For another project, please consult its home page to locate the current issue tracker.
0007970 | ParaView | (No Category) | public | 2008-11-05 17:21 | 2009-02-17 20:42 | ||||
Reporter | cekees | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0007970: Paraview crashes reading XDMF | ||||||||
Description | In the CVS head paraview crashes loading Iron_Protein.StructuredGrid.Collection.xmf from the kitware paraview course data directory. It also crashes loading some of my own xdmf file that prior versions have read without any trouble. | ||||||||
Attached Files | CMakeCache.txt [^] (125,580 bytes) 2008-11-05 17:21 [Show Content] [Hide Content]# This is the CMakeCache file. # For build in directory: /Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin # It was generated by CMake: /Users/cekees/src/pyadh/darwin_i386_macports/CMake 2.7-20081105.app/Contents/bin/cmake # You can edit this file to change values found and used by cmake. # If you do not want to change any of the values, simply exit the editor. # If you do want to change a value, simply edit, save, and exit the editor. # The syntax for the file is as follows: # KEY:TYPE=VALUE # KEY is the name of a variable in the cache. # TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!. # VALUE is the current value for the KEY. ######################## # EXTERNAL cache entries ######################## //Path to a program. BASH:FILEPATH=/bin/bash //Build the documentation (Doxygen). BUILD_DOCUMENTATION:BOOL=ON //Build ParaView examples. BUILD_EXAMPLES:BOOL=ON //Build ICE-T with shared libraries. BUILD_SHARED_LIBS:BOOL=ON //Build the testing tree. BUILD_TESTING:BOOL=ON //Path to a program. CMAKE_AR:FILEPATH=/usr/bin/ar //For backwards compatibility, what version of CMake commands and // syntax should this version of CMake try to support. CMAKE_BACKWARDS_COMPATIBILITY:STRING=2.4 //Choose the type of build, options are: None(CMAKE_CXX_FLAGS or // CMAKE_C_FLAGS used) Debug Release RelWithDebInfo MinSizeRel. CMAKE_BUILD_TYPE:STRING= //Enable/Disable color output during build. CMAKE_COLOR_MAKEFILE:BOOL=ON //CXX compiler. CMAKE_CXX_COMPILER:FILEPATH=/opt/local/bin/openmpicxx //Flags used by the compiler during all build types. CMAKE_CXX_FLAGS:STRING= //Flags used by the compiler during debug builds. CMAKE_CXX_FLAGS_DEBUG:STRING=-g //Flags used by the compiler during release minsize builds. CMAKE_CXX_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG //Flags used by the compiler during release builds (/MD /Ob1 /Oi // /Ot /Oy /Gs will produce slightly less optimized but smaller // files). CMAKE_CXX_FLAGS_RELEASE:STRING=-O3 -DNDEBUG //Flags used by the compiler during Release with Debug Info builds. CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=-O2 -g //C compiler. CMAKE_C_COMPILER:FILEPATH=/opt/local/bin/openmpicc //Flags used by the compiler during all build types. CMAKE_C_FLAGS:STRING= //Flags used by the compiler during debug builds. CMAKE_C_FLAGS_DEBUG:STRING=-g //Flags used by the compiler during release minsize builds. CMAKE_C_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG //Flags used by the compiler during release builds (/MD /Ob1 /Oi // /Ot /Oy /Gs will produce slightly less optimized but smaller // files). CMAKE_C_FLAGS_RELEASE:STRING=-O3 -DNDEBUG //Flags used by the compiler during Release with Debug Info builds. CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-O2 -g //Flags used by the linker. CMAKE_EXE_LINKER_FLAGS:STRING= //Flags used by the linker during debug builds. CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Fortran compiler. CMAKE_Fortran_COMPILER:FILEPATH=/opt/local/bin/openmpif90 //Use HP pthreads. CMAKE_HP_PTHREADS:BOOL=OFF //Path to a program. CMAKE_INSTALL_NAME_TOOL:FILEPATH=/usr/bin/install_name_tool //Install path prefix, prepended onto install directories. CMAKE_INSTALL_PREFIX:PATH=/Users/cekees/src/pyadh/darwin_i386_macports //Path to a program. CMAKE_LINKER:FILEPATH=/usr/bin/ld //Path to a program. CMAKE_MAKE_PROGRAM:FILEPATH=/usr/bin/make //Flags used by the linker during the creation of modules. CMAKE_MODULE_LINKER_FLAGS:STRING= //Flags used by the linker during debug builds. CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Path to a program. CMAKE_NM:FILEPATH=/usr/bin/nm //Path to a program. CMAKE_OBJCOPY:FILEPATH=CMAKE_OBJCOPY-NOTFOUND //Path to a program. CMAKE_OBJDUMP:FILEPATH=CMAKE_OBJDUMP-NOTFOUND //Build architectures for OSX CMAKE_OSX_ARCHITECTURES:STRING=i386 //isysroot used for universal binary support CMAKE_OSX_SYSROOT:PATH=/Developer/SDKs/MacOSX10.5.sdk //Value Computed by CMake CMAKE_PROJECT_NAME:STATIC=ParaView //Path to a program. CMAKE_RANLIB:FILEPATH=/usr/bin/ranlib //Flags used by the linker during the creation of dll's. CMAKE_SHARED_LINKER_FLAGS:STRING= //Flags used by the linker during debug builds. CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Path to a program. CMAKE_STRIP:FILEPATH=/usr/bin/strip //Thread library used. CMAKE_THREAD_LIBS:STRING=-lpthread //Use the pthreads library. CMAKE_USE_PTHREADS:BOOL=ON //If true, cmake will use relative paths in makefiles and projects. CMAKE_USE_RELATIVE_PATHS:BOOL=OFF //Use sproc libs. CMAKE_USE_SPROC:BOOL=OFF //Use the win32 thread library. CMAKE_USE_WIN32_THREADS:BOOL=OFF //If this value is on, makefiles will be generated without the // .SILENT directive, and all commands will be echoed to the console // during the make. This is useful for debugging only. With Visual // Studio IDE projects all commands are done without /nologo. CMAKE_VERBOSE_MAKEFILE:BOOL=OFF //X11 extra flags. CMAKE_X_CFLAGS:STRING=-I //Libraries and options used in X11 programs. CMAKE_X_LIBS:STRING= //Path to program used to compress files for transfer to the dart // server COMPRESSIONCOMMAND:FILEPATH=/usr/bin/gzip //Path to the coverage program that CTest uses for performing coverage // inspection COVERAGE_COMMAND:FILEPATH=/usr/bin/gcov //Path to a program. CP:FILEPATH=/bin/cp //Enable to build OSX bundles CPACK_BINARY_BUNDLE:BOOL=OFF //Enable to build Debian packages CPACK_BINARY_DEB:BOOL=OFF //Enable to build NSIS packages CPACK_BINARY_NSIS:BOOL=OFF //Enable to build OSX X11 packages CPACK_BINARY_OSXX11:BOOL=OFF //Enable to build PackageMaker packages CPACK_BINARY_PACKAGEMAKER:BOOL=OFF //Enable to build RPM packages CPACK_BINARY_RPM:BOOL=OFF //Enable to build STGZ packages CPACK_BINARY_STGZ:BOOL=OFF //Enable to build TBZ2 packages CPACK_BINARY_TBZ2:BOOL=OFF //Enable to build TGZ packages CPACK_BINARY_TGZ:BOOL=OFF //Enable to build TBZ2 source packages CPACK_SOURCE_TBZ2:BOOL=OFF //Enable to build TGZ source packages CPACK_SOURCE_TGZ:BOOL=OFF //Enable to build TZ source packages CPACK_SOURCE_TZ:BOOL=OFF //Enable to build ZIP source packages CPACK_SOURCE_ZIP:BOOL=OFF //Path to a program. CVSCOMMAND:FILEPATH=/usr/bin/cvs //Options passed to the cvs update command. CVS_UPDATE_OPTIONS:STRING=-d -A -P //Limit of reported errors, -1 reports all. DART_BUILD_ERROR_REPORT_LIMIT:BOOL=OFF //Limit of reported warnings, -1 reports all. DART_BUILD_WARNING_REPORT_LIMIT:BOOL=OFF //If you have Dart installed, where is it located? DART_ROOT:PATH=DART_ROOT-NOTFOUND //Maximum time allowed before CTest will kill the test. DART_TESTING_TIMEOUT:STRING=1500 //Show the actual output of the build, or if off show a . for each // 1024 bytes. DART_VERBOSE_BUILD:BOOL=OFF //Should Dart server send email when build errors are found in // Continuous builds? DELIVER_CONTINUOUS_EMAIL:BOOL=OFF //Use Qt4 DESIRED_QT_VERSION:STRING=4 //Value Computed by CMake DICOMParser_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/DICOMParser //Value Computed by CMake DICOMParser_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/DICOMParser //Build the HTML Help file (CHM). DOCUMENTATION_HTML_HELP:BOOL=ON //Build a compressed tar archive of the HTML doc. DOCUMENTATION_HTML_TARZ:BOOL=ON //Graphviz Dot tool for using Doxygen DOXYGEN_DOT_EXECUTABLE:FILEPATH=/Applications/Doxygen.app/Contents/Resources/dot //Missing description DOXYGEN_DOT_PATH:FILEPATH=/Applications/Doxygen.app/Contents/Resources //Doxygen documentation generation tool (http://www.doxygen.org) DOXYGEN_EXECUTABLE:FILEPATH=/Applications/Doxygen.app/Contents/Resources/doxygen //Build Doxygen of VTK using short file names DOXYGEN_SHORT_NAMES:BOOL=OFF //Path to a program. DOXYTAG:FILEPATH=/Applications/Doxygen.app/Contents/Resources/doxytag //Path to a program. GNUPLOT_EXECUTABLE:FILEPATH=GNUPLOT_EXECUTABLE-NOTFOUND //Path to gunzip executable GUNZIPCOMMAND:FILEPATH=/usr/bin/gunzip //Path to a program. GZIP:FILEPATH=/usr/bin/gzip //Enable datasets larger than memory HDF5_ENABLE_HSIZET:BOOL=ON //Enable parallel build (uses MPI) HDF5_ENABLE_PARALLEL:BOOL=OFF //Compile Stream Virtual File Driver support HDF5_STREAM_VFD:BOOL=ON //Value Computed by CMake ICET_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Utilities/IceT //Build and run the ICE-T tests. ICET_BUILD_TESTING:BOOL=OFF //Value Computed by CMake ICET_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Utilities/IceT //Value Computed by CMake ICE_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Utilities/Xdmf2/Ice //Path to a file. ICE_HAVE_FCNTL:PATH=/usr/include //Path to a file. ICE_HAVE_MMAN:PATH=/usr/include/sys //Path to a file. ICE_HAVE_NETINET:PATH=/usr/include/netinet //Value Computed by CMake ICE_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Utilities/Xdmf2/Ice //Specify if Qt documentation should be linked to. INCLUDE_QT_DOCUMENTATION:BOOL=ON //Path to java command, used by the Dart server to create html. JAVACOMMAND:FILEPATH=/usr/bin/java //Value Computed by CMake KWCommon_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Common/KWCommon //Enable testing in KWCommon (if BUILD_TESTING is ON as well). KWCommon_BUILD_TESTING:BOOL=ON //Dependencies for the target KWCommon_LIB_DEPENDS:STATIC=general;vtkCommon;general;vtksys; //Value Computed by CMake KWCommon_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Common/KWCommon //Command used to build entire project from the command line. MAKECOMMAND:STRING=/usr/bin/make -i //Path to the memory checking command, used for memory error detection. MEMORYCHECK_COMMAND:FILEPATH=MEMORYCHECK_COMMAND-NOTFOUND //File that contains suppressions for the memory checker MEMORYCHECK_SUPPRESSIONS_FILE:FILEPATH= //Executable for running MPI programs. MPIEXEC:FILEPATH=/opt/local/bin/openmpiexec //Maximum number of processors available to run MPI applications. MPIEXEC_MAX_NUMPROCS:STRING=2 //Flag used by MPI to specify the number of processes for MPIEXEC; // the next option will be the number of processes. MPIEXEC_NUMPROC_FLAG:STRING=-np //These flags will come after all flags given to MPIEXEC. MPIEXEC_POSTFLAGS:STRING= //These flags will be directly before the executable that is being // run by MPIEXEC. MPIEXEC_PREFLAGS:STRING= //MPI compiler. Used only to detect MPI compilation flags. MPI_COMPILER:FILEPATH=/opt/local/bin/openmpicxx //MPI compilation flags MPI_COMPILE_FLAGS:STRING=-D_REENTRANT //Extra MPI libraries to link against MPI_EXTRA_LIBRARY:STRING=/opt/local/lib/libmpi.dylib;/opt/local/lib/libopen-rte.dylib;/opt/local/lib/libopen-pal.dylib;/usr/lib/libutil.dylib //MPI include path MPI_INCLUDE_PATH:STRING=/opt/local/include //MPI library to link against MPI_LIBRARY:FILEPATH=/opt/local/lib/libmpi_cxx.dylib //MPI linking flags MPI_LINK_FLAGS:STRING=-Wl,-u,_munmap -Wl,-multiply_defined,suppress //Path to a program. MV:FILEPATH=/bin/mv //Value Computed by CMake MaterialLibrary_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/MaterialLibrary //Value Computed by CMake MaterialLibrary_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/MaterialLibrary //Include for OpenGL on OSX OPENGL_INCLUDE_DIR:PATH=/System/Library/Frameworks/OpenGL.framework //OpenGL lib for OSX OPENGL_gl_LIBRARY:FILEPATH=/System/Library/Frameworks/OpenGL.framework //AGL lib for OSX OPENGL_glu_LIBRARY:FILEPATH=/System/Library/Frameworks/AGL.framework //Path to a file. OPENSSL_INCLUDE_DIR:PATH=/usr/include //Path to a library. OPENSSL_LIBRARIES:FILEPATH=/usr/lib/libssl.dylib //Build ParaView with enforced secure connection (--connect-id) PARAVIEW_ALWAYS_SECURE_CONNECTION:BOOL=OFF //Build default ParaView Client PARAVIEW_BUILD_Client:BOOL=ON //Build OverView informatics application PARAVIEW_BUILD_OverView:BOOL=OFF //Build Array PARAVIEW_BUILD_PLUGIN_Array:BOOL=OFF //Build ChartViewFrame PARAVIEW_BUILD_PLUGIN_ChartViewFrame:BOOL=OFF //Build ClientAttributeView PARAVIEW_BUILD_PLUGIN_ClientAttributeView:BOOL=OFF //Build ClientChartView PARAVIEW_BUILD_PLUGIN_ClientChartView:BOOL=OFF //Build ClientGeoView PARAVIEW_BUILD_PLUGIN_ClientGeoView:BOOL=OFF //Build ClientGraphView PARAVIEW_BUILD_PLUGIN_ClientGraphView:BOOL=OFF //Build ClientHierarchyView PARAVIEW_BUILD_PLUGIN_ClientHierarchyView:BOOL=OFF //Build ClientRecordView PARAVIEW_BUILD_PLUGIN_ClientRecordView:BOOL=OFF //Build ClientTableView PARAVIEW_BUILD_PLUGIN_ClientTableView:BOOL=OFF //Build CommonToolbar PARAVIEW_BUILD_PLUGIN_CommonToolbar:BOOL=OFF //Build Comsmology Filters PARAVIEW_BUILD_PLUGIN_CosmoFilters:BOOL=OFF //Build GraphLayoutFilterPanel PARAVIEW_BUILD_PLUGIN_GraphLayoutFilterPanel:BOOL=OFF //Build Infovis PARAVIEW_BUILD_PLUGIN_Infovis:BOOL=OFF //Build Prism PARAVIEW_BUILD_PLUGIN_Prism:BOOL=ON //Build SQLDatabaseGraphSourcePanel PARAVIEW_BUILD_PLUGIN_SQLDatabaseGraphSourcePanel:BOOL=OFF //Build SQLDatabaseTableSourcePanel PARAVIEW_BUILD_PLUGIN_SQLDatabaseTableSourcePanel:BOOL=OFF //Build SplitTableFieldPanel PARAVIEW_BUILD_PLUGIN_SplitTableFieldPanel:BOOL=OFF //Build StatisticsToolbar PARAVIEW_BUILD_PLUGIN_StatisticsToolbar:BOOL=OFF //Build TableToGraphPanel PARAVIEW_BUILD_PLUGIN_TableToGraphPanel:BOOL=OFF //Build TableToSparseArrayPanel PARAVIEW_BUILD_PLUGIN_TableToSparseArrayPanel:BOOL=OFF //Build ThresholdTablePanel PARAVIEW_BUILD_PLUGIN_ThresholdTablePanel:BOOL=OFF //Build ParaView Qt Client. This requires Qt. PARAVIEW_BUILD_QT_GUI:BOOL=ON //Build ParaView against the PVAdaptor private source library. // Requires Kitware License PARAVIEW_BUILD_WITH_ADAPTOR:BOOL=OFF //Path to a file. PARAVIEW_DATA_ROOT:PATH=PARAVIEW_DATA_ROOT-NOTFOUND //Build