0006935 | ParaView | (No Category) | public | 2008-05-01 16:13 | 2009-05-13 13:59 | ||||
Summary | 0006935: Display Transformation inputs only allow two digits of precision | ||||||||
Description | The Display tab, Transformation (at the bottom of the tab) only allows two digits of precision beyond the decimal. This should be changed to any number. For instance, on the Translate - X, try to put 0.001 in the input box. | ||||||||
Relationships | ||||||
(0012222) Utkarsh Ayachit (administrator) 2008-06-03 11:30 |
change spin boxes to line edits. |
(0012930) Utkarsh Ayachit (administrator) 2008-08-04 16:47 |
Converting the transformation widgets on the display panel to use line edits instead of spin boxes. /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayProxyEditor.cxx,v <-- Qt/Components/pqDisplayProxyEditor.cxx new revision: 1.61; previous revision: 1.60 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqDisplayProxyEditor.ui,v <-- Qt/Components/Resources/UI/pqDisplayProxyEditor.ui new revision: 1.34; previous revision: 1.33 |
(0012959) Alan Scott (manager) 2008-08-07 16:01 |
Tested client/server |
2008-05-01 16:13 | Alan Scott | New Issue | |
2008-05-13 12:48 | Ken Moreland | Status | backlog => tabled |
2008-05-13 12:48 | Ken Moreland | Assigned To | => Berk Geveci |
2008-06-03 11:30 | Utkarsh Ayachit | Note Added: 0012222 | |
2008-06-03 11:30 | Utkarsh Ayachit | Assigned To | Berk Geveci => Clinton Stimpson |
2008-07-22 11:12 | Ken Moreland | Relationship added | has duplicate 0007380 |
2008-08-04 16:18 | Berk Geveci | Assigned To | Clinton Stimpson => Utkarsh Ayachit |
2008-08-04 16:47 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-08-04 16:47 | Utkarsh Ayachit | Resolution | open => fixed |
2008-08-04 16:47 | Utkarsh Ayachit | Note Added: 0012930 | |
2008-08-07 16:01 | Alan Scott | Status | @80@ => closed |
2008-08-07 16:01 | Alan Scott | Note Added: 0012959 | |
