0007391 | ParaView | (No Category) | public | 2008-07-22 15:20 | 2009-05-13 13:47 | ||||
Summary | 0007391: vtkPExtractHistogram should produce empty output on non-root processess | ||||||||
Description | To view the issue caused by this bug do the following: * run ParaView in parallel * apply histogram to any source * look at histogram output in spreadsheet view vtkPExtractHistogram produces valid output only on the root node, however it still produces non-empty recitlinear grids on other processes. The spreadsheet view simply delivers all the data from all the nodes to the client and hence we get invalid data on the client. | ||||||||
(0014087) Utkarsh Ayachit (administrator) 2008-11-10 18:15 |
This bug is not longer relevant since vtkPExtractHistogram now produces vtkTable as an output. It's ensured that an empty vtkTable is generated on satellites as requested by this bug. |
(0014145) Alan Scott (manager) 2008-11-19 18:27 |
Looks right to me. Used client/server, sphere, histogram, spreadsheet. |
2008-07-22 15:20 | Utkarsh Ayachit | New Issue | |
2008-11-10 18:15 | Utkarsh Ayachit | Note Added: 0014087 | |
2008-11-10 18:15 | Utkarsh Ayachit | Status | backlog => @80@ |
2008-11-10 18:15 | Utkarsh Ayachit | Resolution | open => fixed |
2008-11-10 18:15 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-11-19 18:27 | Alan Scott | Note Added: 0014145 | |
2008-11-19 18:27 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:47 | Utkarsh Ayachit | Target Version | => 3.6 |
