0006147 | ParaView | (No Category) | public | 2007-12-11 10:10 | 2009-05-13 13:59 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0006147: (MARS-normal) Display is wrong when first timestep value in a file is not 0 | ||||||||
Description | If the first timestep value in a file is not 0, the GUI timestep value is incorrect and any timestep value labels show 0 and not the correct value of the first timestep. | ||||||||
Attached Files | OffsetTimeRange.tar.gz [^] (26,005 bytes) 2008-04-15 12:28 | ||||||||
(0010184) Utkarsh Ayachit (administrator) 2008-01-18 09:49 |
The following patch fixes this issue. /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.cxx,v <-- pqPipelineRepresentation.cxx new revision: 1.19; previous revision: 1.18 |
(0010263) Alan Scott (manager) 2008-01-23 16:22 |
Client (XP) Server (6 processors). Trunk, January 23rd. I still see this issue. Ken has a BIG dataset that he says is unlimited release that we can send out. I am using that. Ask Ken or me for it if necessary. I bring up this file, and it has a time of 0, time step of 0. In the Information tab, we have Time Index = 0, Value = 30.8525, Index 1 = 31.1025, etc.. I click the Next Frame button, and the time button sets to time step 0 - i.e., 30.8525, time step 0. I click the Next Frame button, now we are (correctly) at 31.1025, time step 1. |
(0010749) Berk Geveci (administrator) 2008-03-07 08:09 |
Utkarsh: Can you check this out? Alan: What is that big dataset you are referring to? Do we have it? |
(0011335) Ken Moreland (manager) 2008-04-15 12:29 |
The data set Alan is talking about is a semi-large fire data set I sent Berk a while ago. To make things easier, I attached a simple, small data set that displays the problem. It is a simple modification of the singleSphereAnimation data set in ParaViewData with the time range offset to 10-20. |
(0011345) Utkarsh Ayachit (administrator) 2008-04-15 15:23 |
When a file is opened, if the current time (both the application time maintained by the time keeper, as well as the animation time maintained by the animation scene) is not within the range of time values provided by the while, then we change the current time to be the minimum time provided by the reader. /cvsroot/ParaView3/ParaView3/Qt/Core/pqAnimationScene.cxx,v <-- Qt/Core/pqAnimationScene.cxx new revision: 1.24; previous revision: 1.23 /cvsroot/ParaView3/ParaView3/Qt/Core/pqTimeKeeper.cxx,v <-- Qt/Core/pqTimeKeeper.cxx new revision: 1.14; previous revision: 1.13 |
(0011405) Alan Scott (manager) 2008-04-16 17:15 |
Tested local client |
2007-12-11 10:10 | David Karelitz | New Issue | |
2008-01-18 09:49 | Utkarsh Ayachit | Status | backlog => @80@ |
2008-01-18 09:49 | Utkarsh Ayachit | Resolution | open => fixed |
2008-01-18 09:49 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-01-18 09:49 | Utkarsh Ayachit | Note Added: 0010184 | |
2008-01-23 16:22 | Alan Scott | Status | @80@ => @20@ |
2008-01-23 16:22 | Alan Scott | Resolution | fixed => reopened |
2008-01-23 16:22 | Alan Scott | Note Added: 0010263 | |
2008-03-07 07:56 | Berk Geveci | Target Version | => MARS |
2008-03-07 08:03 | Berk Geveci | Category | Development => 3.4 |
2008-03-07 08:09 | Berk Geveci | Note Added: 0010749 | |
2008-03-07 08:09 | Berk Geveci | Status | @20@ => tabled |
2008-04-15 12:28 | Ken Moreland | File Added: OffsetTimeRange.tar.gz | |
2008-04-15 12:29 | Ken Moreland | Note Added: 0011335 | |
2008-04-15 15:23 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-15 15:23 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-04-15 15:23 | Utkarsh Ayachit | Note Added: 0011345 | |
2008-04-16 17:15 | Alan Scott | Status | @80@ => closed |
2008-04-16 17:15 | Alan Scott | Note Added: 0011405 | |
2009-05-13 13:58 | Utkarsh Ayachit | Target Version | MARS => 3.4 |