ParaView with Floating Point Exceptions turned on PARAVIEW_ENABLE_FPE:BOOL=OFF //Enable/Disable Python scripting support. PARAVIEW_ENABLE_PYTHON:BOOL=ON //Build ParaView with all experimental options PARAVIEW_EXPERIMENTAL_USER:BOOL=OFF //Extra modules that ParaView will try to import. The modules have // to provide ParaViewImport.cmake file. PARAVIEW_EXTRA_EXTERNAL_MODULES:STRING= //Build Python Testing support if PARAVIEW_ENABLE_PYTHON is ON PARAVIEW_TESTING_WITH_PYTHON:BOOL=ON //Use IceT multi display manager PARAVIEW_USE_ICE_T:BOOL=ON //Build ParaView with MPI support PARAVIEW_USE_MPI:BOOL=ON //Use SILO library PARAVIEW_USE_SILO:BOOL=OFF //Use system installed HDF5 PARAVIEW_USE_SYSTEM_HDF5:BOOL=OFF //Path to a program. PERL_EXECUTABLE:FILEPATH=/usr/bin/perl //Value Computed by CMake PQGUI_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Qt //Value Computed by CMake PQGUI_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Qt //Value Computed by CMake PVFilters_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Servers/Filters //Value Computed by CMake PVFilters_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Servers/Filters //Value Computed by CMake PVServerCommon_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Servers/Common //Value Computed by CMake PVServerCommon_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Servers/Common //Value Computed by CMake PVServer_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Servers //Value Computed by CMake PVServer_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Servers //Value Computed by CMake PVServers_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Servers/Executables //Value Computed by CMake PVServers_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Servers/Executables //Command to run after a failed test to cleanup processes. Example: // "killall -9 rsh paraview" PV_TEST_CLEAN_COMMAND:STRING= //Node which serves as the client node, used to connect from the // server side in reverse connection mode. PV_TEST_CLIENT:STRING=localhost //Command to run before a test begins. Multiple commands are separated // by ';'. PV_TEST_INIT_COMMAND:STRING= //Node which serves as the root node for the cluster when testing // in parallel PV_TEST_SERVER_ROOT:STRING=localhost //Purposely empty: work around CMake FindPythonLibs bug PYTHON_DEBUG_LIBRARY:FILEPATH= //Add module vtkCommonPython PYTHON_ENABLE_MODULE_vtkCommonPython:BOOL=ON //Add module vtkFilteringPython PYTHON_ENABLE_MODULE_vtkFilteringPython:BOOL=ON //Add module vtkGenericFilteringPython PYTHON_ENABLE_MODULE_vtkGenericFilteringPython:BOOL=ON //Add module vtkGeovisPython PYTHON_ENABLE_MODULE_vtkGeovisPython:BOOL=ON //Add module vtkGraphicsPython PYTHON_ENABLE_MODULE_vtkGraphicsPython:BOOL=ON //Add module vtkHybridPython PYTHON_ENABLE_MODULE_vtkHybridPython:BOOL=ON //Add module vtkIOPython PYTHON_ENABLE_MODULE_vtkIOPython:BOOL=ON //Add module vtkImagingPython PYTHON_ENABLE_MODULE_vtkImagingPython:BOOL=ON //Add module vtkInfovisPython PYTHON_ENABLE_MODULE_vtkInfovisPython:BOOL=ON //Add module vtkPVServerCommonPython PYTHON_ENABLE_MODULE_vtkPVServerCommonPython:BOOL=ON //Add module vtkPVServerManagerPython PYTHON_ENABLE_MODULE_vtkPVServerManagerPython:BOOL=ON //Add module vtkParallelPython PYTHON_ENABLE_MODULE_vtkParallelPython:BOOL=ON //Add module vtkRenderingPython PYTHON_ENABLE_MODULE_vtkRenderingPython:BOOL=ON //Add module vtkViewsPython PYTHON_ENABLE_MODULE_vtkViewsPython:BOOL=ON //Add module vtkVolumeRenderingPython PYTHON_ENABLE_MODULE_vtkVolumeRenderingPython:BOOL=ON //Add module vtkWidgetsPython PYTHON_ENABLE_MODULE_vtkWidgetsPython:BOOL=ON //Path to a program. PYTHON_EXECUTABLE:FILEPATH=/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework/Versions/Current/bin/python //Extra libraries to link when linking to python (such as "z" for // zlib). Separate multiple libraries with semicolons. PYTHON_EXTRA_LIBS:STRING= //Path to a file. PYTHON_INCLUDE_PATH:PATH=/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework/Headers //Path to a library. PYTHON_LIBRARY:FILEPATH=/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework //Add module vtkCommonPython shared PYTHON_MODULE_vtkCommonPython_BUILD_SHARED:BOOL=ON //Add module vtkFilteringPython shared PYTHON_MODULE_vtkFilteringPython_BUILD_SHARED:BOOL=ON //Add module vtkGenericFilteringPython shared PYTHON_MODULE_vtkGenericFilteringPython_BUILD_SHARED:BOOL=ON //Add module vtkGeovisPython shared PYTHON_MODULE_vtkGeovisPython_BUILD_SHARED:BOOL=ON //Add module vtkGraphicsPython shared PYTHON_MODULE_vtkGraphicsPython_BUILD_SHARED:BOOL=ON //Add module vtkHybridPython shared PYTHON_MODULE_vtkHybridPython_BUILD_SHARED:BOOL=ON //Add module vtkIOPython shared PYTHON_MODULE_vtkIOPython_BUILD_SHARED:BOOL=ON //Add module vtkImagingPython shared PYTHON_MODULE_vtkImagingPython_BUILD_SHARED:BOOL=ON //Add module vtkInfovisPython shared PYTHON_MODULE_vtkInfovisPython_BUILD_SHARED:BOOL=ON //Add module vtkPVServerCommonPython shared PYTHON_MODULE_vtkPVServerCommonPython_BUILD_SHARED:BOOL=ON //Add module vtkPVServerManagerPython shared PYTHON_MODULE_vtkPVServerManagerPython_BUILD_SHARED:BOOL=ON //Add module vtkParallelPython shared PYTHON_MODULE_vtkParallelPython_BUILD_SHARED:BOOL=ON //Add module vtkRenderingPython shared PYTHON_MODULE_vtkRenderingPython_BUILD_SHARED:BOOL=ON //Add module vtkViewsPython shared PYTHON_MODULE_vtkViewsPython_BUILD_SHARED:BOOL=ON //Add module vtkVolumeRenderingPython shared PYTHON_MODULE_vtkVolumeRenderingPython_BUILD_SHARED:BOOL=ON //Add module vtkWidgetsPython shared PYTHON_MODULE_vtkWidgetsPython_BUILD_SHARED:BOOL=ON //Utility library needed for vtkpython PYTHON_UTIL_LIBRARY:FILEPATH=/usr/lib/libutil.dylib //Value Computed by CMake ParaView_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin //Value Computed by CMake ParaView_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs //Value Computed by CMake PrismClientPlugin_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Plugins/PrismPlugins/Client //Dependencies for the target PrismClientPlugin_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManager; //Value Computed by CMake PrismClientPlugin_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Plugins/PrismPlugins/Client //Dependencies for the target PrismServerPlugin_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //path to assistant executable for documentation QT_ASSISTANT_EXECUTABLE:FILEPATH=/Developer/Tools/Qt/assistant.app/Contents/MacOS/assistant //Path to a program. QT_DBUSCPP2XML_EXECUTABLE:FILEPATH=QT_DBUSCPP2XML_EXECUTABLE-NOTFOUND //Path to a program. QT_DBUSXML2CPP_EXECUTABLE:FILEPATH=QT_DBUSXML2CPP_EXECUTABLE-NOTFOUND //The location of the Qt docs QT_DOC_DIR:PATH=/Developer/Documentation/Qt //Qt library dir QT_LIBRARY_DIR:PATH=/Library/Frameworks //Path to a program. QT_LRELEASE_EXECUTABLE:FILEPATH=/Developer/Tools/Qt/lrelease //Path to a program. QT_LUPDATE_EXECUTABLE:FILEPATH=/Developer/Tools/Qt/lupdate //The location of the Qt mkspecs containing qconfig.pri QT_MKSPECS_DIR:PATH=/usr/local/Qt4.3/mkspecs //Path to a program. QT_MOC_EXECUTABLE:FILEPATH=/Developer/Tools/Qt/moc //Path to a file. QT_PHONON_INCLUDE_DIR:PATH=QT_PHONON_INCLUDE_DIR-NOTFOUND //Path to a library. QT_PHONON_LIBRARY_DEBUG:FILEPATH=QT_PHONON_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_PHONON_LIBRARY_RELEASE:FILEPATH=QT_PHONON_LIBRARY_RELEASE-NOTFOUND //The location of the Qt plugins QT_PLUGINS_DIR:PATH=/Developer/Applications/Qt/plugins //Path to a program. QT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin/qmake //Path to a file. QT_QT3SUPPORT_INCLUDE_DIR:PATH=/Library/Frameworks/Qt3Support.framework/Headers //The Qt QT3SUPPORT library QT_QT3SUPPORT_LIBRARY:FILEPATH=/Library/Frameworks/Qt3Support.framework //Path to a library. QT_QT3SUPPORT_LIBRARY_DEBUG:FILEPATH=QT_QT3SUPPORT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QT3SUPPORT_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/Qt3Support.framework //Path to a file. QT_QTASSISTANTCLIENT_INCLUDE_DIR:PATH=/Library/Frameworks/QtAssistant.framework/Headers //Path to a library. QT_QTASSISTANTCLIENT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTASSISTANTCLIENT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTASSISTANT_INCLUDE_DIR:PATH=/Library/Frameworks/QtAssistant.framework/Headers //The Qt QTASSISTANT library QT_QTASSISTANT_LIBRARY:FILEPATH=/Library/Frameworks/QtAssistant.framework //Path to a library. QT_QTASSISTANT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTASSISTANT_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/QtAssistant.framework //Path to a library. QT_QTCLUCENE_LIBRARY_DEBUG:FILEPATH=QT_QTCLUCENE_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTCLUCENE_LIBRARY_RELEASE:FILEPATH=QT_QTCLUCENE_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTCORE_INCLUDE_DIR:PATH=/Library/Frameworks/QtCore.framework/Headers //The Qt QTCORE library QT_QTCORE_LIBRARY:FILEPATH=/Library/Frameworks/QtCore.framework //Path to a library. QT_QTCORE_LIBRARY_DEBUG:FILEPATH=QT_QTCORE_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTCORE_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/QtCore.framework //Path to a file. QT_QTDBUS_INCLUDE_DIR:PATH=QT_QTDBUS_INCLUDE_DIR-NOTFOUND //Path to a library. QT_QTDBUS_LIBRARY_DEBUG:FILEPATH=QT_QTDBUS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDBUS_LIBRARY_RELEASE:FILEPATH=QT_QTDBUS_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR:PATH=/Library/Frameworks/QtDesigner.framework/Headers //The Qt QTDESIGNERCOMPONENTS library QT_QTDESIGNERCOMPONENTS_LIBRARY:FILEPATH=/Library/Frameworks/QtDesignerComponents.framework //Path to a library. QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/QtDesignerComponents.framework //Path to a file. QT_QTDESIGNER_INCLUDE_DIR:PATH=/Library/Frameworks/QtDesigner.framework/Headers //The Qt QTDESIGNER library QT_QTDESIGNER_LIBRARY:FILEPATH=/Library/Frameworks/QtDesigner.framework //Path to a library. QT_QTDESIGNER_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNER_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDESIGNER_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/QtDesigner.framework //Path to a file. QT_QTGUI_INCLUDE_DIR:PATH=/Library/Frameworks/QtGui.framework/Headers //The Qt QTGUI library QT_QTGUI_LIBRARY:FILEPATH=/Library/Frameworks/QtGui.framework //Path to a library. QT_QTGUI_LIBRARY_DEBUG:FILEPATH=QT_QTGUI_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTGUI_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/QtGui.framework //Path to a file. QT_QTHELP_INCLUDE_DIR:PATH=QT_QTHELP_INCLUDE_DIR-NOTFOUND //Path to a library. QT_QTHELP_LIBRARY_DEBUG:FILEPATH=QT_QTHELP_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTHELP_LIBRARY_RELEASE:FILEPATH=QT_QTHELP_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTMOTIF_INCLUDE_DIR:PATH=QT_QTMOTIF_INCLUDE_DIR-NOTFOUND //Path to a library. QT_QTMOTIF_LIBRARY_DEBUG:FILEPATH=QT_QTMOTIF_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTMOTIF_LIBRARY_RELEASE:FILEPATH=QT_QTMOTIF_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTNETWORK_INCLUDE_DIR:PATH=/Library/Frameworks/QtNetwork.framework/Headers //The Qt QTNETWORK library QT_QTNETWORK_LIBRARY:FILEPATH=/Library/Frameworks/QtNetwork.framework //Path to a library. QT_QTNETWORK_LIBRARY_DEBUG:FILEPATH=QT_QTNETWORK_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTNETWORK_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/QtNetwork.framework //Path to a file. QT_QTNSPLUGIN_INCLUDE_DIR:PATH=QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND //Path to a library. QT_QTNSPLUGIN_LIBRARY_DEBUG:FILEPATH=QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTNSPLUGIN_LIBRARY_RELEASE:FILEPATH=QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTOPENGL_INCLUDE_DIR:PATH=/Library/Frameworks/QtOpenGL.framework/Headers //The Qt QTOPENGL library QT_QTOPENGL_LIBRARY:FILEPATH=/Library/Frameworks/QtOpenGL.framework //Path to a library. QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=QT_QTOPENGL_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/QtOpenGL.framework //Path to a file. QT_QTSCRIPT_INCLUDE_DIR:PATH=/Library/Frameworks/QtScript.framework/Headers //The Qt QTSCRIPT library QT_QTSCRIPT_LIBRARY:FILEPATH=/Library/Frameworks/QtScript.framework //Path to a library. QT_QTSCRIPT_LIBRARY_DEBUG:FILEPATH=QT_QTSCRIPT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSCRIPT_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/QtScript.framework //Path to a file. QT_QTSQL_INCLUDE_DIR:PATH=/Library/Frameworks/QtSql.framework/Headers //The Qt QTSQL library QT_QTSQL_LIBRARY:FILEPATH=/Library/Frameworks/QtSql.framework //Path to a library. QT_QTSQL_LIBRARY_DEBUG:FILEPATH=QT_QTSQL_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSQL_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/QtSql.framework //Path to a file. QT_QTSVG_INCLUDE_DIR:PATH=/Library/Frameworks/QtSvg.framework/Headers //The Qt QTSVG library QT_QTSVG_LIBRARY:FILEPATH=/Library/Frameworks/QtSvg.framework //Path to a library. QT_QTSVG_LIBRARY_DEBUG:FILEPATH=QT_QTSVG_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSVG_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/QtSvg.framework //Path to a file. QT_QTTEST_INCLUDE_DIR:PATH=/Library/Frameworks/QtTest.framework/Headers //The Qt QTTEST library QT_QTTEST_LIBRARY:FILEPATH=/Library/Frameworks/QtTest.framework //Path to a library. QT_QTTEST_LIBRARY_DEBUG:FILEPATH=QT_QTTEST_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTTEST_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/QtTest.framework //Path to a file. QT_QTUITOOLS_INCLUDE_DIR:PATH=/usr/include/QtUiTools //The Qt QTUITOOLS library QT_QTUITOOLS_LIBRARY:FILEPATH=/usr/lib/libQtUiTools.a //Path to a library. QT_QTUITOOLS_LIBRARY_DEBUG:FILEPATH=QT_QTUITOOLS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTUITOOLS_LIBRARY_RELEASE:FILEPATH=/usr/lib/libQtUiTools.a //Path to a file. QT_QTWEBKIT_INCLUDE_DIR:PATH=QT_QTWEBKIT_INCLUDE_DIR-NOTFOUND //Path to a