0006659 | ParaView | (No Category) | public | 2008-03-25 21:48 | 2009-05-13 13:59 | ||||
Priority | urgent | Severity | crash | Reproducibility | always | ||||
Summary | 0006659: Selection multi-block and spreadsheet dies | ||||||||
Description | XP, local, trunk. This needs to be fixed before I can resolve bug number 6627. There is most likely an easier way to replicate, but this is very consistent. Run ParaView locally. open can. All variables, apply. Surface with edges. Select Points On, choose one point on the block. Split vertical Spreadsheet view Filters/ Data Analysis/ Extract Selection Copy Active Selection, Apply. Display tab, click DataSet 0. A very bad crash. | ||||||||
(0010955) Utkarsh Ayachit (administrator) 2008-03-28 13:23 |
I can't seem to reproduce this. Can you please verify if this still crashes? Thanks |
(0011007) Alan Scott (manager) 2008-03-31 19:46 |
Feedback given in a separate e-mail. This still crashes with Windows XP. Although I don't think it matters, I am building with the silo reader. |
(0011061) Utkarsh Ayachit (administrator) 2008-04-03 11:54 |
BUG: Fixed BUG 0006659. (index--) was used instead of (*index)--. Fixed that. /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCompositeDataInformation.cxx,v <-- Servers/Common/vtkPVCompositeDataInformation.cxx new revision: 1.13; previous revision: 1.12 |
(0011142) Alan Scott (manager) 2008-04-07 19:26 |
Tested local paraview, as stated in the bug. |
2008-03-25 21:48 | Alan Scott | New Issue | |
2008-03-26 12:56 | Alan Scott | Assigned To | => Utkarsh Ayachit |
2008-03-26 12:56 | Alan Scott | Status | backlog => tabled |
2008-03-28 13:23 | Utkarsh Ayachit | Note Added: 0010955 | |
2008-03-28 13:23 | Utkarsh Ayachit | Status | tabled => @20@ |
2008-03-31 19:46 | Alan Scott | Note Added: 0011007 | |
2008-03-31 19:46 | Alan Scott | Status | @20@ => tabled |
2008-04-03 11:54 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-03 11:54 | Utkarsh Ayachit | Resolution | open => fixed |
2008-04-03 11:54 | Utkarsh Ayachit | Note Added: 0011061 | |
2008-04-07 19:26 | Alan Scott | Status | @80@ => closed |
2008-04-07 19:26 | Alan Scott | Note Added: 0011142 | |
