0005869 | ParaView | (No Category) | public | 2007-10-11 17:49 | 2007-11-01 16:34 | ||||
Reporter | David Karelitz | ||||||||
Priority | urgent | Severity | major | Reproducibility | always | ||||
Summary | 0005869: Connection ID is always the same on OSX/PPC | ||||||||
Description | When running on macos X/PPC (though the same might occur on intel), the default connection ID is always the same at startup. It should be a different value each time paraview is launched. | ||||||||
(0009453) Berk Geveci (administrator) 2007-10-12 15:13 |
cvs commit -m"BUG: Fixed random seed. It was being set to the same number on 32 bit machines because of loss of precision in double -> long conversion" pqSimpleServerStartup.cxx Checking for path: /cvsroot/ParaView3/ParaView3/Qt/Components Unrestricted user: berk /cvsroot/ParaView3/ParaView3/Qt/Components/pqSimpleServerStartup.cxx,v <-- pqSimpleServerStartup.cxx new revision: 1.24.4.1; previous revision: 1.24 |
(0009602) Alan Scott (manager) 2007-11-01 16:34 |
As per Tony C., this has been fixed. |
2007-10-11 17:49 | David Karelitz | New Issue | |
2007-10-12 13:25 | Berk Geveci | Status | backlog => tabled |
2007-10-12 13:25 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2007-10-12 15:13 | Berk Geveci | Status | tabled => @80@ |
2007-10-12 15:13 | Berk Geveci | Resolution | open => fixed |
2007-10-12 15:13 | Berk Geveci | Note Added: 0009453 | |
2007-11-01 16:34 | Alan Scott | Status | @80@ => closed |
2007-11-01 16:34 | Alan Scott | Note Added: 0009602 | |
