0006651 | ParaView | (No Category) | public | 2008-03-25 17:03 | 2010-11-08 14:40 | ||||
Reporter | Sean Ziegeler | ||||||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0006651: Remove INITFINI flag from CMake/ParaViewCommon.cmake, | ||||||||
Description | Starting on line 233 of CMake/ParaViewCommon.cmake, there's a check to see if the IBM xlC compiler supports the -binitfini:poe_remote_main option and add it to the C flags. The comments are correct in that the option is required to build an MPI executable. However, that option can and should be included in the MPI_EXTRA_LIBRARY variable. Non-MPI builds of ParaView don't like the option (at least on my systems). Even MPI builds require some non-MPI executables to complete the build process. I am guessing this is a holdover from the days before the existence of MPI_EXTRA_LIBRARY. Recommend removing that option, or at least changing it to append to the MPI_EXTRA_LIBRARY variable instead of C flags. | ||||||||
(0023056) David Partyka (developer) 2010-11-08 10:01 |
I took your suggestion and now set the flag on MPI_EXTRA_LIBRARY instead. Please reopen the issue if this does not fix it as I don't have an xlc machine to test on. Fixed with commit d439615da1d4611727e37241477de012cc3a0168. |
2008-03-25 17:03 | Sean Ziegeler | New Issue | |
2008-04-15 12:51 | Berk Geveci | Status | backlog => @30@ |
2010-11-05 13:42 | Utkarsh Ayachit | Status | @30@ => tabled |
2010-11-05 13:42 | Utkarsh Ayachit | Assigned To | => David Partyka |
2010-11-08 10:01 | David Partyka | Note Added: 0023056 | |
2010-11-08 10:01 | David Partyka | Status | tabled => @80@ |
2010-11-08 10:01 | David Partyka | Fixed in Version | => 3.10 |
2010-11-08 10:01 | David Partyka | Resolution | open => fixed |
2010-11-08 14:40 | Alan Scott | Status | @80@ => closed |
