0006290 | ParaView | (No Category) | public | 2008-01-31 09:22 | 2009-12-10 06:56 | ||||
Reporter | Pascal Obry | ||||||||
Assigned To | |||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Summary | 0006290: Tcl scipt crashes Paraview 2.6.2 with a segmentation violation on Debian GNU/Linux | ||||||||
Description | The following script crashes badly Paraview 2.6.2 with a segmentation violation. I'm not 100% sure that the Tcl script is correct but for sure Paraview should not crash in this case. I have added a backtrace below (sorry I don't have the trace with debug information). To reproduce just open the crash.pvs script. | ||||||||
Additional Information | ... while executing "Tree::itemcget .paraview.10.19.20.176.177.200.201.203.205.684.1653.1654.frame.1659.1660.1662.1664.1671.1674 time1_2.00000e+000 -data" ("eval" body line 1) invoked from within "eval [linsert $args 0 Tree::$cmd .paraview.10.19.20.176.177.200.201.203.205.684.1653.1654.frame.1659.1660.1662.1664.1671.1674]" (procedure ".paraview.10.19.20.176.177.200.201.203.205.684.1653.1654.fra..." line 1) invoked from within ".paraview.10.19.20.176.177.200.201.203.205.684.1653.1654.frame.1659.1660.1662.1664.1671.1674 itemcget time1_2.00000e+000 -data" ErrorMessage end Program received signal SIGSEGV, Segmentation fault. [Switching to Thread 0xb6fcb6e0 (LWP 11362)] 0x0a5bd0bc in vtkDataArray::GetTuple1 () (gdb) bt #0 0x0a5bd0bc in vtkDataArray::GetTuple1 () #1 0x0880e076 in vtkPVSelectTimeSet::SetTimeValueCallback () #2 0x088b6272 in vtkPVSelectTimeSetCppCommand () #3 0x08ce7021 in TclInvokeStringCommand () #4 0x08ce87fb in TclEvalObjvInternal () #5 0x08ce8b41 in Tcl_EvalEx () #6 0x08d2e747 in Tcl_FSEvalFile () #7 0x08d2e843 in Tcl_EvalFile () #8 0x089126af in vtkKWApplication::LoadScript () 0000009 0x086a758b in vtkPVWindow::LoadScript () #10 0x089a523a in vtkKWWindowBase::LoadScript () 0000011 0x088d3000 in vtkPVWindowCppCommand () #12 0x08ce7021 in TclInvokeStringCommand () #13 0x08ce87fb in TclEvalObjvInternal () #14 0x08ce8b41 in Tcl_EvalEx () #15 0x08ce9012 in Tcl_Eval () #16 0x08ce9098 in Tcl_GlobalEval () #17 0x0898e3b8 in vtkKWTkUtilities::EvaluateSimpleStringInternal () #18 0x0898e6e5 in vtkKWTkUtilities::EvaluateSimpleString () #19 0x0893574d in vtkKWMenu::CommandInvokedCallback () #20 0x08a3a46b in vtkKWMenuCppCommand () #21 0x08ce7021 in TclInvokeStringCommand () #22 0x08ce87fb in TclEvalObjvInternal () #23 0x08d0dd84 in TclExecuteByteCode () #24 0x08d0cf1e in TclCompEvalObj () #25 0x08ce97b7 in Tcl_EvalObjEx () #26 0x08d89275 in TkInvokeMenu () #27 0x08d8a50c in MenuWidgetObjCmd () #28 0x08ce87fb in TclEvalObjvInternal () #29 0x08ce95f7 in Tcl_EvalObjv () #30 0x08ce9756 in Tcl_EvalObjEx () #31 0x08d3e91a in Tcl_UplevelObjCmd () #32 0x08ce87fb in TclEvalObjvInternal () #33 0x08d0dd84 in TclExecuteByteCode () #34 0x08d0cf1e in TclCompEvalObj () #35 0x08d3e347 in TclObjInterpProc () #36 0x08ce87fb in TclEvalObjvInternal () #37 0x08ce8b41 in Tcl_EvalEx () #38 0x08ce9012 in Tcl_Eval () #39 0x08ce9098 in Tcl_GlobalEval () #40 0x08dd7cdf in Tk_BindEvent () #41 0x08ddc7e7 in TkBindEventProc () #42 0x08d64ea9 in Tk_HandleEvent () #43 0x08d64f45 in WindowEventProc () #44 0x08d348c1 in Tcl_ServiceEvent () #45 0x08d34b2a in Tcl_DoOneEvent () #46 0x08911c8b in vtkKWApplication::Start () #47 0x08660b8f in vtkPVApplication::Start () #48 0x086e4ff9 in vtkPVProcessModuleGUIHelper::RunGUIStart () 0000049 0x0935ffdd in vtkProcessModule::StartClient () #50 0x0936054d in vtkProcessModule::Start () #51 0x0936cb79 in vtkProcessModuleGUIHelper::Run () #52 0x08642ba0 in MyMain () #53 0x08642bf2 in main () | ||||||||
Attached Files | bug.tgz [^] (1,864 bytes) 2008-01-31 09:22 | ||||||||
There are no notes attached to this issue. |
2008-01-31 09:22 | Pascal Obry | New Issue | |
2008-01-31 09:22 | Pascal Obry | File Added: bug.tgz | |
2009-12-09 14:49 | Berk Geveci | Project | @3@ => ParaView |
2009-12-10 06:56 | Berk Geveci | Status | backlog => closed |
2009-12-10 06:56 | Berk Geveci | Resolution | open => won't fix |
