0007795 | ParaView | (No Category) | public | 2008-10-09 09:47 | 2011-01-14 20:37 | ||||
Reporter | Stephane P | ||||||||
Status | closed | Resolution | suspended | ||||||
Target Version | 3.8 | Fixed in Version | |||||||
Summary | 0007795: cache geometry for animation does not work in client-server mode | ||||||||
Description | When creating animations, the cache geometry flag can be activated (animation inspector -> cache geometry check box). This allow to have fast playback framerates by saving all the time steps in a flipbook. This does not work in client-server mode : all the pipeline is always re-executed at each time step. | ||||||||
Additional Information | To test this, load the "cache.pvsm" state file. In builtin mode, if you activate the cache, the progress bar is never activated when playing back the animation. In client server mode, whatever the settings of the cache, the progress bar always flickers, showing that the pipeline is updated at each time step. | ||||||||
Project | ParaViS | ||||||||
Attached Files | cache.pvsm [^] (53,818 bytes) 2008-10-09 09:47 | ||||||||
(0013878) Utkarsh Ayachit (administrator) 2008-10-14 16:11 |
Adding a new vtkPVCacheKeeper which takes out the logic for cache-keeping from Update suppressor. The cache keeper is inserted immediately after the geometry filter. In this stage the caching is on the server side immediately after the "geometry" filter. The next-stage is to use a second cache-keeper in parallel after the distributor to cache the result. /cvsroot/ParaView3/ParaView3/Servers/Filters/CMakeLists.txt,v <-- Servers/Filters/CMakeLists.txt new revision: 1.180; previous revision: 1.179 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVCacheKeeper.cxx,v <-- Servers/Filters/vtkPVCacheKeeper.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVCacheKeeper.h,v <-- Servers/Filters/vtkPVCacheKeeper.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVCacheKeeperPipeline.cxx,v <-- Servers/Filters/vtkPVCacheKeeperPipeline.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVCacheKeeperPipeline.h,v <-- Servers/Filters/vtkPVCacheKeeperPipeline.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVGeometryInformation.cxx,v <-- Servers/Filters/vtkPVGeometryInformation.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVUpdateSuppressor.cxx,v <-- Servers/Filters/vtkPVUpdateSuppressor.cxx new revision: 1.63; previous revision: 1.62 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVUpdateSuppressor.h,v <-- Servers/Filters/vtkPVUpdateSuppressor.h new revision: 1.28; previous revision: 1.27 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMDataLabelRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMDataLabelRepresentationProxy.cxx new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRepresentationStrategy.cxx,v <-- Servers/ServerManager/vtkSMRepresentationStrategy.cxx new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMRepresentationStrategy.h,v <-- Servers/ServerManager/vtkSMRepresentationStrategy.h new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSimpleParallelStrategy.cxx,v <-- Servers/ServerManager/vtkSMSimpleParallelStrategy.cxx new revision: 1.24; previous revision: 1.23 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSimpleParallelStrategy.h,v <-- Servers/ServerManager/vtkSMSimpleParallelStrategy.h new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSimpleStrategy.cxx,v <-- Servers/ServerManager/vtkSMSimpleStrategy.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSimpleStrategy.h,v <-- Servers/ServerManager/vtkSMSimpleStrategy.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml new revision: 1.317; previous revision: 1.316 |
(0024686) Utkarsh Ayachit (administrator) 2011-01-14 13:51 |
Caching on dataserver is supported for now. We can add another bug for caching on rendering nodes, if neeeded. |
(0024700) Alan Scott (manager) 2011-01-14 20:37 |
I also believe this is fixed. If not, please reopen. |
2008-10-09 09:47 | Stephane P | New Issue | |
2008-10-09 09:47 | Stephane P | File Added: cache.pvsm | |
2008-10-14 16:11 | Utkarsh Ayachit | Status | backlog => tabled |
2008-10-14 16:11 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-10-14 16:11 | Utkarsh Ayachit | Note Added: 0013878 | |
2009-02-17 14:17 | Utkarsh Ayachit | Category | 3.4 => 3.8 |
2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 |
2011-01-14 13:51 | Utkarsh Ayachit | Note Added: 0024686 | |
2011-01-14 13:51 | Utkarsh Ayachit | Status | tabled => @80@ |
2011-01-14 13:51 | Utkarsh Ayachit | Resolution | open => suspended |
2011-01-14 20:37 | Alan Scott | Note Added: 0024700 | |
2011-01-14 20:37 | Alan Scott | Status | @80@ => closed |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
