0006786 | ParaView | (No Category) | public | 2008-04-10 04:12 | 2008-07-07 19:07 | ||||
Reporter | Jean M. Favre | ||||||||
Assigned To | Pat Marion | ||||||||
Summary | 0006786: Compartative views last frame is not set at the last timestep value | ||||||||
Description | Because of an incorrect computation of the time increment to use in generating the multi-views in comparative viewing, the last frame does not coincide with the last timestep value. A suggested change is to edit on line 565 of ./Servers/ServerManager/vtkSMComparativeViewProxy.cxx changing the computation of the increment from double increment = (this->TimeRange[1] - this->TimeRange[0])/ (this->Dimensions[0]*this->Dimensions[1]); to double increment = (this->TimeRange[1] - this->TimeRange[0])/ (this->Dimensions[0]*this->Dimensions[1] - 1.0); | ||||||||
(0012644) Alan Scott (manager) 2008-07-07 19:07 |
Tested client/server with can, split window. Works. |
2008-04-10 04:12 | Jean M. Favre | New Issue | |
2008-04-10 11:24 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2008-04-10 11:24 | Berk Geveci | Status | backlog => tabled |
2008-05-08 14:12 | Berk Geveci | Category | 3.4 => 3.6 |
2008-07-02 12:57 | Berk Geveci | Assigned To | Utkarsh Ayachit => Pat Marion |
2008-07-02 12:57 | Berk Geveci | Category | 3.6 => Development |
2008-07-03 12:13 | Pat Marion | Status | tabled => @80@ |
2008-07-03 12:13 | Pat Marion | Resolution | open => fixed |
2008-07-07 19:07 | Alan Scott | Status | @80@ => closed |
2008-07-07 19:07 | Alan Scott | Note Added: 0012644 | |
