0008053 | ParaView | (No Category) | public | 2008-11-06 20:39 | 2009-05-13 13:45 | ||||
Summary | 0008053: Glyph cone does not set scale factor correctly | ||||||||
Description | Using glyph, we finally have arrow scale factors set to something that is sane. But, Cone is not. This makes XP look crazy, and locks up Linux. ParaView 3.4.0, Linux, local client. open can.exo. glyph filter/ vectors == ACCL/ Glyph type == Cone. Apply. Do the same thing, but set Scale Factor to 0.0000001 before hitting Apply. This is really obnoxious behavior, and really should be fixed for the next release. | ||||||||
Attached Files | glyphScaleProblem.png [^] (483,022 bytes) 2009-04-27 21:31 | ||||||||
(0016145) Utkarsh Ayachit (administrator) 2009-04-22 15:18 |
Improved scale factor estimation code. Added domain updates to ensure that the array ranges for the current array selection are used. /cvsroot/ParaView3/ParaView3/Qt/Components/pqGlyphPanel.cxx,v <-- Qt/Components/pqGlyphPanel.cxx new revision: 1.8; previous revision: 1.7 |
(0016207) Alan Scott (manager) 2009-04-27 21:31 |
Nope. Try stepping to time step 1. I am enclosing a picture of what it looks like (from Arrow, which is even better). This hangs machines that are not blazingly fast. The main problem is that time step 0 doesn't have an acceleration, time step 1 does. They are a dozen orders of magnitude different in size between time step 0 and 1. |
(0016211) Utkarsh Ayachit (administrator) 2009-04-28 08:53 |
Added a new bug for temporal range issue (Bug 0008938). That being fairly complex, it was decided to handle after 3.6 (either as 3.6.1 or 3.8) |
(0016216) Alan Scott (manager) 2009-04-28 12:47 |
Sounds good to me (Utkarsh's reply) Tested client/ remote server. |
2008-11-06 20:39 | Alan Scott | New Issue | |
2009-02-17 14:54 | Utkarsh Ayachit | Status | backlog => tabled |
2009-02-17 14:54 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-02-17 14:54 | Utkarsh Ayachit | Category | 3.4 => 3.6 |
2009-04-22 15:18 | Utkarsh Ayachit | Note Added: 0016145 | |
2009-04-22 15:18 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-04-22 15:18 | Utkarsh Ayachit | Resolution | open => fixed |
2009-04-27 21:31 | Alan Scott | Note Added: 0016207 | |
2009-04-27 21:31 | Alan Scott | Status | @80@ => @20@ |
2009-04-27 21:31 | Alan Scott | Resolution | fixed => reopened |
2009-04-27 21:31 | Alan Scott | File Added: glyphScaleProblem.png | |
2009-04-28 08:53 | Utkarsh Ayachit | Note Added: 0016211 | |
2009-04-28 08:53 | Utkarsh Ayachit | Status | @20@ => @80@ |
2009-04-28 08:53 | Utkarsh Ayachit | Resolution | reopened => fixed |
2009-04-28 12:47 | Alan Scott | Note Added: 0016216 | |
2009-04-28 12:47 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:45 | Utkarsh Ayachit | Target Version | => 3.6 |