library. QT_QTWEBKIT_LIBRARY_DEBUG:FILEPATH=QT_QTWEBKIT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTWEBKIT_LIBRARY_RELEASE:FILEPATH=QT_QTWEBKIT_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTXMLPATTERNS_INCLUDE_DIR:PATH=QT_QTXMLPATTERNS_INCLUDE_DIR-NOTFOUND //Path to a library. QT_QTXMLPATTERNS_LIBRARY_DEBUG:FILEPATH=QT_QTXMLPATTERNS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTXMLPATTERNS_LIBRARY_RELEASE:FILEPATH=QT_QTXMLPATTERNS_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTXML_INCLUDE_DIR:PATH=/Library/Frameworks/QtXml.framework/Headers //The Qt QTXML library QT_QTXML_LIBRARY:FILEPATH=/Library/Frameworks/QtXml.framework //Path to a library. QT_QTXML_LIBRARY_DEBUG:FILEPATH=QT_QTXML_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTXML_LIBRARY_RELEASE:FILEPATH=/Library/Frameworks/QtXml.framework //Path to a program. QT_RCC_EXECUTABLE:FILEPATH=/Developer/Tools/Qt/rcc //Path to a program. QT_UIC3_EXECUTABLE:FILEPATH=/Developer/Tools/Qt/uic3 //Path to a program. QT_UIC_EXECUTABLE:FILEPATH=/Developer/Tools/Qt/uic //Set to ON if Qt build uses frameworks. QT_USE_FRAMEWORKS:BOOL=ON //Path to a library. QT_ZLIB_LIBRARY:FILEPATH=/usr/lib/libz.dylib //Dependencies for the target QVTKWidgetPlugin_LIB_DEPENDS:STATIC=general;/Library/Frameworks/QtCore.framework;general;/Library/Frameworks/QtGui.framework; //Dependencies for the target QVTK_LIB_DEPENDS:STATIC=general;/Library/Frameworks/QtGui.framework;general;-framework Carbon;general;-framework AppKit;general;/Library/Frameworks/QtSql.framework;general;/Library/Frameworks/QtCore.framework;general;/usr/lib/libz.dylib;general;-framework ApplicationServices;general;vtkRendering;general;vtkGraphics;general;vtkImaging;general;vtkCommon;general;vtkQtChart;general;vtkViews; //Value Computed by CMake QtChart_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Qt/Chart //Dependencies for the target QtChart_LIB_DEPENDS:STATIC=general;/usr/lib/libQtUiTools.a;general;/Library/Frameworks/QtGui.framework;general;-framework Carbon;general;-framework AppKit;general;/Library/Frameworks/QtXml.framework;general;/Library/Frameworks/QtCore.framework;general;/usr/lib/libz.dylib;general;-framework ApplicationServices; //Value Computed by CMake QtChart_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Qt/Chart //Value Computed by CMake QtPython_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Qt/Python //Dependencies for the target QtPython_LIB_DEPENDS:STATIC=general;pqCore;general;pqWidgets;general;/usr/lib/libQtUiTools.a;general;/Library/Frameworks/QtGui.framework;general;-framework Carbon;general;-framework AppKit;general;/Library/Frameworks/QtXml.framework;general;/Library/Frameworks/QtCore.framework;general;/usr/lib/libz.dylib;general;-framework ApplicationServices;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework;general;vtkPVPythonInterpretor; //Value Computed by CMake QtPython_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Qt/Python //Value Computed by CMake QtTesting_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Qt/Testing //Dependencies for the target QtTesting_LIB_DEPENDS:STATIC=general;/usr/lib/libQtUiTools.a;general;/Library/Frameworks/QtGui.framework;general;-framework Carbon;general;-framework AppKit;general;/Library/Frameworks/QtXml.framework;general;/Library/Frameworks/QtCore.framework;general;/usr/lib/libz.dylib;general;-framework ApplicationServices;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework;general;/usr/lib/libutil.dylib; //Value Computed by CMake QtTesting_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Qt/Testing //Value Computed by CMake QtWidgets_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Qt/Widgets //Value Computed by CMake QtWidgets_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Qt/Widgets //Path to a program. RM:FILEPATH=/bin/rm //Path to scp command, used by CTest for submitting results to // a Dart server SCPCOMMAND:FILEPATH=/usr/bin/scp //Name of the computer/site where compile is being run SITE:STRING=chris-keess-macbook-pro.local //Path to a program. SVNCOMMAND:FILEPATH=/usr/bin/svn //Value Computed by CMake ServerManager_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Servers/ServerManager //Value Computed by CMake ServerManager_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Servers/ServerManager //Path to a program. TAR:FILEPATH=/usr/bin/tar //Build the 2007 Verdict User Manual VERDICT_BUILD_DOC:BOOL=OFF //Should tests of the VERDICT library be built? VERDICT_ENABLE_TESTING:BOOL=OFF //Mangle verdict names for inclusion in a larger library? VERDICT_MANGLE:BOOL=ON //VTK requires the verdict prefix to be vtk VERDICT_MANGLE_PREFIX:STRING=vtk //VTK requires doubles VERDICT_USE_FLOAT:BOOL=OFF //Path to a library. VLI_LIBRARY_FOR_VP1000:FILEPATH=VLI_LIBRARY_FOR_VP1000-NOTFOUND //Value Computed by CMake VTKCS_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Utilities/VTKClientServer //Value Computed by CMake VTKCS_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Utilities/VTKClientServer //Value Computed by CMake VTKEXPAT_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/vtkexpat //Value Computed by CMake VTKEXPAT_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/vtkexpat //Value Computed by CMake VTKFREETYPE_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/vtkfreetype //Value Computed by CMake VTKFREETYPE_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/vtkfreetype //Value Computed by CMake VTKFTGL_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/ftgl //Value Computed by CMake VTKFTGL_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/ftgl //Value Computed by CMake VTKHDF5_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Utilities/hdf5 //Value Computed by CMake VTKHDF5_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Utilities/hdf5 //Value Computed by CMake VTKJPEG_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/vtkjpeg //Value Computed by CMake VTKJPEG_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/vtkjpeg //Value Computed by CMake VTKNETCDF_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/vtknetcdf //Value Computed by CMake VTKNETCDF_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/vtknetcdf //Value Computed by CMake VTKPNG_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/vtkpng //Value Computed by CMake VTKPNG_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/vtkpng //Value Computed by CMake VTKPythonWrapping_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Utilities/VTKPythonWrapping //Value Computed by CMake VTKPythonWrapping_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Utilities/VTKPythonWrapping //Value Computed by CMake VTKTIFF_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/vtktiff //Value Computed by CMake VTKTIFF_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/vtktiff //Value Computed by CMake VTKZLIB_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/vtkzlib //Value Computed by CMake VTKZLIB_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/vtkzlib //Path to a program. VTK_APPLE_RESOURCE:FILEPATH=/usr/bin/Rez //Value Computed by CMake VTK_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK //Path to a file. VTK_DATA_ROOT:PATH=VTK_DATA_ROOT-NOTFOUND //Build leak checking support into VTK. VTK_DEBUG_LEAKS:BOOL=OFF //Location of the OpenGL extensions header file (glext.h). VTK_GLEXT_FILE:FILEPATH=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/ParseOGLExt/headers/glext.h //Location of the GLX extensions header file (glxext.h). VTK_GLXEXT_FILE:FILEPATH=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/ParseOGLExt/headers/glxext.h //Directory in which the VTK Qt plugin is placed during installation. VTK_INSTALL_QT_PLUGIN_DIR:STRING=${CMAKE_INSTALL_PREFIX}${VTK_INSTALL_QT_DIR} //Remove all legacy code completely. VTK_LEGACY_REMOVE:BOOL=OFF //Silence all legacy code messages. VTK_LEGACY_SILENT:BOOL=OFF //; separated directories to search for materials/shaders VTK_MATERIALS_DIRS:STRING=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/MaterialLibrary/Repository //Path to a program. VTK_MPIRUN_EXE:FILEPATH=/opt/local/bin/openmpiexec //Maximum number of processors available to run parallel applications. // (see /Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/CMakeLists.txt // for more info.) VTK_MPI_MAX_NUMPROCS:STRING=2 //Flag used by mpi to specify the number of processes, the next // option will be the number of processes. (see /Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/CMakeLists.txt // for more info.) VTK_MPI_NUMPROC_FLAG:STRING=-np //These flags will come after all flags given to MPIRun.(see /Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/CMakeLists.txt // for more info.) VTK_MPI_POSTFLAGS:STRING= //These flags will be directly before the executable that is being // run by VTK_MPIRUN_EXE. (see /Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/CMakeLists.txt // for more info.) VTK_MPI_PREFLAGS:STRING= //These flags will be directly before the number of processess // flag (see /Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/CMakeLists.txt // for more info.) VTK_MPI_PRENUMPROC_FLAGS:STRING= //The opengl library being used supports off screen Mesa calls. VTK_OPENGL_HAS_OSMESA:BOOL=OFF //Value Computed by CMake VTK_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK //VTK tests call vtkFloatingPointExceptions::Enable() VTK_TESTING_USE_FPE:BOOL=ON //Build VTK with 64 bit ids VTK_USE_64BIT_IDS:BOOL=OFF //Use Boost libraries for graph algorithms - www.boost.org. VTK_USE_BOOST:BOOL=OFF //Build classes using Carbon API. VTK_USE_CARBON:BOOL=ON //Build pixel and vertex shader support for Cg. VTK_USE_CG_SHADERS:BOOL=OFF //Build classes using Cocoa API. VTK_USE_COCOA:BOOL=OFF //Turn this option off and tests and warning/error macros will // not popup windows VTK_USE_DISPLAY:BOOL=ON //If the FFMPEG library is available, should VTK use it for saving // .avi animation files? VTK_USE_FFMPEG_ENCODER:BOOL=OFF //Build the vtkGeovis kit. Needed for performing geographic visualization. VTK_USE_GEOVIS:BOOL=ON //Build pixel and vertex shader support for GLSL. VTK_USE_GLSL_SHADERS:BOOL=ON //Build VTK with GUI Support VTK_USE_GUISUPPORT:BOOL=ON //Build the vtkInfovis kit. Needed for performing information // visualization. VTK_USE_INFOVIS:BOOL=ON //Use mangled Mesa with OpenGL. VTK_USE_MANGLED_MESA:BOOL=OFF //Build metaio VTK_USE_METAIO:BOOL=ON //Enable use of the patented mpeg2 library. You are solely responsible // for any legal issues associated with using patented code in // your software. VTK_USE_MPEG2_ENCODER:BOOL=OFF //Build the MySQL driver for vtkSQLDatabase. VTK_USE_MYSQL:BOOL=OFF //Add support for arbitrary-dimension sparse and dense arrays. VTK_USE_N_WAY_ARRAYS:BOOL=OFF //Build the ODBC database interface VTK_USE_ODBC:BOOL=OFF //Build the PostgreSQL driver for vtkSQLDatabase. VTK_USE_POSTGRES:BOOL=OFF //Build QVTK widget and plugin for Qt VTK_USE_QVTK:BOOL=ON //Use QtOpenGL in QVTK VTK_USE_QVTK_QTOPENGL:BOOL=OFF //Build shared libraries with rpath. This makes it easy to run // executables from the build tree when using shared libraries, // but removes install support. VTK_USE_RPATH:BOOL=ON //Use the system's expat library. VTK_USE_SYSTEM_EXPAT:BOOL=OFF //Use the system's freetype library. VTK_USE_SYSTEM_FREETYPE:BOOL=OFF //Use the system's jpeg library. VTK_USE_SYSTEM_JPEG:BOOL=OFF //Use the system's libxml2 library. VTK_USE_SYSTEM_LIBXML2:BOOL=OFF //Use the system's png library. VTK_USE_SYSTEM_PNG:BOOL=OFF //Use the system's tiff library. VTK_USE_SYSTEM_TIFF:BOOL=OFF //Use the system's zlib library. VTK_USE_SYSTEM_ZLIB:BOOL=OFF //Build VTK with Tk support VTK_USE_TK:BOOL=OFF //Build the vtkViews kit. Needed for creating packaged and linked // views. VTK_USE_VIEWS:BOOL=ON //Enable support for VolumePro 1000. VTK_USE_VOLUMEPRO_1000:BOOL=OFF //Location of the WGL extensions header file (wglext.h). VTK_WGLEXT_FILE:FILEPATH=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/ParseOGLExt/headers/wglext.h //Path to a file. VTK_WRAP_HINTS:FILEPATH=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Wrapping/hints //Path to a program. WGET_EXECUTABLE:FILEPATH=WGET_EXECUTABLE-NOTFOUND //XDMF has Network Distributed Global Memory (NDGM) XDMF_HAS_NDGM:BOOL=OFF //Path to a file. XDMF_HAVE_FCNTL:PATH=/usr/include //Path to a file. XDMF_HAVE_MMAN:PATH=/usr/include/sys //Path to a file. XDMF_HAVE_NETINET:PATH=/usr/include/netinet //Build Support for MySQL DataItems XDMF_USE_MYSQL:BOOL=OFF //Value Computed by CMake Xdmf_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Utilities/Xdmf2 //Dependencies for the target Xdmf_LIB_DEPENDS:STATIC=general;/opt/local/lib/libmpi.dylib;general;/opt/local/lib/libopen-rte.dylib;general;/opt/local/lib/libopen-pal.dylib;general;/usr/lib/libutil.dylib;general;/opt/local/lib/libmpi_cxx.dylib;general;vtkhdf5;general;vtklibxml2; //Value Computed by CMake Xdmf_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Utilities/Xdmf2 //Dependencies for the target icet_LIB_DEPENDS:STATIC=general;/System/Library/Frameworks/AGL.framework;general;/System/Library/Frameworks/OpenGL.framework;general;/opt/local/lib/libmpi_cxx.dylib;general;/opt/local/lib/libmpi.dylib;general;/opt/local/lib/libopen-rte.dylib;general;/opt/local/lib/libopen-pal.dylib;general;/usr/lib/libutil.dylib; //Dependencies for the target icet_mpi_LIB_DEPENDS:STATIC=general;/System/Library/Frameworks/AGL.framework;general;/System/Library/Frameworks/OpenGL.framework;general;/opt/local/lib/libmpi_cxx.dylib;general;/opt/local/lib/libmpi.dylib;general;/opt/local/lib/libopen-rte.dylib;general;/opt/local/lib/libopen-pal.dylib;general;/usr/lib/libutil.dylib;general;icet; //Dependencies for the target icet_strategies_LIB_DEPENDS:STATIC=general;/System/Library/Frameworks/AGL.framework;general;/System/Library/Frameworks/OpenGL.framework;general;/opt/local/lib/libmpi_cxx.dylib;general;/opt/local/lib/libmpi.dylib;general;/opt/local/lib/libopen-rte.dylib;general;/opt/local/lib/libopen-pal.dylib;general;/usr/lib/libutil.dylib;general;icet; //Value Computed by CMake pqChartTest_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Qt/Chart/Testing //Value Computed by CMake pqChartTest_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Qt/Chart/Testing //Value Computed by CMake pqClient_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Applications/Client //Value Computed by CMake pqClient_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Applications/Client //Value Computed by CMake pqComponents_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Qt/Components //Dependencies for the target pqComponents_LIB_DEPENDS:STATIC=general;pqCore;general;QtChart;general;QtTesting;general;pqWidgets;general;QVTK;general;vtkPVServerManager;general;vtkPVPythonInterpretor;general;QtPython;general;vtkPVServerCommonPythonD;general;vtkPVServerManagerPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework;general;/Library/Frameworks/QtAssistant.framework;general;/Library/Frameworks/QtNetwork.framework; //Value Computed by CMake pqComponents_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Qt/Components //Value Computed by CMake pqCore_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Qt/Core //Dependencies for the target pqCore_LIB_DEPENDS:STATIC=general;QtChart;general;QtTesting;general;pqWidgets;general;QVTK;general;vtkPVServerManager;general;vtkInfovisCS;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Value Computed by CMake pqCore_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Qt/Core //Value Computed by CMake pqWidgetsTest_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Qt/Widgets/Testing //Value Computed by CMake pqWidgetsTest_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Qt/Widgets/Testing //Dependencies for the target pqWidgets_LIB_DEPENDS:STATIC=general;/usr/lib/libQtUiTools.a;general;/Library/Frameworks/QtGui.framework;general;-framework Carbon;general;-framework AppKit;general;/Library/Frameworks/QtXml.framework;general;/Library/Frameworks/QtCore.framework;general;/usr/lib/libz.dylib;general;-framework ApplicationServices; //Value Computed by CMake verdict_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/verdict //Value Computed by CMake verdict_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/verdict //Dependencies for the target vtkClientServer_LIB_DEPENDS:STATIC=general;vtkCommon; //Dependencies for the target vtkCommonCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommon; //Dependencies for the target vtkCommonPythonD_LIB_DEPENDS:STATIC=general;vtkCommon;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkCommonPython_LIB_DEPENDS:STATIC=general;vtkCommonPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkCommon_LIB_DEPENDS:STATIC=general;vtksys;general;-lpthread;general;-lm; //Dependencies for target vtkDICOMParser_LIB_DEPENDS:STATIC= //Value Computed by CMake vtkExodus2_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/vtkexodus2 //Value Computed by CMake vtkExodus2_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/vtkexodus2 //Dependencies for the target vtkFilteringCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltering;general;vtkCommonCS; //Dependencies for the target vtkFilteringPythonD_LIB_DEPENDS:STATIC=general;vtkFiltering;general;vtkCommonPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkFilteringPython_LIB_DEPENDS:STATIC=general;vtkFilteringPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkFiltering_LIB_DEPENDS:STATIC=general;vtkCommon; //Dependencies for the target vtkGenericFilteringCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkGenericFiltering;general;vtkFilteringCS; //Dependencies for the target vtkGenericFilteringPythonD_LIB_DEPENDS:STATIC=general;vtkGenericFiltering;general;vtkFilteringPythonD;general;vtkGraphicsPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkGenericFilteringPython_LIB_DEPENDS:STATIC=general;vtkGenericFilteringPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkGenericFiltering_LIB_DEPENDS:STATIC=general;vtkFiltering;general;vtkGraphics; //Dependencies for the target vtkGeovisPythonD_LIB_DEPENDS:STATIC=general;vtkGeovis;general;vtkWidgetsPythonD;general;vtkViewsPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkGeovisPython_LIB_DEPENDS:STATIC=general;vtkGeovisPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkGeovis_LIB_DEPENDS:STATIC=general;vtkWidgets;general;vtkViews;general;vtklibxml2; //Dependencies for the target vtkGraphicsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkGraphics;general;vtkFilteringCS; //Dependencies for the target vtkGraphicsPythonD_LIB_DEPENDS:STATIC=general;vtkGraphics;general;vtkFilteringPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkGraphicsPython_LIB_DEPENDS:STATIC=general;vtkGraphicsPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkGraphics_LIB_DEPENDS:STATIC=general;vtkFiltering;general;vtkverdict; //Dependencies for the target vtkHybridCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkHybrid;general;vtkRenderingCS; //Dependencies for the target vtkHybridPythonD_LIB_DEPENDS:STATIC=general;vtkHybrid;general;vtkRenderingPythonD;general;vtkIOPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkHybridPython_LIB_DEPENDS:STATIC=general;vtkHybridPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkHybrid_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkIO;general;vtkexoIIc;general;vtkParallel; //Dependencies for the target vtkIOCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIO;general;vtkFilteringCS; //Dependencies for the target vtkIOPythonD_LIB_DEPENDS:STATIC=general;vtkIO;general;vtkFilteringPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkIOPython_LIB_DEPENDS:STATIC=general;vtkIOPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkIO_LIB_DEPENDS:STATIC=general;vtkFiltering;general;vtkDICOMParser;general;vtkNetCDF;general;vtkmetaio;general;vtksqlite;general;vtkpng;general;vtkzlib;general;vtkjpeg;general;vtktiff;general;vtkexpat;general;vtksys; //Dependencies for the target vtkImagingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkImaging;general;vtkFilteringCS; //Dependencies for the target vtkImagingPythonD_LIB_DEPENDS:STATIC=general;vtkImaging;general;vtkFilteringPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkImagingPython_LIB_DEPENDS:STATIC=general;vtkImagingPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkImaging_LIB_DEPENDS:STATIC=general;vtkFiltering; //Dependencies for the target vtkInfovisCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkInfovis;general;vtkFilteringCS;general;vtkRenderingCS; //Dependencies for the target vtkInfovisPythonD_LIB_DEPENDS:STATIC=general;vtkInfovis;general;vtkWidgetsPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkInfovisPython_LIB_DEPENDS:STATIC=general;vtkInfovisPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkInfovis_LIB_DEPENDS:STATIC=general;vtkWidgets;general;vtklibxml2; //Dependencies for target vtkNetCDF_LIB_DEPENDS:STATIC= //Dependencies for the target vtkPVCommandOptions_LIB_DEPENDS:STATIC=general;vtkIO; //Dependencies for the target vtkPVFiltersCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVFilters;general;vtkParallelCS;general;vtkHybridCS;general;vtkRenderingCS;general;vtkVolumeRenderingCS;general;vtkWidgetsCS; //Dependencies for the target vtkPVFilters_LIB_DEPENDS:STATIC=general;vtkPVServerCommon;general;vtkPVServerCommonCS;general;vtkXdmfCS;general;vtkHybridCS;general;vtkParallelCS;general;vtkVolumeRenderingCS;general;vtkWidgetsCS;general;KWCommon;general;vtksys;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework;general;vtkPVPythonInterpretor;general;vtkhdf5;general;vtkClientServer;general;icet;general;icet_mpi;general;icet_strategies; //Dependencies for the target vtkPVPythonInterpretor_LIB_DEPENDS:STATIC=general;vtkCommon;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkPVServerCommonCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVServerCommon;general;vtkParallelCS;general;vtkHybridCS;general;vtkRenderingCS; //Dependencies for the target vtkPVServerCommonPythonD_LIB_DEPENDS:STATIC=general;vtkPVServerCommon;general;vtkCommonPythonD;general;vtkFilteringPythonD;general;vtkIOPythonD;general;vtkPVServerCommon;general;vtkPVServerCommonCS;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkPVServerCommonPython_LIB_DEPENDS:STATIC=general;vtkPVServerCommonPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkPVServerCommon_LIB_DEPENDS:STATIC=general;vtkHybridCS;general;vtkParallelCS;general;vtkInfovisCS;general;KWCommon;general;vtksys;general;vtkhdf5;general;vtkClientServer;general;vtkPVCommandOptions; //Dependencies for the target vtkPVServerManagerPythonD_LIB_DEPENDS:STATIC=general;vtkPVServerManager;general;vtkPVServerCommonPythonD;general;vtkPVServerManager;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkPVServerManagerPython_LIB_DEPENDS:STATIC=general;vtkPVServerManagerPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkPVServerManager_LIB_DEPENDS:STATIC=general;vtkPVFiltersCS;general;vtkClientServer;general;KWCommon;general;vtkXdmfCS;general;vtkXdmf; //Dependencies for the target vtkParallelCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkParallel;general;vtkRenderingCS; //Dependencies for the target vtkParallelPythonD_LIB_DEPENDS:STATIC=general;vtkParallel;general;vtkRenderingPythonD;general;vtkIOPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkParallelPython_LIB_DEPENDS:STATIC=general;vtkParallelPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkParallel_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkIO;general;vtkexoIIc;general;/opt/local/lib/libmpi_cxx.dylib;general;/opt/local/lib/libmpi.dylib;general;/opt/local/lib/libopen-rte.dylib;general;/opt/local/lib/libopen-pal.dylib;general;/usr/lib/libutil.dylib; //Value Computed by CMake vtkQtChart_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/GUISupport/Qt/Chart //Dependencies for the target vtkQtChart_LIB_DEPENDS:STATIC=general;/Library/Frameworks/QtGui.framework;general;-framework Carbon;general;-framework AppKit;general;/Library/Frameworks/QtSql.framework;general;/Library/Frameworks/QtCore.framework;general;/usr/lib/libz.dylib;general;-framework ApplicationServices; //Value Computed by CMake vtkQtChart_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/GUISupport/Qt/Chart //Dependencies for the target vtkRenderingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRendering;general;vtkGenericFilteringCS;general;vtkGraphicsCS;general;vtkImagingCS;general;vtkIOCS; //Dependencies for the target vtkRenderingPythonD_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkGraphicsPythonD;general;vtkImagingPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkRenderingPython_LIB_DEPENDS:STATIC=general;vtkRenderingPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkRendering_LIB_DEPENDS:STATIC=general;vtkGraphics;general;vtkImaging;general;vtkIO;general;vtkftgl;general;vtkfreetype;general;/System/Library/Frameworks/OpenGL.framework;general;/System/Library/Frameworks/AGL.framework;general;-framework Carbon; //Dependencies for the target vtkViewsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkViews;general;vtkInfovisCS;general;vtkFilteringCS; //Dependencies for the target vtkViewsPythonD_LIB_DEPENDS:STATIC=general;vtkViews;general;vtkInfovisPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkViewsPython_LIB_DEPENDS:STATIC=general;vtkViewsPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkViews_LIB_DEPENDS:STATIC=general;vtkInfovis; //Dependencies for the target vtkVolumeRenderingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkVolumeRendering;general;vtkRenderingCS; //Dependencies for the target vtkVolumeRenderingPythonD_LIB_DEPENDS:STATIC=general;vtkVolumeRendering;general;vtkRenderingPythonD;general;vtkIOPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkVolumeRenderingPython_LIB_DEPENDS:STATIC=general;vtkVolumeRenderingPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkVolumeRendering_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkIO; //Dependencies for the target vtkWidgetsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkWidgets;general;vtkRenderingCS; //Dependencies for the target vtkWidgetsPythonD_LIB_DEPENDS:STATIC=general;vtkWidgets;general;vtkRenderingPythonD;general;vtkHybridPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkWidgetsPython_LIB_DEPENDS:STATIC=general;vtkWidgetsPythonD;general;/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework; //Dependencies for the target vtkWidgets_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkHybrid; //Dependencies for the target vtkXdmfCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkXdmf;general;vtkRenderingCS; //Dependencies for the target vtkXdmfPython_LIB_DEPENDS:STATIC=general;vtkIOPythonD;general;vtkRenderingPythonD;general;vtkParallelPythonD;general;Xdmf; //Dependencies for the target vtkXdmf_LIB_DEPENDS:STATIC=general;vtkIO;general;Xdmf;general;vtkRendering;general;vtkParallel; //Dependencies for the target vtkexoIIc_LIB_DEPENDS:STATIC=general;vtkNetCDF; //Dependencies for target vtkexpat_LIB_DEPENDS:STATIC= //Dependencies for the target vtkfreetype_LIB_DEPENDS:STATIC=general;-framework ApplicationServices -framework CoreServices; //Dependencies for the target vtkftgl_LIB_DEPENDS:STATIC=general;/System/Library/Frameworks/OpenGL.framework;general;vtkfreetype; //Dependencies for the target vtkhdf5_LIB_DEPENDS:STATIC=general;m;general;vtkzlib; //Dependencies for target vtkjpeg_LIB_DEPENDS:STATIC= //Value Computed by CMake vtklibxml2_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/vtklibxml2 //Dependencies for the target vtklibxml2_LIB_DEPENDS:STATIC=general;vtkzlib;general;dl;general;history;general;readline;general;-lpthread;general;m; //Value Computed by CMake vtklibxml2_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/vtklibxml2 //Value Computed by CMake vtkmetaio_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/vtkmetaio //Dependencies for the target vtkmetaio_LIB_DEPENDS:STATIC=general;vtkzlib;general;vtksys; //Value Computed by CMake vtkmetaio_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/vtkmetaio //Dependencies for the target vtkpng_LIB_DEPENDS:STATIC=general;vtkzlib; //Dependencies for target vtksqlite_LIB_DEPENDS:STATIC= //Value Computed by CMake vtksys_BINARY_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/kwsys //Dependencies for target vtksys_LIB_DEPENDS:STATIC= //Value Computed by CMake vtksys_SOURCE_DIR:STATIC=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/Utilities/kwsys //Dependencies for the target vtktiff_LIB_DEPENDS:STATIC=general;vtkzlib;general;vtkjpeg; //Dependencies for target vtkverdict_LIB_DEPENDS:STATIC= //Dependencies for target vtkzlib_LIB_DEPENDS:STATIC= ######################## # INTERNAL cache entries ######################## //Host Arcitecture : Linux IRIXN32 IRIX64 AIX CYGWIN ARCH_TO_BUILD:INTERNAL=Darwin //Advanced flag for variable: BASH BASH-ADVANCED:INTERNAL=1 //Advanced flag for variable: BUILD_DOCUMENTATION BUILD_DOCUMENTATION-ADVANCED:INTERNAL=1 //Advanced flag for variable: BUILD_EXAMPLES BUILD_EXAMPLES-ADVANCED:INTERNAL=1 //Advanced flag for variable: BUILD_TESTING BUILD_TESTING-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CMAKE_ANSI_FOR_SCOPE:INTERNAL=TRUE //Have include iostream CMAKE_ANSI_STREAM_HEADERS:INTERNAL=1 //Advanced flag for variable: CMAKE_AR CMAKE_AR-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_BACKWARDS_COMPATIBILITY CMAKE_BACKWARDS_COMPATIBILITY-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_BUILD_TOOL CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1 //What is the target build tool cmake is generating for. CMAKE_BUILD_TOOL:INTERNAL=/usr/bin/make //This is the directory where this CMakeCahe.txt was created CMAKE_CACHEFILE_DIR:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin //Major version of cmake used to create the current loaded cache CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2 //Minor version of cmake used to create the current loaded cache CMAKE_CACHE_MINOR_VERSION:INTERNAL=7 //Major version of cmake used to create the current loaded cache CMAKE_CACHE_RELEASE_VERSION:INTERNAL=20081105 //Advanced flag for variable: CMAKE_COLOR_MAKEFILE CMAKE_COLOR_MAKEFILE-ADVANCED:INTERNAL=1 //Path to CMake executable. CMAKE_COMMAND:INTERNAL=/Users/cekees/src/pyadh/darwin_i386_macports/CMake 2.7-20081105.app/Contents/bin/cmake //Path to cpack program executable. CMAKE_CPACK_COMMAND:INTERNAL=/Users/cekees/src/pyadh/darwin_i386_macports/CMake 2.7-20081105.app/Contents/bin/cpack //Advanced flag for variable: CMAKE_CTEST_COMMAND CMAKE_CTEST_COMMAND-ADVANCED:INTERNAL=1 //Path to ctest program executable. CMAKE_CTEST_COMMAND:INTERNAL=/Users/cekees/src/pyadh/darwin_i386_macports/CMake 2.7-20081105.app/Contents/bin/ctest //Advanced flag for variable: CMAKE_CXX_COMPILER CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1 CMAKE_CXX_COMPILER_WORKS:INTERNAL=1 //Advanced flag for variable: CMAKE_CXX_FLAGS CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_CXX_FLAGS_DEBUG CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_CXX_FLAGS_MINSIZEREL CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_CXX_FLAGS_RELEASE CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_C_COMPILER CMAKE_C_COMPILER-ADVANCED:INTERNAL=1 CMAKE_C_COMPILER_WORKS:INTERNAL=1 //Advanced flag for variable: CMAKE_C_FLAGS CMAKE_C_FLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_C_FLAGS_DEBUG CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_C_FLAGS_MINSIZEREL CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_C_FLAGS_RELEASE CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_C_FLAGS_RELWITHDEBINFO CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CMAKE_DETERMINE_CXX_ABI_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE CMAKE_DETERMINE_C_ABI_COMPILED:INTERNAL=TRUE //Path to cache edit program executable. CMAKE_EDIT_COMMAND:INTERNAL=/Users/cekees/src/pyadh/darwin_i386_macports/CMake 2.7-20081105.app/Contents/bin/ccmake //Executable file format CMAKE_EXECUTABLE_FORMAT:INTERNAL=Unknown //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Name of generator. CMAKE_GENERATOR:INTERNAL=Unix Makefiles //Result of TRY_COMPILE CMAKE_HAS_ANSI_STRING_STREAM:INTERNAL=TRUE //Is X11 around. CMAKE_HAS_X:INTERNAL= //Have include CMAKE_HAVE_LIMITS_H CMAKE_HAVE_LIMITS_H:INTERNAL=1 //Have library pthreads CMAKE_HAVE_PTHREADS_CREATE:INTERNAL= //Have library pthread CMAKE_HAVE_PTHREAD_CREATE:INTERNAL=1 //Have include CMAKE_HAVE_PTHREAD_H CMAKE_HAVE_PTHREAD_H:INTERNAL=1 //Have includes CMAKE_HAVE_SYS_PRCTL_H CMAKE_HAVE_SYS_PRCTL_H:INTERNAL= //Have include CMAKE_HAVE_UNISTD_H CMAKE_HAVE_UNISTD_H:INTERNAL=1 //Start directory with the top level CMakeLists.txt file for this // project CMAKE_HOME_DIRECTORY:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs //Advanced flag for variable: CMAKE_HP_PTHREADS CMAKE_HP_PTHREADS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_INSTALL_NAME_TOOL CMAKE_INSTALL_NAME_TOOL-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_LINKER CMAKE_LINKER-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_MAKE_PROGRAM CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_NM CMAKE_NM-ADVANCED:INTERNAL=1 //Does the compiler support ansi for scope. CMAKE_NO_ANSI_FOR_SCOPE:INTERNAL=0 //Advanced flag for variable: CMAKE_NO_ANSI_STREAM_HEADERS CMAKE_NO_ANSI_STREAM_HEADERS-ADVANCED:INTERNAL=1 //Does the compiler support headers like iostream. CMAKE_NO_ANSI_STREAM_HEADERS:INTERNAL=0 //Does the compiler support sstream CMAKE_NO_ANSI_STRING_STREAM:INTERNAL=0 //Does the compiler support std::. CMAKE_NO_STD_NAMESPACE:INTERNAL=0 //number of local generators CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=151 //Advanced flag for variable: CMAKE_OBJCOPY CMAKE_OBJCOPY-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_OBJDUMP CMAKE_OBJDUMP-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_OSX_ARCHITECTURES CMAKE_OSX_ARCHITECTURES-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_OSX_SYSROOT CMAKE_OSX_SYSROOT-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_RANLIB CMAKE_RANLIB-ADVANCED:INTERNAL=1 //Test Support for 64 bit file systems CMAKE_REQUIRE_LARGE_FILE_SUPPORT:INTERNAL=1 //Path to CMake installation. CMAKE_ROOT:INTERNAL=/Users/cekees/src/pyadh/darwin_i386_macports/CMake 2.7-20081105.app/Contents/share/cmake-2.7 //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Result of CHECK_TYPE_SIZE CMAKE_SIZEOF_CHAR:INTERNAL=1 //Result of CHECK_TYPE_SIZE CMAKE_SIZEOF_DOUBLE:INTERNAL=8 //Result of CHECK_TYPE_SIZE CMAKE_SIZEOF_FLOAT:INTERNAL=4 //Result of CHECK_TYPE_SIZE CMAKE_SIZEOF_INT:INTERNAL=4 //Result of CHECK_TYPE_SIZE CMAKE_SIZEOF_LONG:INTERNAL=4 //Result of CHECK_TYPE_SIZE CMAKE_SIZEOF_SHORT:INTERNAL=2 //Result of CHECK_TYPE_SIZE CMAKE_SIZEOF_UNSIGNED_SHORT:INTERNAL=2 //Result of CHECK_TYPE_SIZE CMAKE_SIZEOF_VOID_P:INTERNAL=4 //Advanced flag for variable: CMAKE_SKIP_RPATH CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1 //Whether to build with rpath. CMAKE_SKIP_RPATH:INTERNAL=0 //Result of TRY_COMPILE CMAKE_STD_NAMESPACE:INTERNAL=TRUE //Advanced flag for variable: CMAKE_STRIP CMAKE_STRIP-ADVANCED:INTERNAL=1 //Suppress Warnings that are meant for the author of the CMakeLists.txt // files. CMAKE_SUPPRESS_DEVELOPER_WARNINGS:INTERNAL=FALSE //Advanced flag for variable: CMAKE_THREAD_LIBS CMAKE_THREAD_LIBS-ADVANCED:INTERNAL=1 //uname command CMAKE_UNAME:INTERNAL=/usr/bin/uname //Advanced flag for variable: CMAKE_USE_PTHREADS CMAKE_USE_PTHREADS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_USE_RELATIVE_PATHS CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_USE_SPROC CMAKE_USE_SPROC-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_USE_WIN32_THREADS CMAKE_USE_WIN32_THREADS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_VERBOSE_MAKEFILE CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1 //Result of TEST_BIG_ENDIAN CMAKE_WORDS_BIGENDIAN:INTERNAL=0 //Advanced flag for variable: CMAKE_X_CFLAGS CMAKE_X_CFLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CMAKE_X_LIBS CMAKE_X_LIBS-ADVANCED:INTERNAL=1 //Advanced flag for variable: COMPRESSIONCOMMAND COMPRESSIONCOMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: COVERAGE_COMMAND COVERAGE_COMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: CP CP-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_BINARY_BUNDLE CPACK_BINARY_BUNDLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_BINARY_DEB CPACK_BINARY_DEB-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_BINARY_NSIS CPACK_BINARY_NSIS-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_BINARY_OSXX11 CPACK_BINARY_OSXX11-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_BINARY_PACKAGEMAKER CPACK_BINARY_PACKAGEMAKER-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_BINARY_RPM CPACK_BINARY_RPM-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_BINARY_STGZ CPACK_BINARY_STGZ-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_BINARY_TBZ2 CPACK_BINARY_TBZ2-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_BINARY_TGZ CPACK_BINARY_TGZ-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_SOURCE_TBZ2 CPACK_SOURCE_TBZ2-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_SOURCE_TGZ CPACK_SOURCE_TGZ-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_SOURCE_TZ CPACK_SOURCE_TZ-ADVANCED:INTERNAL=1 //Advanced flag for variable: CPACK_SOURCE_ZIP CPACK_SOURCE_ZIP-ADVANCED:INTERNAL=1 //Advanced flag for variable: CVSCOMMAND CVSCOMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: CVS_UPDATE_OPTIONS CVS_UPDATE_OPTIONS-ADVANCED:INTERNAL=1 //CXX compiler accepts flag -no-cpp-precomp CXX_HAS_CPP_PRECOMP_FLAG:INTERNAL=TRUE //Advanced flag for variable: DART_BUILD_ERROR_REPORT_LIMIT DART_BUILD_ERROR_REPORT_LIMIT-ADVANCED:INTERNAL=1 //Advanced flag for variable: DART_BUILD_WARNING_REPORT_LIMIT DART_BUILD_WARNING_REPORT_LIMIT-ADVANCED:INTERNAL=1 //Advanced flag for variable: DART_ROOT DART_ROOT-ADVANCED:INTERNAL=1 //Advanced flag for variable: DART_TESTING_TIMEOUT DART_TESTING_TIMEOUT-ADVANCED:INTERNAL=1 //Advanced flag for variable: DART_VERBOSE_BUILD DART_VERBOSE_BUILD-ADVANCED:INTERNAL=1 //Advanced flag for variable: DELIVER_CONTINUOUS_EMAIL DELIVER_CONTINUOUS_EMAIL-ADVANCED:INTERNAL=1 //Advanced flag for variable: DESIRED_QT_VERSION DESIRED_QT_VERSION-ADVANCED:INTERNAL=1 //Other test DEV_T_IS_SCALAR:INTERNAL=1 //Advanced flag for variable: DOCUMENTATION_HTML_HELP DOCUMENTATION_HTML_HELP-ADVANCED:INTERNAL=1 //Advanced flag for variable: DOCUMENTATION_HTML_TARZ DOCUMENTATION_HTML_TARZ-ADVANCED:INTERNAL=1 //Advanced flag for variable: DOXYGEN_DOT_EXECUTABLE DOXYGEN_DOT_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: DOXYGEN_DOT_PATH DOXYGEN_DOT_PATH-ADVANCED:INTERNAL=1 //Advanced flag for variable: DOXYGEN_EXECUTABLE DOXYGEN_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: DOXYGEN_SHORT_NAMES DOXYGEN_SHORT_NAMES-ADVANCED:INTERNAL=1 //Advanced flag for variable: DOXYTAG DOXYTAG-ADVANCED:INTERNAL=1 //Advanced flag for variable: EXECUTABLE_OUTPUT_PATH EXECUTABLE_OUTPUT_PATH-ADVANCED:INTERNAL=1 //Single output directory for building all executables. EXECUTABLE_OUTPUT_PATH:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/bin //Have include malloc.h EX_HAVE_MALLOC_H:INTERNAL= //Details about finding MPI FIND_PACKAGE_MESSAGE_DETAILS_MPI:INTERNAL=[/opt/local/lib/libmpi_cxx.dylib][/opt/local/include] //Details about finding Perl FIND_PACKAGE_MESSAGE_DETAILS_Perl:INTERNAL=[/usr/bin/perl] //Details about finding PythonInterp FIND_PACKAGE_MESSAGE_DETAILS_PythonInterp:INTERNAL=[/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework/Versions/Current/bin/python] //Details about finding PythonLibs FIND_PACKAGE_MESSAGE_DETAILS_PythonLibs:INTERNAL=[/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework][/Users/cekees/src/pyadh/darwin_i386_macports/Python.framework/Headers] //Details about finding Qt4 FIND_PACKAGE_MESSAGE_DETAILS_Qt4:INTERNAL=[/Library/Frameworks][/usr/include][/Developer/Tools/Qt/moc][/Developer/Tools/Qt/uic][/Developer/Tools/Qt/rcc] //Details about finding Threads FIND_PACKAGE_MESSAGE_DETAILS_Threads:INTERNAL=[TRUE] //Advanced flag for variable: GNUPLOT_EXECUTABLE GNUPLOT_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: GUNZIPCOMMAND GUNZIPCOMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: GZIP GZIP-ADVANCED:INTERNAL=1 //Have symbol alloca HAVE_ALLOCA:INTERNAL=1 //Have include HAVE_ALLOCA_H HAVE_ALLOCA_H:INTERNAL=1 //Have includes HAVE_ANSIDECL_H HAVE_ANSIDECL_H:INTERNAL= //Have include HAVE_ARPA_INET_H HAVE_ARPA_INET_H:INTERNAL=1 //Have include HAVE_ARPA_NAMESER_H HAVE_ARPA_NAMESER_H:INTERNAL=1 //Have include HAVE_ASSERT_H HAVE_ASSERT_H:INTERNAL=1 //Other test HAVE_ATTRIBUTE:INTERNAL=1 //Result of TRY_COMPILE HAVE_CMAKE_REQUIRE_LARGE_FILE_SUPPORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_UNSIGNED_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_VOID_P:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_WORDS_BIGENDIAN:INTERNAL=TRUE //Have include HAVE_CTYPE_H HAVE_CTYPE_H:INTERNAL=1 //Have function difftime HAVE_DIFFTIME:INTERNAL=1 //Have include HAVE_DIRENT_H HAVE_DIRENT_H:INTERNAL=1 //Have include HAVE_DLFCN_H HAVE_DLFCN_H:INTERNAL=1 //Have library dl;history;readline;-lpthread;m HAVE_DLOPEN:INTERNAL=1 //Have includes HAVE_DL_H HAVE_DL_H:INTERNAL= //Have include HAVE_ERRNO_H HAVE_ERRNO_H:INTERNAL=1 //Have include HAVE_FCNTL_H HAVE_FCNTL_H:INTERNAL=1 //Have includes HAVE_FEATURES_H HAVE_FEATURES_H:INTERNAL= //Have symbol finite HAVE_FINITE:INTERNAL=1 //Have include HAVE_FLOAT_H HAVE_FLOAT_H:INTERNAL=1 //Have function floor HAVE_FLOOR:INTERNAL=1 //Have function fork HAVE_FORK:INTERNAL=1 //Have symbol fpclass HAVE_FPCLASS:INTERNAL= //Have symbol fprintf HAVE_FPRINTF:INTERNAL=1 //Have symbol fp_class HAVE_FP_CLASS:INTERNAL= //Have includes HAVE_FP_CLASS_H HAVE_FP_CLASS_H:INTERNAL= //Have function frexpf HAVE_FREXPF:INTERNAL=1 //Have function frexpl HAVE_FREXPL:INTERNAL=1 //Have symbol ftime HAVE_FTIME:INTERNAL=1 //NetCDF test HAVE_FTRUNCATE:INTERNAL=1 //Other test HAVE_FUNCTION:INTERNAL=1 //Result of TRY_COMPILE HAVE_GETADDRINFO_COMPILED:INTERNAL=TRUE //Have function gethostname HAVE_GETHOSTNAME:INTERNAL=1 //Have function getopt HAVE_GETOPT:INTERNAL=1 //Have function getpwuid HAVE_GETPWUID:INTERNAL=1 //Have function getrusage HAVE_GETRUSAGE:INTERNAL=1 //Have symbol gettimeofday HAVE_GETTIMEOFDAY:INTERNAL=1 //Have includes HAVE_GLOBUS_COMMON_H HAVE_GLOBUS_COMMON_H:INTERNAL= //Result