0007657 | ParaView | (No Category) | public | 2008-09-11 14:36 | 2016-08-12 09:57 | ||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Summary | 0007657: Recording camera zoom does not work with parallel projection | ||||||||
Description | The camera animation does not work quite right with the zoom when using parallel projection. The position information is recorded, but the zoom level is not. To replicate: 1. Create a cone source (or anything else). 2. Turn on parallel projection. 3. Open the animation view. 4. Create a camera track. 5. Zoom the view in or out. 6. Edit one of the keyframes of the camera track and record the current camera view (the other keyframe will be the original view). 7. Play the animation. The camera will not actually zoom. | ||||||||
Relationships | ||||||
(0037592) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-09-11 14:36 | Ken Moreland | New Issue | |
2009-02-17 13:31 | Utkarsh Ayachit | Priority | normal => low |
2009-02-17 13:31 | Utkarsh Ayachit | Category | Development => 3.8 |
2009-02-18 09:01 | Utkarsh Ayachit | Relationship added | has duplicate 0007466 |
2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-11-26 13:49 | David Partyka | Assigned To | => Utkarsh Ayachit |
2010-11-26 13:49 | David Partyka | Status | backlog => tabled |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037592 | |
