0006623 | ParaView | (No Category) | public | 2008-03-18 15:43 | 2009-05-13 13:59 | ||||
Reporter | Berk Geveci | ||||||||
Priority | normal | Severity | crash | Reproducibility | random | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0006623: Client crashes after server crashes | ||||||||
Description | We should be able to handle server crashes more gracefully. I am running into cases where the client crashes after disconnecting from a server that dies. This happens either when disconnecting or connecting to another server. | ||||||||
Steps To Reproduce | It should be easy to test this by adding abort inside a filter. | ||||||||
(0011976) Utkarsh Ayachit (administrator) 2008-05-16 16:43 |
Could not reproduce with a few simple cases that I tried. Any particular case where such crashes are observed? |
(0013300) Alan Scott (manager) 2008-09-04 15:02 |
I am marking this closed, since I cannot replicate it either. * I killed a set of nodes, and ParaView client handled it acceptably well. * I ssh'd into a node, and killed pvserver. ParaView hung, but it seemed that the system knew that I had done some dirty work, and had not killed the nodes - as it usually does. Thus, not a good test. |
2008-03-18 15:43 | Berk Geveci | New Issue | |
2008-04-10 17:31 | Ken Moreland | Category | Development => 3.4 |
2008-04-10 17:31 | Ken Moreland | Status | backlog => tabled |
2008-04-10 17:31 | Ken Moreland | Assigned To | => Berk Geveci |
2008-05-15 13:42 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-05-16 16:43 | Utkarsh Ayachit | Note Added: 0011976 | |
2008-05-16 16:43 | Utkarsh Ayachit | Status | tabled => @20@ |
2008-09-03 13:28 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-09-03 13:28 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2008-09-04 15:02 | Alan Scott | Status | @80@ => closed |
2008-09-04 15:02 | Alan Scott | Note Added: 0013300 | |