of TRY_COMPILE HAVE_ICET_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_VOID_P:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF___INT64:INTERNAL=FALSE //Have includes HAVE_IEEEFP_H HAVE_IEEEFP_H:INTERNAL= //Have include HAVE_INTTYPES_H HAVE_INTTYPES_H:INTERNAL=1 //Have function ioctl HAVE_IOCTL:INTERNAL=1 //Have includes HAVE_IO_H HAVE_IO_H:INTERNAL= //Have function isascii HAVE_ISASCII:INTERNAL=1 //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF___INT64:INTERNAL=FALSE //Have library dl; HAVE_LIBDL:INTERNAL=1 //Have library history;dl HAVE_LIBHISTORY:INTERNAL=1 //Have library m; HAVE_LIBM:INTERNAL=1 //Have library readline;dl;history HAVE_LIBREADLINE:INTERNAL=1 //Have library socket;m HAVE_LIBSOCKET:INTERNAL= //Have library ucb;m HAVE_LIBUCB:INTERNAL= //Have library ws2_32;m HAVE_LIBWS2_32:INTERNAL= //Have library wsock32;m HAVE_LIBWSOCK32:INTERNAL= //Have include HAVE_LIMITS_H HAVE_LIMITS_H:INTERNAL=1 //Have symbol localtime HAVE_LOCALTIME:INTERNAL=1 //Have function longjmp HAVE_LONGJMP:INTERNAL=1 //Have includes HAVE_MALLOC_H HAVE_MALLOC_H:INTERNAL= //Have include HAVE_MATH_H HAVE_MATH_H:INTERNAL=1 //Have function memmove HAVE_MEMMOVE:INTERNAL=1 //Have include HAVE_MEMORY_H HAVE_MEMORY_H:INTERNAL=1 //Have function memset HAVE_MEMSET:INTERNAL=1 //Have includes HAVE_MFHDF_H HAVE_MFHDF_H:INTERNAL= //Have function mmap HAVE_MMAP:INTERNAL=1 //Have includes HAVE_NAN_H HAVE_NAN_H:INTERNAL= //Have includes HAVE_NDIR_H HAVE_NDIR_H:INTERNAL= //Have include HAVE_NETDB_H HAVE_NETDB_H:INTERNAL=1 //Have include HAVE_NETINET_IN_H HAVE_NETINET_IN_H:INTERNAL=1 //Have include HAVE_NETINET_TCP_H HAVE_NETINET_TCP_H:INTERNAL=1 //Other test HAVE_OFF64_T:INTERNAL= //Have includes HAVE_PDB_H HAVE_PDB_H:INTERNAL= //Have function pow HAVE_POW:INTERNAL=1 //Have symbol printf HAVE_PRINTF:INTERNAL=1 //Have include HAVE_PTHREAD_H HAVE_PTHREAD_H:INTERNAL=1 //Have include HAVE_RESOLV_H HAVE_RESOLV_H:INTERNAL=1 //Have include HAVE_SETJMP_H HAVE_SETJMP_H:INTERNAL=1 //Have library dld;dl HAVE_SHLLOAD:INTERNAL= //Have function sigaction HAVE_SIGACTION:INTERNAL=1 //Have symbol signal HAVE_SIGNAL:INTERNAL=1 //Have include HAVE_SIGNAL_H HAVE_SIGNAL_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_FAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_FAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_FAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_FAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_LEAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_LEAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_LEAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT_LEAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_JDSHKJFHDKS:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_LONG_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_OFF_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_PTRDIFF_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SSIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UCHAR:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_SIZEOF_UINT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_FAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_FAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_FAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_FAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_LEAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_LEAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_LEAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UINT_LEAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF___INT64:INTERNAL=FALSE //Have symbol snprintf HAVE_SNPRINTF:INTERNAL=1 //Other test HAVE_SOCKLEN_T:INTERNAL=1 //Result of TRY_COMPILE HAVE_SOCKLEN_T_COMPILED:INTERNAL=TRUE //Have symbol SO_REUSEADDR HAVE_SO_REUSEADDR:INTERNAL=1 //Have symbol sprintf HAVE_SPRINTF:INTERNAL=1 //Have function sqrt HAVE_SQRT:INTERNAL=1 //Have includes HAVE_SRBCLIENT_H HAVE_SRBCLIENT_H:INTERNAL= //Have symbol sscanf HAVE_SSCANF:INTERNAL=1 //Have symbol stat HAVE_STAT:INTERNAL=1 //Other test HAVE_STAT_ST_BLOCKS:INTERNAL=1 //Have include HAVE_STDARG_H HAVE_STDARG_H:INTERNAL=1 //Have include stddef.h HAVE_STDDEF_H:INTERNAL=1 //Have include stdint.h HAVE_STDINT_H:INTERNAL=1 //Have include stdint.h HAVE_STDINT_H_CXX:INTERNAL=1 //Have include HAVE_STDIO_H HAVE_STDIO_H:INTERNAL=1 //Have include HAVE_STDLIB_H HAVE_STDLIB_H:INTERNAL=1 //Have function strcasecmp HAVE_STRCASECMP:INTERNAL=1 //Have function strchr HAVE_STRCHR:INTERNAL=1 //Have symbol strdup HAVE_STRDUP:INTERNAL=1 //Have symbol strerror HAVE_STRERROR:INTERNAL=1 //Have symbol strftime HAVE_STRFTIME:INTERNAL=1 //Have include HAVE_STRINGS_H HAVE_STRINGS_H:INTERNAL=1 //Have include HAVE_STRING_H HAVE_STRING_H:INTERNAL=1 //Have symbol strndup HAVE_STRNDUP:INTERNAL= //Have function strrchr HAVE_STRRCHR:INTERNAL=1 //Have function strstr HAVE_STRSTR:INTERNAL=1 //Have function strtol HAVE_STRTOL:INTERNAL=1 //Have function strtoll HAVE_STRTOLL:INTERNAL=1 //Have function areroul HAVE_STRTOUL:INTERNAL= //Other test HAVE_STRUCT_TIMEZONE:INTERNAL=1 //Other test HAVE_STRUCT_TM_TM_ZONE:INTERNAL=1 //NetCDF test HAVE_ST_BLKSIZE:INTERNAL=1 //Have function system HAVE_SYSTEM:INTERNAL=1 //Result of TRY_COMPILE HAVE_SYS_DIR_H_COMPILED:INTERNAL=TRUE //Have include HAVE_SYS_FILIO_H HAVE_SYS_FILIO_H:INTERNAL=1 //Have include HAVE_SYS_IOCTL_H HAVE_SYS_IOCTL_H:INTERNAL=1 //Have include HAVE_SYS_MMAN_H HAVE_SYS_MMAN_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_SYS_NDIR_H_COMPILED:INTERNAL=FALSE //Have includes HAVE_SYS_PROC_H HAVE_SYS_PROC_H:INTERNAL= //Have include HAVE_SYS_RESOURCE_H HAVE_SYS_RESOURCE_H:INTERNAL=1 //Have include HAVE_SYS_SELECT_H HAVE_SYS_SELECT_H:INTERNAL=1 //Have include HAVE_SYS_SOCKET_H HAVE_SYS_SOCKET_H:INTERNAL=1 //Have include HAVE_SYS_STAT_H HAVE_SYS_STAT_H:INTERNAL=1 HAVE_SYS_SYSINFO_H:INTERNAL= //Have include HAVE_SYS_TIMEB_H HAVE_SYS_TIMEB_H:INTERNAL=1 //Have include HAVE_SYS_TIME_H HAVE_SYS_TIME_H:INTERNAL=1 //Have include sys/types.h HAVE_SYS_TYPES_H:INTERNAL=1 //Other test HAVE_TIMEZONE:INTERNAL=1 //Have include HAVE_TIME_H HAVE_TIME_H:INTERNAL=1 //Have symbol TIOCGETD HAVE_TIOCGETD:INTERNAL=1 //Have symbol TIOCGWINSZ HAVE_TIOCGWINSZ:INTERNAL=1 //Other test HAVE_TM_GMTOFF:INTERNAL=1 //Other test HAVE_TM_ZONE:INTERNAL=1 //Have include HAVE_UNISTD_H HAVE_UNISTD_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_VA_COPY_COMPILED:INTERNAL=TRUE //Have symbol vfprintf HAVE_VFPRINTF:INTERNAL=1 //Have symbol vsnprintf HAVE_VSNPRINTF:INTERNAL=1 //Have symbol vsprintf HAVE_VSPRINTF:INTERNAL=1 //Result of TRY_COMPILE HAVE_VTK_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTK_SIZEOF___INT64:INTERNAL=FALSE //Have function waitpid HAVE_WAITPID:INTERNAL=1 //Have includes HAVE_WINDOWS_H HAVE_WINDOWS_H:INTERNAL= //Have includes HAVE_WINSOCK_H HAVE_WINSOCK_H:INTERNAL= //Have symbol _stat HAVE__STAT:INTERNAL= //Result of TRY_COMPILE HAVE___VA_COPY_COMPILED:INTERNAL=TRUE //Advanced flag for variable: HDF5_ENABLE_HSIZET HDF5_ENABLE_HSIZET-ADVANCED:INTERNAL=1 //Advanced flag for variable: HDF5_ENABLE_PARALLEL HDF5_ENABLE_PARALLEL-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE HDF5_PRINTF_LL_TEST_COMPILE:INTERNAL=TRUE //Result of TRY_RUN HDF5_PRINTF_LL_TEST_RUN:INTERNAL=0 //Advanced flag for variable: HDF5_STREAM_VFD HDF5_STREAM_VFD-ADVANCED:INTERNAL=1 //Advanced flag for variable: ICET_BUILD_TESTING ICET_BUILD_TESTING-ADVANCED:INTERNAL=1 //Advanced flag for variable: ICET_MPIRUN_EXE ICET_MPIRUN_EXE-ADVANCED:INTERNAL=1 //This is set from VTK_MPIRUN_EXE. ICET_MPIRUN_EXE:INTERNAL=/opt/local/bin/openmpiexec //Advanced flag for variable: ICET_MPI_MAX_NUMPROCS ICET_MPI_MAX_NUMPROCS-ADVANCED:INTERNAL=1 //This is set from VTK_MPI_MAX_NUMPROCS. ICET_MPI_MAX_NUMPROCS:INTERNAL=2 //Advanced flag for variable: ICET_MPI_POSTFLAGS ICET_MPI_POSTFLAGS-ADVANCED:INTERNAL=1 //This is set from VTK_MPI_POSTFLAGS. ICET_MPI_POSTFLAGS:INTERNAL= //Advanced flag for variable: ICET_MPI_PREFLAGS ICET_MPI_PREFLAGS-ADVANCED:INTERNAL=1 //This is set from a combination of VTK_MPI_PREFLAGS VTK_MPI_NUMPROC_FLAG // VTK_MPI_MAX_NUMPROCS VTK_MPI_PREFLAGS. ICET_MPI_PREFLAGS:INTERNAL=;-np;2; //Result of CHECK_TYPE_SIZE ICET_SIZEOF_CHAR:INTERNAL=1 //Result of CHECK_TYPE_SIZE ICET_SIZEOF_DOUBLE:INTERNAL=8 //Result of CHECK_TYPE_SIZE ICET_SIZEOF_FLOAT:INTERNAL=4 //Result of CHECK_TYPE_SIZE ICET_SIZEOF_INT:INTERNAL=4 //Result of CHECK_TYPE_SIZE ICET_SIZEOF_LONG:INTERNAL=4 //Result of CHECK_TYPE_SIZE ICET_SIZEOF_LONG_LONG:INTERNAL=8 //Result of CHECK_TYPE_SIZE ICET_SIZEOF_SHORT:INTERNAL=2 //Result of CHECK_TYPE_SIZE ICET_SIZEOF_VOID_P:INTERNAL=4 //Result of CHECK_TYPE_SIZE ICET_SIZEOF___INT64:INTERNAL= //Whether streams support 64-bit types ICE_HAVE_64BIT_STREAMS:INTERNAL=1 //Advanced flag for variable: ICE_HAVE_FCNTL ICE_HAVE_FCNTL-ADVANCED:INTERNAL=1 //Advanced flag for variable: ICE_HAVE_MMAN ICE_HAVE_MMAN-ADVANCED:INTERNAL=1 //Advanced flag for variable: ICE_HAVE_NETINET ICE_HAVE_NETINET-ADVANCED:INTERNAL=1 //Advanced flag for variable: INCLUDE_QT_DOCUMENTATION INCLUDE_QT_DOCUMENTATION-ADVANCED:INTERNAL=1 //Other test INLINE_TEST___inline:INTERNAL=1 //Other test INLINE_TEST___inline__:INTERNAL=1 //Other test INLINE_TEST_inline:INTERNAL=1 //Advanced flag for variable: JAVACOMMAND JAVACOMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: KWCommon_BUILD_TESTING KWCommon_BUILD_TESTING-ADVANCED:INTERNAL=1 //include paths for KWCommon KWCommon_INCLUDE_PATH:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/Common/KWCommon //libraries for KWCommon KWCommon_LIBRARIES:INTERNAL=KWCommon //Result of TRY_RUN KWSYS_CHAR_IS_SIGNED:INTERNAL=0 //Result of TRY_COMPILE KWSYS_CHAR_IS_SIGNED_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_ARGUMENT_DEPENDENT_LOOKUP_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_CSTDDEF_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_FULL_SPECIALIZATION_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_MEMBER_TEMPLATES_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_NULL_TEMPLATE_ARGS_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_C_HAS_PTRDIFF_T_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_C_HAS_SSIZE_T_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_HAVE_STD_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_USE_ANSI_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_USE_SSTREAM_COMPILED:INTERNAL=TRUE //Result of TRY_RUN KWSYS_LFS_WORKS:INTERNAL=0 //Result of TRY_COMPILE KWSYS_LFS_WORKS_COMPILED:INTERNAL=TRUE //Result of CHECK_TYPE_SIZE KWSYS_SIZEOF_CHAR:INTERNAL=1 //Result of CHECK_TYPE_SIZE KWSYS_SIZEOF_INT:INTERNAL=4 //Result of CHECK_TYPE_SIZE KWSYS_SIZEOF_LONG:INTERNAL=4 //Result of CHECK_TYPE_SIZE KWSYS_SIZEOF_LONG_LONG:INTERNAL=8 //Result of CHECK_TYPE_SIZE KWSYS_SIZEOF_SHORT:INTERNAL=2 //Result of CHECK_TYPE_SIZE KWSYS_SIZEOF___INT64:INTERNAL= //Result of TRY_COMPILE KWSYS_STAT_HAS_ST_MTIM_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_MAX_SIZE_ARGUMENT_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_OBJECTS_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_REBIND_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_TEMPLATE_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ITERATOR_TRAITS_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAVE_STD_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_STRING_HAVE_NEQ_CHAR_COMPILED:INTERNAL=TRUE //Advanced flag for variable: LIBRARY_OUTPUT_PATH LIBRARY_OUTPUT_PATH-ADVANCED:INTERNAL=1 //Single output directory for building all libraries. LIBRARY_OUTPUT_PATH:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/bin //Advanced flag for variable: MAKECOMMAND MAKECOMMAND-ADVANCED:INTERNAL=1 //Path to vtkMaterialLibraryMacro.h MATERIAL_LIBRARY_MATERIAL_MACRO_HEADER:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/MaterialLibrary/vtkMaterialLibraryMacro.h //Path to vtkShaderCodeLibraryMacro.h MATERIAL_LIBRARY_SHADER_MACRO_HEADER:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/MaterialLibrary/vtkShaderCodeLibraryMacro.h //Advanced flag for variable: MEMORYCHECK_COMMAND MEMORYCHECK_COMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: MEMORYCHECK_SUPPRESSIONS_FILE MEMORYCHECK_SUPPRESSIONS_FILE-ADVANCED:INTERNAL=1 //Advanced flag for variable: MPIEXEC MPIEXEC-ADVANCED:INTERNAL=1 //Advanced flag for variable: MPIEXEC_MAX_NUMPROCS MPIEXEC_MAX_NUMPROCS-ADVANCED:INTERNAL=1 //Advanced flag for variable: MPIEXEC_NUMPROC_FLAG MPIEXEC_NUMPROC_FLAG-ADVANCED:INTERNAL=1 //Advanced flag for variable: MPIEXEC_POSTFLAGS MPIEXEC_POSTFLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: MPIEXEC_PREFLAGS MPIEXEC_PREFLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: MPI_COMPILER MPI_COMPILER-ADVANCED:INTERNAL=1 //Advanced flag for variable: MPI_COMPILE_FLAGS MPI_COMPILE_FLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: MPI_EXTRA_LIBRARY MPI_EXTRA_LIBRARY-ADVANCED:INTERNAL=0 //Advanced flag for variable: MPI_INCLUDE_PATH MPI_INCLUDE_PATH-ADVANCED:INTERNAL=0 //Scratch variable for MPI detection MPI_LIB:INTERNAL=MPI_LIB-NOTFOUND //Advanced flag for variable: MPI_LIBRARY MPI_LIBRARY-ADVANCED:INTERNAL=0 //Advanced flag for variable: MPI_LINK_FLAGS MPI_LINK_FLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: MV MV-ADVANCED:INTERNAL=1 //Have library c NOT_NEED_LIBNSL:INTERNAL=1 //Advanced flag for variable: OPENGL_INCLUDE_DIR OPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: OPENGL_gl_LIBRARY OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: OPENGL_glu_LIBRARY OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: OPENSSL_INCLUDE_DIR OPENSSL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: OPENSSL_LIBRARIES OPENSSL_LIBRARIES-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_ALWAYS_SECURE_CONNECTION PARAVIEW_ALWAYS_SECURE_CONNECTION-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_Client PARAVIEW_BUILD_Client-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_OverView PARAVIEW_BUILD_OverView-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_Array PARAVIEW_BUILD_PLUGIN_Array-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_ChartViewFrame