0007366 | ParaView | (No Category) | public | 2008-07-18 14:07 | 2016-08-12 09:57 | ||||
Reporter | Berk Geveci | ||||||||
Target Version | Someday | Fixed in Version | |||||||
Summary | 0007366: Test ParaView build with 1 cmake run (preloaded cache) | ||||||||
Description | We had reports that MPI include path is not set properly and VTK/Parallel fails to compile. | ||||||||
(0023621) David Partyka (developer) 2010-11-30 22:30 |
Can you give some more details? I am not sure what you mean by preloaded cache. The amber5 dashboard builds with MPI and that writes out an initial cache enabling MPI, if that is what you mean? |
(0037584) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-07-18 14:07 | Berk Geveci | New Issue | |
2009-02-18 09:18 | Utkarsh Ayachit | Category | 3.6 => Someday |
2009-05-13 13:49 | Utkarsh Ayachit | Target Version | => Someday |
2010-11-30 22:28 | David Partyka | Assigned To | => David Partyka |
2010-11-30 22:28 | David Partyka | Status | backlog => tabled |
2010-11-30 22:30 | David Partyka | Note Added: 0023620 | |
2010-11-30 22:30 | David Partyka | Note Deleted: 0023620 | |
2010-11-30 22:30 | David Partyka | Note Added: 0023621 | |
2010-11-30 22:30 | David Partyka | Status | tabled => @20@ |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037584 | |
