0006783 | ParaView | (No Category) | public | 2008-04-09 17:47 | 2009-05-13 13:59 | ||||
Summary | 0006783: Cannot convert frustum selection to id selection | ||||||||
Description | Create a Wavelet source and perform a select cells through operation. In the selection inspector, change the selection type from Frustum to either IDs or Global IDs. The selection disappears. The selection should be converted to IDs (which was the behavior in 3.2.1). | ||||||||
Relationships | ||||||
(0011760) Berk Geveci (administrator) 2008-05-08 13:51 |
Re-enable but add a warning if number of ids in the selection is larger than 10000. |
(0011819) Utkarsh Ayachit (administrator) 2008-05-12 11:37 |
It's now possible to convert frustum selection to id/global-id selection. If number of IDs is > 10,000, then a warning is flashed. ------------------------------------ commitid: Jh2cL1CYGUdIOG2t; ------------------------------------ /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.cxx,v <-- Servers/ServerManager/vtkSMSelectionHelper.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.cxx,v <-- Qt/Components/pqSelectionInspectorPanel.cxx new revision: 1.27; previous revision: 1.26 |
(0011877) Alan Scott (manager) 2008-05-13 19:05 |
When I select Global ID's, I get lots of grumbling verbage back. Is this expected behavior? Local ParaView, XP. |
(0011897) Ken Moreland (manager) 2008-05-14 10:37 |
Can you be more specific about the grumbling? I just loaded disk_out_ref, selected the entire thing with a frustum select (either points or cells) and then converted to global ids. The process was silent. |
(0011900) Utkarsh Ayachit (administrator) 2008-05-14 10:45 |
Alan, There was a bug in PVGeometryFilter that I fixed (probably yesterday) which was causing some errors on the (process > 0). So you may want to update before trying it out again. |
(0012062) Alan Scott (manager) 2008-05-21 23:10 |
OK, that fixed the grumbling - too many error messages issue. Next, I did the following (seems to need to be done exactly as follows): * Wavelet source. * Representation: Surface. * Select cells through. * Rotate the wavelet with the left mouse button. * Selection inspector, change selection type from frustum to IDs. * Rotate the wavelet with the left mouse button. * Selection inspector, change selection type from IDs to Global IDs. The select goes away - should it? * Rotate the wavelet with the left mouse button. * Selection inspector, change selection type from Global IDs to IDs. * Rotate the cube, and you will find that multiple random cells are now selected. Surely this shouldn't be happening... Client/Server, 6 pvservers, XP client. |
(0012162) Utkarsh Ayachit (administrator) 2008-05-30 10:32 |
Conversion to global ids should not be available to wavelet since wavelet doesn't produce gloabl ids. Added a new bug 0007126 for that. |
(0012196) Alan Scott (manager) 2008-06-02 19:12 |
Fixed. Tested as per my notes below. |
2008-04-09 17:47 | Ken Moreland | New Issue | |
2008-04-09 17:47 | Ken Moreland | Status | backlog => tabled |
2008-04-09 17:47 | Ken Moreland | Assigned To | => Berk Geveci |
2008-05-08 13:51 | Berk Geveci | Note Added: 0011760 | |
2008-05-08 13:51 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-05-12 11:37 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-05-12 11:37 | Utkarsh Ayachit | Resolution | open => fixed |
2008-05-12 11:37 | Utkarsh Ayachit | Note Added: 0011819 | |
2008-05-13 19:05 | Alan Scott | Status | @80@ => @20@ |
2008-05-13 19:05 | Alan Scott | Resolution | fixed => reopened |
2008-05-13 19:05 | Alan Scott | Note Added: 0011877 | |
2008-05-14 10:37 | Ken Moreland | Note Added: 0011897 | |
2008-05-14 10:45 | Utkarsh Ayachit | Note Added: 0011900 | |
2008-05-16 14:10 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-05-16 14:10 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-05-21 23:10 | Alan Scott | Status | @80@ => @20@ |
2008-05-21 23:10 | Alan Scott | Resolution | fixed => reopened |
2008-05-21 23:10 | Alan Scott | Note Added: 0012062 | |
2008-05-30 10:31 | Utkarsh Ayachit | Relationship added | related to 0007126 |
2008-05-30 10:32 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-05-30 10:32 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-05-30 10:32 | Utkarsh Ayachit | Note Added: 0012162 | |
2008-06-02 19:12 | Alan Scott | Status | @80@ => closed |
2008-06-02 19:12 | Alan Scott | Note Added: 0012196 | |
