0007633 | ParaView | (No Category) | public | 2008-09-08 15:31 | 2011-01-13 17:00 | ||||
Summary | 0007633: File ID variables | ||||||||
Description | Old ParaView use to create a variable that numbered each incoming file. There is a variable now, called File Id, which is always zero. I have a user that needs to identify which files are which, in order to debug algorithms from simulation codes. Either we need a working File Id-ish variable, or we need the File Id fixed. This needs to be done early in the development of 3.6. | ||||||||
(0015037) Utkarsh Ayachit (administrator) 2009-02-17 13:27 |
This seems to have been fixed. I opened "z_pinch1.exo.8.[0-7]" and there's a "File Ids" variable that when turned on of the properties panel creates a cell variable "FileId" which is what you want and is no zero (goes from 0-7 in my case). |
(0015118) Alan Scott (manager) 2009-02-17 21:34 |
Nope, not fixed. It is now kind of strange. Do exactly as follows: Paraview trunk, local server, XP Open z_pinch1.exo.8.0. Turn all variables on. Apply. Color by fileId. Toggle color legend visibility. Range is 0-0 Rescale to Data Range. Range remains 0-0 Now, try advancing one time step. Rescale to Data Range. Range is now 0-7. This is what we want. Now, go back one time step. Range remains good. |
(0015139) Utkarsh Ayachit (administrator) 2009-02-18 11:03 |
vtkPExodusIIReader sets the FileId and then sets the FileName, however setting file name was resulting in resetting of the fileId to 0. Fixed that by not resetting the FileId since it's not meta-data read from file anyways. Commit to directory "ParaView3/VTK/Hybrid" lies in external project VTK /cvsroot/ParaView3/ParaView3/VTK/Hybrid/vtkExodusIIReader.cxx,v <-- VTK/Hybrid/vtkExodusIIReader.cxx new revision: 1.74; previous revision: 1.73 |
(0015181) Alan Scott (manager) 2009-02-18 16:53 |
Tested local server. |
2008-09-08 15:31 | Alan Scott | New Issue | |
2009-02-17 13:27 | Utkarsh Ayachit | Note Added: 0015037 | |
2009-02-17 13:27 | Utkarsh Ayachit | Status | backlog => @80@ |
2009-02-17 13:27 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2009-02-17 13:27 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-02-17 21:34 | Alan Scott | Note Added: 0015118 | |
2009-02-17 21:34 | Alan Scott | Status | @80@ => @20@ |
2009-02-17 21:34 | Alan Scott | Resolution | unable to reproduce => reopened |
2009-02-18 11:03 | Utkarsh Ayachit | Note Added: 0015139 | |
2009-02-18 11:03 | Utkarsh Ayachit | Status | @20@ => @80@ |
2009-02-18 11:03 | Utkarsh Ayachit | Resolution | reopened => fixed |
2009-02-18 16:53 | Alan Scott | Note Added: 0015181 | |
2009-02-18 16:53 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