PARAVIEW_BUILD_PLUGIN_ChartViewFrame-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_ClientAttributeView PARAVIEW_BUILD_PLUGIN_ClientAttributeView-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_ClientChartView PARAVIEW_BUILD_PLUGIN_ClientChartView-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_ClientGeoView PARAVIEW_BUILD_PLUGIN_ClientGeoView-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_ClientGraphView PARAVIEW_BUILD_PLUGIN_ClientGraphView-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_ClientHierarchyView PARAVIEW_BUILD_PLUGIN_ClientHierarchyView-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_ClientRecordView PARAVIEW_BUILD_PLUGIN_ClientRecordView-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_ClientTableView PARAVIEW_BUILD_PLUGIN_ClientTableView-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_CommonToolbar PARAVIEW_BUILD_PLUGIN_CommonToolbar-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_CosmoFilters PARAVIEW_BUILD_PLUGIN_CosmoFilters-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_GraphLayoutFilterPanel PARAVIEW_BUILD_PLUGIN_GraphLayoutFilterPanel-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_Infovis PARAVIEW_BUILD_PLUGIN_Infovis-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_Prism PARAVIEW_BUILD_PLUGIN_Prism-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_SQLDatabaseGraphSourcePanel PARAVIEW_BUILD_PLUGIN_SQLDatabaseGraphSourcePanel-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_SQLDatabaseTableSourcePanel PARAVIEW_BUILD_PLUGIN_SQLDatabaseTableSourcePanel-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_SplitTableFieldPanel PARAVIEW_BUILD_PLUGIN_SplitTableFieldPanel-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_StatisticsToolbar PARAVIEW_BUILD_PLUGIN_StatisticsToolbar-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_TableToGraphPanel PARAVIEW_BUILD_PLUGIN_TableToGraphPanel-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_TableToSparseArrayPanel PARAVIEW_BUILD_PLUGIN_TableToSparseArrayPanel-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_PLUGIN_ThresholdTablePanel PARAVIEW_BUILD_PLUGIN_ThresholdTablePanel-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_BUILD_WITH_ADAPTOR PARAVIEW_BUILD_WITH_ADAPTOR-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_ENABLE_FPE PARAVIEW_ENABLE_FPE-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_EXPERIMENTAL_USER PARAVIEW_EXPERIMENTAL_USER-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_EXTRA_EXTERNAL_MODULES PARAVIEW_EXTRA_EXTERNAL_MODULES-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_TESTING_WITH_PYTHON PARAVIEW_TESTING_WITH_PYTHON-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_USE_ICE_T PARAVIEW_USE_ICE_T-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_USE_SILO PARAVIEW_USE_SILO-ADVANCED:INTERNAL=1 //Advanced flag for variable: PARAVIEW_USE_SYSTEM_HDF5 PARAVIEW_USE_SYSTEM_HDF5-ADVANCED:INTERNAL=1 //Advanced flag for variable: PERL_EXECUTABLE PERL_EXECUTABLE-ADVANCED:INTERNAL=1 //Width for printf for type `long long' or `__int64', us. `ll PRINTF_LL_WIDTH:INTERNAL="q" //Path to paraview module. PV_PYTHON_MODULE_DIR:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/Utilities/VTKPythonWrapping //Advanced flag for variable: PV_TEST_CLEAN_COMMAND PV_TEST_CLEAN_COMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: PV_TEST_CLIENT PV_TEST_CLIENT-ADVANCED:INTERNAL=1 //Advanced flag for variable: PV_TEST_INIT_COMMAND PV_TEST_INIT_COMMAND-ADVANCED:INTERNAL=1 //Advanced flag for variable: PV_TEST_SERVER_ROOT PV_TEST_SERVER_ROOT-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_DEBUG_LIBRARY PYTHON_DEBUG_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkCommonPython PYTHON_ENABLE_MODULE_vtkCommonPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkFilteringPython PYTHON_ENABLE_MODULE_vtkFilteringPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkGenericFilteringPython PYTHON_ENABLE_MODULE_vtkGenericFilteringPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkGeovisPython PYTHON_ENABLE_MODULE_vtkGeovisPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkGraphicsPython PYTHON_ENABLE_MODULE_vtkGraphicsPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkHybridPython PYTHON_ENABLE_MODULE_vtkHybridPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkIOPython PYTHON_ENABLE_MODULE_vtkIOPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkImagingPython PYTHON_ENABLE_MODULE_vtkImagingPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkInfovisPython PYTHON_ENABLE_MODULE_vtkInfovisPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkPVServerCommonPython PYTHON_ENABLE_MODULE_vtkPVServerCommonPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkPVServerManagerPython PYTHON_ENABLE_MODULE_vtkPVServerManagerPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkParallelPython PYTHON_ENABLE_MODULE_vtkParallelPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkRenderingPython PYTHON_ENABLE_MODULE_vtkRenderingPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkViewsPython PYTHON_ENABLE_MODULE_vtkViewsPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkVolumeRenderingPython PYTHON_ENABLE_MODULE_vtkVolumeRenderingPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_ENABLE_MODULE_vtkWidgetsPython PYTHON_ENABLE_MODULE_vtkWidgetsPython-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_EXECUTABLE PYTHON_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_EXTRA_LIBS PYTHON_EXTRA_LIBS-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_INCLUDE_PATH PYTHON_INCLUDE_PATH-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_LIBRARY PYTHON_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkCommonPython_BUILD_SHARED PYTHON_MODULE_vtkCommonPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkFilteringPython_BUILD_SHARED PYTHON_MODULE_vtkFilteringPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkGenericFilteringPython_BUILD_SHARED PYTHON_MODULE_vtkGenericFilteringPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkGeovisPython_BUILD_SHARED PYTHON_MODULE_vtkGeovisPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkGraphicsPython_BUILD_SHARED PYTHON_MODULE_vtkGraphicsPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkHybridPython_BUILD_SHARED PYTHON_MODULE_vtkHybridPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkIOPython_BUILD_SHARED PYTHON_MODULE_vtkIOPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkImagingPython_BUILD_SHARED PYTHON_MODULE_vtkImagingPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkInfovisPython_BUILD_SHARED PYTHON_MODULE_vtkInfovisPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkPVServerCommonPython_BUILD_SHARED PYTHON_MODULE_vtkPVServerCommonPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkPVServerManagerPython_BUILD_SHARED PYTHON_MODULE_vtkPVServerManagerPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkParallelPython_BUILD_SHARED PYTHON_MODULE_vtkParallelPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkRenderingPython_BUILD_SHARED PYTHON_MODULE_vtkRenderingPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkViewsPython_BUILD_SHARED PYTHON_MODULE_vtkViewsPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkVolumeRenderingPython_BUILD_SHARED PYTHON_MODULE_vtkVolumeRenderingPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_MODULE_vtkWidgetsPython_BUILD_SHARED PYTHON_MODULE_vtkWidgetsPython_BUILD_SHARED-ADVANCED:INTERNAL=1 //Advanced flag for variable: PYTHON_UTIL_LIBRARY PYTHON_UTIL_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_ASSISTANT_EXECUTABLE QT_ASSISTANT_EXECUTABLE-ADVANCED:INTERNAL=1 QT_BINARY_DIR:INTERNAL=/Developer/Tools/Qt //Advanced flag for variable: QT_DBUSCPP2XML_EXECUTABLE QT_DBUSCPP2XML_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_DBUSXML2CPP_EXECUTABLE QT_DBUSXML2CPP_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_DOC_DIR QT_DOC_DIR-ADVANCED:INTERNAL=1 QT_HEADERS_DIR:INTERNAL=/usr/include //Advanced flag for variable: QT_LIBRARY_DIR QT_LIBRARY_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_LRELEASE_EXECUTABLE QT_LRELEASE_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_LUPDATE_EXECUTABLE QT_LUPDATE_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_MKSPECS_DIR QT_MKSPECS_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_MOC_EXECUTABLE QT_MOC_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_PHONON_INCLUDE_DIR QT_PHONON_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_PHONON_LIBRARY_DEBUG QT_PHONON_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_PHONON_LIBRARY_RELEASE QT_PHONON_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_PLUGINS_DIR QT_PLUGINS_DIR-ADVANCED:INTERNAL=1 QT_QMAKE_EXECUTABLE_LAST:INTERNAL=/usr/bin/qmake //Advanced flag for variable: QT_QT3SUPPORT_INCLUDE_DIR QT_QT3SUPPORT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QT3SUPPORT_LIBRARY QT_QT3SUPPORT_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QT3SUPPORT_LIBRARY_DEBUG QT_QT3SUPPORT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QT3SUPPORT_LIBRARY_RELEASE QT_QT3SUPPORT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTASSISTANTCLIENT_INCLUDE_DIR QT_QTASSISTANTCLIENT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTASSISTANTCLIENT_LIBRARY_DEBUG QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTASSISTANTCLIENT_LIBRARY_RELEASE QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTASSISTANT_INCLUDE_DIR QT_QTASSISTANT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTASSISTANT_LIBRARY QT_QTASSISTANT_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTASSISTANT_LIBRARY_DEBUG QT_QTASSISTANT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTASSISTANT_LIBRARY_RELEASE QT_QTASSISTANT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTCLUCENE_LIBRARY_DEBUG QT_QTCLUCENE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTCLUCENE_LIBRARY_RELEASE QT_QTCLUCENE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTCORE_INCLUDE_DIR QT_QTCORE_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTCORE_LIBRARY QT_QTCORE_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTCORE_LIBRARY_DEBUG QT_QTCORE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTCORE_LIBRARY_RELEASE QT_QTCORE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTDBUS_INCLUDE_DIR QT_QTDBUS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTDBUS_LIBRARY_DEBUG QT_QTDBUS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTDBUS_LIBRARY_RELEASE QT_QTDBUS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY QT_QTDESIGNERCOMPONENTS_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTDESIGNER_INCLUDE_DIR QT_QTDESIGNER_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTDESIGNER_LIBRARY QT_QTDESIGNER_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTDESIGNER_LIBRARY_DEBUG QT_QTDESIGNER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTDESIGNER_LIBRARY_RELEASE QT_QTDESIGNER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTGUI_INCLUDE_DIR QT_QTGUI_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTGUI_LIBRARY QT_QTGUI_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTGUI_LIBRARY_DEBUG QT_QTGUI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTGUI_LIBRARY_RELEASE QT_QTGUI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTHELP_INCLUDE_DIR QT_QTHELP_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTHELP_LIBRARY_DEBUG QT_QTHELP_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTHELP_LIBRARY_RELEASE QT_QTHELP_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTMOTIF_INCLUDE_DIR QT_QTMOTIF_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTMOTIF_LIBRARY_DEBUG QT_QTMOTIF_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTMOTIF_LIBRARY_RELEASE QT_QTMOTIF_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTNETWORK_INCLUDE_DIR QT_QTNETWORK_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTNETWORK_LIBRARY QT_QTNETWORK_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTNETWORK_LIBRARY_DEBUG QT_QTNETWORK_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTNETWORK_LIBRARY_RELEASE QT_QTNETWORK_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTNSPLUGIN_INCLUDE_DIR QT_QTNSPLUGIN_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTNSPLUGIN_LIBRARY_DEBUG QT_QTNSPLUGIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTNSPLUGIN_LIBRARY_RELEASE QT_QTNSPLUGIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTOPENGL_INCLUDE_DIR QT_QTOPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTOPENGL_LIBRARY QT_QTOPENGL_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTOPENGL_LIBRARY_DEBUG QT_QTOPENGL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTOPENGL_LIBRARY_RELEASE QT_QTOPENGL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTSCRIPT_INCLUDE_DIR QT_QTSCRIPT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTSCRIPT_LIBRARY QT_QTSCRIPT_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTSCRIPT_LIBRARY_DEBUG QT_QTSCRIPT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTSCRIPT_LIBRARY_RELEASE QT_QTSCRIPT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTSQL_INCLUDE_DIR QT_QTSQL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTSQL_LIBRARY QT_QTSQL_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTSQL_LIBRARY_DEBUG QT_QTSQL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTSQL_LIBRARY_RELEASE QT_QTSQL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTSVG_INCLUDE_DIR QT_QTSVG_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTSVG_LIBRARY QT_QTSVG_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTSVG_LIBRARY_DEBUG QT_QTSVG_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTSVG_LIBRARY_RELEASE QT_QTSVG_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTTEST_INCLUDE_DIR QT_QTTEST_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTTEST_LIBRARY QT_QTTEST_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTTEST_LIBRARY_DEBUG QT_QTTEST_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTTEST_LIBRARY_RELEASE QT_QTTEST_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTUITOOLS_INCLUDE_DIR QT_QTUITOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTUITOOLS_LIBRARY