0007935 | ParaView | (No Category) | public | 2008-11-04 09:06 | 2016-08-12 09:57 | ||||
Summary | 0007935: Add ability to fix library links in plugin | ||||||||
Description | The current ParaView build has an install make target that, in addition to copying files to the install directory, "fixes" the rpaths for all shared libraries and executables to point to those installed in the ParaView bundle. In order for a plugin to be used with an installed ParaView, its rpaths also need to be mangled in the same way (it magically works when loaded by a running ParaView even if the plugin is not in the bundle directory). | ||||||||
Attached Files | TransformImagePlugin.tar.gz [^] (2,719 bytes) 2010-12-01 12:42 | ||||||||
Relationships | ||||||
(0014025) Ken Moreland (manager) 2008-11-04 09:09 |
Right now I can get around the problem by copying the plugin .dylib file to the bin directory in the ParaView build and running make install of ParaView. The plugin gets picked up with the rest of the libraries and its rpaths are fixed (I just have to go fish it out of the bundle). However, this is a cumbersome process and not one that I want to describe to anyone. Furthermore, it will not be an option when compiling against a ParaView install (once bug 0007348 is complete). |
(0023614) David Partyka (developer) 2010-11-30 22:10 |
This is already fixed. On Linux a make install removes all rpaths as we use a Launcher (bin/paraview -> lib/paraview-x.y/paraview-real). In mac bundles the rpath is fixed up by BundleUtilities. |
(0023617) Alan Scott (manager) 2010-11-30 22:13 |
I believe Dave is correct. If this is still an issue, please reopen this bug. |
(0023643) Ken Moreland (manager) 2010-12-01 12:49 |
I disagree. I do not consider this bug fixed at all. Dave's notes about the rpath being fixed certainly work for plugins located in the ParaView/Plugins source directory. That has been working since before I raised that bug (and in fact the workaround I post in the first note take advantage of this). However, this bug is referencing plugins that are built independent from ParaView like the one I just attached to this report. When you build this plugin, how do you run install on it? How do you run BundleUtilities on it? I know of no way to do this. If it exists, it should be documented on the appropriate Wiki page (http://www.paraview.org/Wiki/Plugin_HowTo [^]) as part of a new heading with a title like "Distributing Built Plugins". |
(0023646) David Partyka (developer) 2010-12-01 14:25 |
Ahh, I see where you are coming from. I presumed you meant plugins built by ParaView. On the Mac I can 'fixup' where the plugin locates it's ParaView/VTK dependencies relatively by replacing absolute paths with @executable/../../Library. On Linux I am less sure. I would be tempted to strip all rpath and require the user to set LD_LIBRARY_PATH appropriately, but that would be a pain for users. I think newer Linux support relative rpath via embedding $Origin/../lib/paraview-3.10/ for each dependency but I will have to research this further. Does this sound like a reasonable approach? |
(0023648) Ken Moreland (manager) 2010-12-01 15:15 |
That sounds good. I admit to be pretty naive about how rpath works everywhere, but it was my understanding that the whole paraview/paraview-real approach was that the paraview stub application would set LD_LIBRARY_PATH to the appropriate lib directory and then call paraview-real, which has all of the rpaths stripped from it. If this is the case, wouldn't it be sufficient to just strip the rpaths from the plugin library? Since it is loaded by the paraview application that already has its LD_LIBRARY_PATH set, it should just find the right libraries, right? |
(0037601) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-11-04 09:06 | Ken Moreland | New Issue | |
2008-11-04 09:06 | Ken Moreland | Relationship added | related to 0007348 |
2008-11-04 09:09 | Ken Moreland | Note Added: 0014025 | |
2009-02-17 14:40 | Utkarsh Ayachit | Category | 3.6 => 3.8 |
2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-11-26 13:41 | David Partyka | Assigned To | => David Partyka |
2010-11-26 13:41 | David Partyka | Status | backlog => tabled |
2010-11-30 22:09 | David Partyka | Note Added: 0023613 | |
2010-11-30 22:10 | David Partyka | Note Deleted: 0023613 | |
2010-11-30 22:10 | David Partyka | Note Added: 0023614 | |
2010-11-30 22:10 | David Partyka | Status | tabled => @80@ |
2010-11-30 22:10 | David Partyka | Fixed in Version | => 3.8 |
2010-11-30 22:10 | David Partyka | Resolution | open => fixed |
2010-11-30 22:13 | Alan Scott | Note Added: 0023617 | |
2010-11-30 22:13 | Alan Scott | Status | @80@ => closed |
2010-12-01 12:42 | Ken Moreland | File Added: TransformImagePlugin.tar.gz | |
2010-12-01 12:49 | Ken Moreland | Note Added: 0023643 | |
2010-12-01 12:49 | Ken Moreland | Status | closed => @20@ |
2010-12-01 12:49 | Ken Moreland | Resolution | fixed => reopened |
2010-12-01 12:50 | Ken Moreland | Target Version | 3.8 => 3.10 |
2010-12-01 14:25 | David Partyka | Note Added: 0023646 | |
2010-12-01 15:15 | Ken Moreland | Note Added: 0023648 | |
2010-12-01 15:15 | Ken Moreland | Status | @20@ => tabled |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037601 | |
2016-08-12 09:57 | Kitware Robot | Fixed in Version | 3.8 => |
2016-08-12 09:57 | Kitware Robot | Resolution | reopened => moved |
