0006702 | ParaView | (No Category) | public | 2008-04-01 16:31 | 2008-04-07 17:53 | ||||
Priority | normal | Severity | feature | Reproducibility | have not tried | ||||
Summary | 0006702: Color by AMR level | ||||||||
Description | When you are drawing the outlines of an AMR data set, you can color by some indices, but there does not seem to be a way to color by level. | ||||||||
(0011032) Utkarsh Ayachit (administrator) 2008-04-02 10:47 |
There's a vtkHierarchicalIndex which is 2-tuble (level, dataset index). To color by level, choose the 0th component of the vtkHierarhicalIndex. |
(0011034) Ken Moreland (manager) 2008-04-02 10:51 |
Oh. I had no idea. Chances are, neither will users. Is there any way to make it more obvious? |
(0011040) Utkarsh Ayachit (administrator) 2008-04-02 14:26 |
Added two arrays "vtkAMRLevel" and "vtkAMRIndex" that can be used for coloring. Selection uses these arrays instead of vtkHierarchicalIndex. Also updated the selection convertor to expect the composite index/hierarchical index arrays only on the cell data. This avoids adding the point data arrays saving some memory. /cvsroot/ParaView3/ParaView3/Servers/Common/vtkSelectionConverter.cxx,v <-- Servers/Common/vtkSelectionConverter.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVGeometryFilter.cxx,v <-- Servers/Filters/vtkPVGeometryFilter.cxx new revision: 1.78; previous revision: 1.77 |
(0011129) Alan Scott (manager) 2008-04-07 17:53 |
Tested client server. Great! |
2008-04-01 16:31 | Ken Moreland | New Issue | |
2008-04-02 10:47 | Utkarsh Ayachit | Note Added: 0011032 | |
2008-04-02 10:51 | Ken Moreland | Note Added: 0011034 | |
2008-04-02 14:17 | Utkarsh Ayachit | Status | backlog => tabled |
2008-04-02 14:17 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-04-02 14:26 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-02 14:26 | Utkarsh Ayachit | Resolution | open => fixed |
2008-04-02 14:26 | Utkarsh Ayachit | Note Added: 0011040 | |
2008-04-07 17:53 | Alan Scott | Status | @80@ => closed |
2008-04-07 17:53 | Alan Scott | Note Added: 0011129 | |
