974a9a in opal_progress () from /apps/x86_64/mpi/openmpi/gcc-3.4.6/openmpi-1.1.2-ofed/lib/libopal.so.0 #3 0x0000002a9ef10017 in mca_pml_ob1_recv () from /apps/x86_64/mpi/openmpi/gcc-3.4.6/openmpi-1.1.2-ofed/lib/openmpi/mca_pml_ob1.so #4 0x0000002a9c6d856b in PMPI_Recv () from /apps/x86_64/mpi/openmpi/gcc-3.4.6/openmpi-1.1.2-ofed/lib/libmpi.so.0 #5 0x0000002a997d5471 in vtkMPICommunicatorReceiveData<char> () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkParallel.so.pv3.1 #6 0x0000002a997d11ee in vtkMPICommunicator::ReceiveVoidArray () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkParallel.so.pv3.1 #7 0x0000002a9978643b in vtkPProbeFilter::RequestData () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkParallel.so.pv3.1 #8 0x0000002a9b2f4e14 in vtkExecutive::CallAlgorithm () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkFiltering.so.pv3.1 0000009 0x0000002a9b2f0fac in vtkDemandDrivenPipeline::ExecuteData () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkFiltering.so.pv3.1 #10 0x0000002a9b2d89a6 in vtkCompositeDataPipeline::ExecuteData () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkFiltering.so.pv3.1 0000011 0x0000002a9b2f2d32 in vtkDemandDrivenPipeline::ProcessRequest () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkFiltering.so.pv3.1 #12 0x0000002a9b3c9671 in vtkStreamingDemandDrivenPipeline::ProcessRequest () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkFiltering.so.pv3.1 #13 0x0000002a9b2d7865 in vtkCompositeDataPipeline::ProcessRequest () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkFiltering.so.pv3.1 #14 0x0000002a9b2f0c4e in vtkDemandDrivenPipeline::UpdateData () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkFiltering.so.pv3.1 #15 0x0000002a9b3c9b8f in vtkStreamingDemandDrivenPipeline::Update () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkFiltering.so.pv3.1 #16 0x0000002a9871609f in vtkAlgorithmCommand () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkFilteringCS.so #17 0x0000002a9872a334 in vtkDataSetAlgorithmCommand () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkFilteringCS.so #18 0x0000002a982a6048 in vtkProbeFilterCommand () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkGraphicsCS.so #19 0x0000002a96aa9b58 in vtkPProbeFilterCommand () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkParallelCS.so #20 0x0000002a98a546f9 in vtkClientServerInterpreter::ProcessCommandInvoke () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkClientServer.so #21 0x0000002a98a559d5 in vtkClientServerInterpreter::ProcessOneMessage () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkClientServer.so #22 0x0000002a98a55d7d in vtkClientServerInterpreter::ProcessStream () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkClientServer.so #23 0x0000002a955e02a0 in vtkSelfConnection::ProcessStreamLocally () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkPVServerCommon.so #24 0x0000002a9559b00e in vtkMPISelfConnection::SendStreamToServerNodeInternal () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkPVServerCommon.so #25 0x0000002a9559b1b5 in vtkMPISelfConnection::SendStreamToDataServer () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkPVServerCommon.so #26 0x0000002a9559c8e4 in vtkProcessModuleConnection::SendStream () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkPVServerCommon.so #27 0x0000002a9559dad9 in vtkProcessModuleConnectionManager::SendStream () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkPVServerCommon.so #28 0x0000002a955a373d in vtkProcessModule::SendStream () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkPVServerCommon.so #29 0x0000002a955907a5 in vtkClientConnectionRMI () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkPVServerCommon.so #30 0x0000002a9975e6f5 in vtkMultiProcessController::ProcessRMI () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkParallel.so.pv3.1 #31 0x0000002a9975eb3d in vtkMultiProcessController::ProcessRMIs () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkParallel.so.pv3.1 #32 0x0000002a955dd394 in vtkRemoteConnection::ProcessCommunication () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkPVServerCommon.so #33 0x0000002a955a0b9c in vtkProcessModuleConnectionManager::MonitorConnections () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkPVServerCommon.so #34 0x0000002a955a2e16 in vtkProcessModule::StartServer () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkPVServerCommon.so #35 0x0000002a955a5fc8 in vtkProcessModule::Start () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkPVServerCommon.so #36 0x0000002a95862d0b in vtkPVMain::Run () from /projects/viz/paraview/ParaView/goldman-ParaView3-trunk/Linux-blackrose-x86_64/lib/paraview-3.1/libvtkPVFilters.so #37 0x0000000000402572 in main () | ||||||||
(0009186) Jon Goldman (reporter) 2007-09-20 12:54 |
Note: The linux operations are on sensitive data. But I am pretty sure Kitware has Golevka data? |
(0016232) Utkarsh Ayachit (administrator) 2009-04-28 17:20 |
This is a very old bug (2007), so I am not sure it still exists. I tried to reproduce on linux with no avail. Please feel free to reopen if the problem still exists. |
(0016263) Alan Scott (manager) 2009-04-29 20:33 |
Could not replicate this bug. Tested client/ remote server. |
2007-09-20 12:53 | Jon Goldman | New Issue | |
2007-09-20 12:54 | Jon Goldman | Note Added: 0009186 | |
2008-04-15 10:07 | Berk Geveci | Assigned To | => Berk Geveci |
2008-04-15 10:07 | Berk Geveci | Status | backlog => tabled |
2008-04-15 10:07 | Berk Geveci | Category | => 3.6 |
2009-02-16 16:32 | Ken Moreland | Assigned To | Berk Geveci => Burlen |
2009-04-28 17:20 | Utkarsh Ayachit | Note Added: 0016232 | |
2009-04-28 17:20 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-04-28 17:20 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2009-04-29 20:33 | Alan Scott | Note Added: 0016263 | |
2009-04-29 20:33 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:44 | Utkarsh Ayachit | Target Version | => 3.6 |