QT_QTUITOOLS_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTUITOOLS_LIBRARY_DEBUG QT_QTUITOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTUITOOLS_LIBRARY_RELEASE QT_QTUITOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTWEBKIT_INCLUDE_DIR QT_QTWEBKIT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTWEBKIT_LIBRARY_DEBUG QT_QTWEBKIT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTWEBKIT_LIBRARY_RELEASE QT_QTWEBKIT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTXMLPATTERNS_INCLUDE_DIR QT_QTXMLPATTERNS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTXMLPATTERNS_LIBRARY_DEBUG QT_QTXMLPATTERNS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTXMLPATTERNS_LIBRARY_RELEASE QT_QTXMLPATTERNS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTXML_INCLUDE_DIR QT_QTXML_INCLUDE_DIR-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTXML_LIBRARY QT_QTXML_LIBRARY-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTXML_LIBRARY_DEBUG QT_QTXML_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_QTXML_LIBRARY_RELEASE QT_QTXML_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_RCC_EXECUTABLE QT_RCC_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_UIC3_EXECUTABLE QT_UIC3_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_UIC_EXECUTABLE QT_UIC_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_USE_FRAMEWORKS QT_USE_FRAMEWORKS-ADVANCED:INTERNAL=1 //Advanced flag for variable: QT_ZLIB_LIBRARY QT_ZLIB_LIBRARY-ADVANCED:INTERNAL=1 //Have symbol Q_WS_MAC Q_WS_MAC:INTERNAL=1 //Have symbol Q_WS_QWS Q_WS_QWS:INTERNAL= //Have symbol Q_WS_WIN Q_WS_WIN:INTERNAL= //Have symbol Q_WS_X11 Q_WS_X11:INTERNAL= //Advanced flag for variable: RM RM-ADVANCED:INTERNAL=1 //Advanced flag for variable: SCPCOMMAND SCPCOMMAND-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE SHARED_LIBRARY_PATH_INFO_COMPILED:INTERNAL=TRUE //Result of TRY_RUN SHARED_LIBRARY_PATH_TYPE:INTERNAL=0 //runtime library path variable name. SHARED_LIBRARY_PATH_VAR_NAME:INTERNAL=DYLD_LIBRARY_PATH //Advanced flag for variable: SITE SITE-ADVANCED:INTERNAL=1 //Result of CHECK_TYPE_SIZE SIZEOF_CHAR:INTERNAL=1 //Result of CHECK_TYPE_SIZE SIZEOF_DOUBLE:INTERNAL=8 //Result of CHECK_TYPE_SIZE SIZEOF_FLOAT:INTERNAL=4 //Result of CHECK_TYPE_SIZE SIZEOF_INT:INTERNAL=4 //Result of CHECK_TYPE_SIZE SIZEOF_INT16_T:INTERNAL=2 //Result of CHECK_TYPE_SIZE SIZEOF_INT32_T:INTERNAL=4 //Result of CHECK_TYPE_SIZE SIZEOF_INT64_T:INTERNAL=8 //Result of CHECK_TYPE_SIZE SIZEOF_INT8_T:INTERNAL=1 //Result of CHECK_TYPE_SIZE SIZEOF_INT_FAST16_T:INTERNAL=2 //Result of CHECK_TYPE_SIZE SIZEOF_INT_FAST32_T:INTERNAL=4 //Result of CHECK_TYPE_SIZE SIZEOF_INT_FAST64_T:INTERNAL=8 //Result of CHECK_TYPE_SIZE SIZEOF_INT_FAST8_T:INTERNAL=1 //Result of CHECK_TYPE_SIZE SIZEOF_INT_LEAST16_T:INTERNAL=2 //Result of CHECK_TYPE_SIZE SIZEOF_INT_LEAST32_T:INTERNAL=4 //Result of CHECK_TYPE_SIZE SIZEOF_INT_LEAST64_T:INTERNAL=8 //Result of CHECK_TYPE_SIZE SIZEOF_INT_LEAST8_T:INTERNAL=1 //Result of CHECK_TYPE_SIZE SIZEOF_JDSHKJFHDKS:INTERNAL= //Result of CHECK_TYPE_SIZE SIZEOF_LONG:INTERNAL=4 //Result of CHECK_TYPE_SIZE SIZEOF_LONG_DOUBLE:INTERNAL=16 //Result of CHECK_TYPE_SIZE SIZEOF_LONG_LONG:INTERNAL=8 //Result of CHECK_TYPE_SIZE SIZEOF_OFF_T:INTERNAL=8 //Result of CHECK_TYPE_SIZE SIZEOF_PTRDIFF_T:INTERNAL=4 //Result of CHECK_TYPE_SIZE SIZEOF_SHORT:INTERNAL=2 //Result of CHECK_TYPE_SIZE SIZEOF_SIZE_T:INTERNAL=4 //Result of CHECK_TYPE_SIZE SIZEOF_SSIZE_T:INTERNAL=4 //Result of CHECK_TYPE_SIZE SIZEOF_UCHAR:INTERNAL= //Result of CHECK_TYPE_SIZE SIZEOF_UINT16_T:INTERNAL=2 //Result of CHECK_TYPE_SIZE SIZEOF_UINT32_T:INTERNAL=4 //Result of CHECK_TYPE_SIZE SIZEOF_UINT64_T:INTERNAL=8 //Result of CHECK_TYPE_SIZE SIZEOF_UINT8_T:INTERNAL=1 //Result of CHECK_TYPE_SIZE SIZEOF_UINT_FAST16_T:INTERNAL=2 //Result of CHECK_TYPE_SIZE SIZEOF_UINT_FAST32_T:INTERNAL=4 //Result of CHECK_TYPE_SIZE SIZEOF_UINT_FAST64_T:INTERNAL=8 //Result of CHECK_TYPE_SIZE SIZEOF_UINT_FAST8_T:INTERNAL=1 //Result of CHECK_TYPE_SIZE SIZEOF_UINT_LEAST16_T:INTERNAL=2 //Result of CHECK_TYPE_SIZE SIZEOF_UINT_LEAST32_T:INTERNAL=4 //Result of CHECK_TYPE_SIZE SIZEOF_UINT_LEAST64_T:INTERNAL=8 //Result of CHECK_TYPE_SIZE SIZEOF_UINT_LEAST8_T:INTERNAL=1 //Result of CHECK_TYPE_SIZE SIZEOF___INT64:INTERNAL= //Have include STDC_HEADERS STDC_HEADERS:INTERNAL=1 //Result of TRY_COMPILE SUPPORT_IP6_COMPILED:INTERNAL=TRUE //Advanced flag for variable: SVNCOMMAND SVNCOMMAND-ADVANCED:INTERNAL=1 //Other test SYSTEM_SCOPE_THREADS:INTERNAL=1 //Advanced flag for variable: TAR TAR-ADVANCED:INTERNAL=1 //Other test TIME_WITH_SYS_TIME:INTERNAL=1 //Advanced flag for variable: VERDICT_BUILD_DOC VERDICT_BUILD_DOC-ADVANCED:INTERNAL=1 //Advanced flag for variable: VERDICT_ENABLE_TESTING VERDICT_ENABLE_TESTING-ADVANCED:INTERNAL=1 //Advanced flag for variable: VERDICT_MANGLE VERDICT_MANGLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: VERDICT_MANGLE_PREFIX VERDICT_MANGLE_PREFIX-ADVANCED:INTERNAL=1 //Advanced flag for variable: VERDICT_USE_FLOAT VERDICT_USE_FLOAT-ADVANCED:INTERNAL=1 //Advanced flag for variable: VLI_LIBRARY_FOR_VP1000 VLI_LIBRARY_FOR_VP1000-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE VTK_ANSI_STREAM_EOF_COMPILED:INTERNAL=TRUE //Result of TRY_RUN VTK_ANSI_STREAM_EOF_RESULT:INTERNAL=0 //Advanced flag for variable: VTK_APPLE_RESOURCE VTK_APPLE_RESOURCE-ADVANCED:INTERNAL=1 VTK_CMAKE_DIR:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs/VTK/CMake //Support for C++ type bool VTK_COMPILER_HAS_BOOL:INTERNAL=1 //Support for full template specialization syntax VTK_COMPILER_HAS_FULL_SPECIALIZATION:INTERNAL=1 //Advanced flag for variable: VTK_DATA_ROOT VTK_DATA_ROOT-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_DEBUG_LEAKS VTK_DEBUG_LEAKS-ADVANCED:INTERNAL=1 //The directory in which code for Shaders is provided. VTK_DEFAULT_SHADERS_DIR:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK/Utilities/MaterialLibrary/Repository VTK_DIR:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/VTK //String encoder. VTK_ENCODESTRING_EXE:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/bin/vtkEncodeString //Support for C++ explict templates VTK_EXPLICIT_TEMPLATES:INTERNAL=1 //Advanced flag for variable: VTK_GLEXT_FILE VTK_GLEXT_FILE-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_GLXEXT_FILE VTK_GLXEXT_FILE-ADVANCED:INTERNAL=1 //Have include iosfwd VTK_HAVE_ANSI_STREAMS:INTERNAL=1 //Support for getsockname with socklen_t VTK_HAVE_GETSOCKNAME_WITH_SOCKLEN_T:INTERNAL=1 //Have library socket VTK_HAVE_LIBSOCKET:INTERNAL= //Have include iostream.h VTK_HAVE_OLD_STREAMS:INTERNAL=1 //Have include strstream.h VTK_HAVE_OLD_STRSTREAM_H:INTERNAL= //Have include strstrea.h VTK_HAVE_OLD_STRSTREA_H:INTERNAL= //Have symbol SO_REUSEADDR VTK_HAVE_SO_REUSEADDR:INTERNAL=1 //Advanced flag for variable: VTK_INSTALL_QT_PLUGIN_DIR VTK_INSTALL_QT_PLUGIN_DIR-ADVANCED:INTERNAL=1 //Whether istream supports long long VTK_ISTREAM_SUPPORTS_LONG_LONG:INTERNAL=1 //Advanced flag for variable: VTK_LEGACY_REMOVE VTK_LEGACY_REMOVE-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_LEGACY_SILENT VTK_LEGACY_SILENT-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_MATERIALS_DIRS VTK_MATERIALS_DIRS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_MPIRUN_EXE VTK_MPIRUN_EXE-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_MPI_MAX_NUMPROCS VTK_MPI_MAX_NUMPROCS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_MPI_NUMPROC_FLAG VTK_MPI_NUMPROC_FLAG-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_MPI_POSTFLAGS VTK_MPI_POSTFLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_MPI_PREFLAGS VTK_MPI_PREFLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_MPI_PRENUMPROC_FLAGS VTK_MPI_PRENUMPROC_FLAGS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_NO_PYTHON_THREADS VTK_NO_PYTHON_THREADS-ADVANCED:INTERNAL=1 //Disable multithreading support in the Python bindings VTK_NO_PYTHON_THREADS:INTERNAL=1 //Advanced flag for variable: VTK_OPENGL_HAS_OSMESA VTK_OPENGL_HAS_OSMESA-ADVANCED:INTERNAL=1 //Whether ostream supports long long VTK_OSTREAM_SUPPORTS_LONG_LONG:INTERNAL=1 //OpenGL extensions parser. VTK_PARSEOGLEXT_EXE:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/bin/vtkParseOGLExt //Result of CHECK_TYPE_SIZE VTK_SIZEOF_LONG_LONG:INTERNAL=8 //Result of CHECK_TYPE_SIZE VTK_SIZEOF___INT64:INTERNAL= VTK_TCL_TK_STATIC:INTERNAL=ON //Advanced flag for variable: VTK_TESTING_USE_FPE VTK_TESTING_USE_FPE-ADVANCED:INTERNAL=1 //Whether char is signed. VTK_TYPE_CHAR_IS_SIGNED:INTERNAL=1 //Result of TRY_COMPILE VTK_TYPE_CHAR_IS_SIGNED_COMPILED:INTERNAL=TRUE //Advanced flag for variable: VTK_USE_64BIT_IDS VTK_USE_64BIT_IDS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_BOOST VTK_USE_BOOST-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_CARBON VTK_USE_CARBON-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_CG_SHADERS VTK_USE_CG_SHADERS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_COCOA VTK_USE_COCOA-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_DISPLAY VTK_USE_DISPLAY-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_FFMPEG_ENCODER VTK_USE_FFMPEG_ENCODER-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_GEOVIS VTK_USE_GEOVIS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_GLSL_SHADERS VTK_USE_GLSL_SHADERS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_GUISUPPORT VTK_USE_GUISUPPORT-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_INFOVIS VTK_USE_INFOVIS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_MANGLED_MESA VTK_USE_MANGLED_MESA-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_MATROX_IMAGING VTK_USE_MATROX_IMAGING-ADVANCED:INTERNAL=1 //Use Matrox Imaging Library for video input. VTK_USE_MATROX_IMAGING:INTERNAL=OFF //Advanced flag for variable: VTK_USE_METAIO VTK_USE_METAIO-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_MPEG2_ENCODER VTK_USE_MPEG2_ENCODER-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_MPI VTK_USE_MPI-ADVANCED:INTERNAL=0 //Build VTK with MPI support VTK_USE_MPI:INTERNAL=ON //Advanced flag for variable: VTK_USE_MYSQL VTK_USE_MYSQL-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_N_WAY_ARRAYS VTK_USE_N_WAY_ARRAYS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_ODBC VTK_USE_ODBC-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_POSTGRES VTK_USE_POSTGRES-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_QVTK VTK_USE_QVTK-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_QVTK_QTOPENGL VTK_USE_QVTK_QTOPENGL-ADVANCED:INTERNAL=1 //Build the vtkRendering kit. Needed for displaying data or using // widgets. VTK_USE_RENDERING:INTERNAL=ON //Advanced flag for variable: VTK_USE_RPATH VTK_USE_RPATH-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_EXPAT VTK_USE_SYSTEM_EXPAT-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_FREETYPE VTK_USE_SYSTEM_FREETYPE-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_JPEG VTK_USE_SYSTEM_JPEG-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_LIBXML2 VTK_USE_SYSTEM_LIBXML2-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_PNG VTK_USE_SYSTEM_PNG-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_TIFF VTK_USE_SYSTEM_TIFF-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_SYSTEM_ZLIB VTK_USE_SYSTEM_ZLIB-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_TK VTK_USE_TK-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_VIEWS VTK_USE_VIEWS-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_USE_VOLUMEPRO_1000 VTK_USE_VOLUMEPRO_1000-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_WGLEXT_FILE VTK_WGLEXT_FILE-ADVANCED:INTERNAL=1 //Advanced flag for variable: VTK_WRAP_HINTS VTK_WRAP_HINTS-ADVANCED:INTERNAL=1 //Wrap VTK classes into the Java language. VTK_WRAP_JAVA:INTERNAL=OFF //Wrap VTK classes into the Python language. VTK_WRAP_PYTHON:INTERNAL=ON //Location of program to do Python wrapping VTK_WRAP_PYTHON_EXE:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/bin/vtkWrapPython //Location of program to do Python wrapping VTK_WRAP_PYTHON_INIT_EXE:INTERNAL=/Users/cekees/src/pyadhGraphical/externalPackages/ParaView3-cvs-bin/bin/vtkWrapPythonInit //Wrap VTK classes into the TCL language. VTK_WRAP_TCL:INTERNAL=OFF //Advanced flag for variable: WGET_EXECUTABLE WGET_EXECUTABLE-ADVANCED:INTERNAL=1 //Advanced flag for variable: XDMF_HAS_NDGM XDMF_HAS_NDGM-ADVANCED:INTERNAL=1 //Whether streams support 64-bit types XDMF_HAVE_64BIT_STREAMS:INTERNAL=1 //Advanced flag for variable: XDMF_HAVE_FCNTL XDMF_HAVE_FCNTL-ADVANCED:INTERNAL=1 //Have include malloc.h XDMF_HAVE_MALLOC_H:INTERNAL= //Advanced flag for variable: XDMF_HAVE_MMAN XDMF_HAVE_MMAN-ADVANCED:INTERNAL=1 //Advanced flag for variable: XDMF_HAVE_NETINET XDMF_HAVE_NETINET-ADVANCED:INTERNAL=1 //Advanced flag for variable: XDMF_REGENERATE_WRAPPERS XDMF_REGENERATE_WRAPPERS-ADVANCED:INTERNAL=1 //Regenerate XdmfPython.cxx XDMF_REGENERATE_WRAPPERS:INTERNAL=OFF //Advanced flag for variable: XDMF_REGENERATE_YACCLEX XDMF_REGENERATE_YACCLEX-ADVANCED:INTERNAL=1 //Regenerate XdmfExprYacc.cxx and XdmfExprLex.cxx XDMF_REGENERATE_YACCLEX:INTERNAL=OFF //Advanced flag for variable: XDMF_USE_MYSQL XDMF_USE_MYSQL-ADVANCED:INTERNAL=1 //Build a Python wrapping interface XDMF_WRAP_PYTHON:INTERNAL=OFF XDMF_WRAP_TCL:INTERNAL=OFF | ||||||||
(0014096) cekees (reporter) 2008-11-12 16:17 |
The crash is due to a mismatch in the HDF5 header files and the HDF5 libraries used in linking. I reconfigured to use the system HDF5 libraries ParaView runs fine. |
(0015061) Utkarsh Ayachit (administrator) 2009-02-17 14:43 |
Seems to have been fixed in CVS. |
(0015105) Alan Scott (manager) 2009-02-17 20:42 |
Tested client/server numerous processes. |
2008-11-05 17:21 | cekees | New Issue | |
2008-11-05 17:21 | cekees | File Added: CMakeCache.txt | |
2008-11-12 16:17 | cekees | Note Added: 0014096 | |
2009-02-17 14:43 | Utkarsh Ayachit | Note Added: 0015061 | |
2009-02-17 14:43 | Utkarsh Ayachit | Status | backlog => @80@ |
2009-02-17 14:43 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2009-02-17 14:43 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-02-17 20:42 | Alan Scott | Note Added: 0015105 | |
2009-02-17 20:42 | Alan Scott | Status | @80@ => closed |
