0007875 | ParaView | (No Category) | public | 2008-10-28 14:31 | 2010-11-16 23:31 | ||||
Assigned To | Dave DeMarle | ||||||||
Priority | normal | Severity | feature | Reproducibility | have not tried | ||||
Status | closed | Resolution | suspended | ||||||
Target Version | 3.8 | Fixed in Version | |||||||
Summary | 0007875: Log scales of negative numbers | ||||||||
Description | If the entire range of a variable is less than zero, it should be possible to apply a log scale. In this case the log scaling should follow the negated values of the scalars. | ||||||||
(0023220) Dave DeMarle (administrator) 2010-11-12 14:16 |
Is this feature request still active? Will behavior confuse users w/regard to 0 in range? |
(0023324) Ken Moreland (manager) 2010-11-16 23:31 |
I agree that it probably only makes sense to fix this issue if you are also (somehow) enabling ranges that cross 0. That would be a nice feature, but there does not seem to be a huge demand for it. To (sort of) verify this, I added an item to the ParaView UserVoice: http://paraview.uservoice.com/forums/11350-general/suggestions/1229153-provide-reasonable-log-scaling-for-scalar-with-0-o [^] |
2008-10-28 14:31 | Ken Moreland | New Issue | |
2009-02-17 14:39 | Utkarsh Ayachit | Category | 3.6 => Pending |
2009-02-20 14:03 | Ken Moreland | Category | Pending => 3.8 |
2009-05-13 13:40 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-11-12 14:16 | Dave DeMarle | Note Added: 0023220 | |
2010-11-12 14:16 | Dave DeMarle | Status | backlog => @80@ |
2010-11-12 14:16 | Dave DeMarle | Resolution | open => suspended |
2010-11-12 14:16 | Dave DeMarle | Assigned To | => Dave DeMarle |
2010-11-16 23:31 | Ken Moreland | Note Added: 0023324 | |
2010-11-16 23:31 | Ken Moreland | Status | @80@ => closed |
