0006645 | ParaView | (No Category) | public | 2008-03-24 15:19 | 2008-04-01 17:29 | ||||
Reporter | Kent Eschenberg | ||||||||
Summary | 0006645: Cannot Save Animation Frames from Python | ||||||||
Description | The bug reporting software does not allow me to select the correct options for the following so I'll provide the info here: Category: 3.2.1 Product Version: standard After recording a few frames with pvpython or pvbatch, using OpenGL, the program crashes. The frames made up to the crash look correct. | ||||||||
Additional Information | Works fine when linked to Mesa. | ||||||||
Attached Files | t6.py [^] (485 bytes) 2008-03-24 15:19 | ||||||||
(0010959) Utkarsh Ayachit (administrator) 2008-03-28 13:59 |
The destroying and creating of windows when saving each frame (with offscreen rendering enabled) may be causing this problem. We should avoid this. |
(0011002) Utkarsh Ayachit (administrator) 2008-03-31 16:43 |
Avoids creation/destruction of window when each frame is saved. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMAnimationSceneImageWriter.cxx,v <-- Servers/ServerManager/vtkSMAnimationSceneImageWriter.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRenderViewProxy.cxx,v <-- Servers/ServerManager/vtkSMRenderViewProxy.cxx new revision: 1.65; previous revision: 1.64 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRenderViewProxy.h,v <-- Servers/ServerManager/vtkSMRenderViewProxy.h new revision: 1.28; previous revision: 1.27 |
(0011026) Alan Scott (manager) 2008-04-01 17:29 |
Not tested. |
2008-03-24 15:19 | Kent Eschenberg | New Issue | |
2008-03-24 15:19 | Kent Eschenberg | File Added: t6.py | |
2008-03-28 13:59 | Utkarsh Ayachit | Note Added: 0010959 | |
2008-03-31 16:43 | Utkarsh Ayachit | Status | backlog => @80@ |
2008-03-31 16:43 | Utkarsh Ayachit | Resolution | open => fixed |
2008-03-31 16:43 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-03-31 16:43 | Utkarsh Ayachit | Note Added: 0011002 | |
2008-04-01 17:29 | Alan Scott | Status | @80@ => closed |
2008-04-01 17:29 | Alan Scott | Note Added: 0011026 | |
