0008064 | ParaView | (No Category) | public | 2008-11-08 13:19 | 2009-05-13 21:33 | ||||
Reporter | Jan Ploski | ||||||||
Assigned To | Burlen | ||||||||
Priority | low | Severity | crash | Reproducibility | always | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Target Version | 3.6 | Fixed in Version | 3.6 | ||||||
Summary | 0008064: pvserver crashes when volume rendering is enabled (gcc, x86_64, OpenMPI) | ||||||||
Description | I can reliably crash pvserver by opening the headsq.vti or disk_out_ref.ex2 2008 tutorial examples and changing the display mode to "Volume" (I haven't tried other examples, but I suppose it would also crash). After the server crash the client sometimes also quits (after I discard the displayed error message). The example works ok when the built-in server is used. | ||||||||
Additional Information | The server was compiled from 3.4.0 source using "gcc (GCC) 4.1.2 20070115 (prerelease) (SUSE Linux)". This is an Opteron SLES10 SP1 Linux system, OpenMPI 1.2.6, with libOSMesa. The used client is the binary version downloaded from ParaView's web site. Command used to run the server: mpirun -np 4 /opt/ParaView-3.4.0-Install/bin/pvserver -rc --client-host=<removed> --server-port=21234 --use-offscreen-rendering Stdout/stderr: Process id: 0 >> ERROR: In /usr/src/ParaView-3.4.0/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 1478 Process id: 1 >> ERROR: In /usr/src/ParaView-3.4.0/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 1478 Process id: 2 >> ERROR: In /usr/src/ParaView-3.4.0/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 1478 Process id: 3 >> ERROR: In /usr/src/ParaView-3.4.0/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 1478 [node11:21063] *** Process received signal *** [node11:21063] Signal: Segmentation fault (11) [node11:21063] Signal code: Address not mapped (1) [node11:21063] Failing at address: 0x21 [node11:21064] *** Process received signal *** [node11:21064] Signal: Segmentation fault (11) [node11:21064] Signal code: Address not mapped (1) [node11:21064] Failing at address: 0x21 [node11:21065] *** Process received signal *** [node11:21065] Signal: Segmentation fault (11) [node11:21065] Signal code: Address not mapped (1) [node11:21065] Failing at address: 0x21 [node11:21066] *** Process received signal *** [node11:21066] Signal: Segmentation fault (11) [node11:21066] Signal code: Address not mapped (1) [node11:21066] Failing at address: 0x21 mpirun noticed that job rank 0 with PID 21063 on node node11 exited on signal 11 (Segmentation fault). Output of ldd /opt/ParaView-3.4.0-Install/bin/pvserver libGLU.so.1 => /usr/lib64/libGLU.so.1 (0x00002b272c323000) libmpi_cxx.so.0 => /opt/openmpi-gcc/lib/libmpi_cxx.so.0 (0x00002b272c4a2000) libmpi.so.0 => /opt/openmpi-gcc/lib/libmpi.so.0 (0x00002b272c5c4000) libopen-rte.so.0 => /opt/openmpi-gcc/lib/libopen-rte.so.0 (0x00002b272c758000) libopen-pal.so.0 => /opt/openmpi-gcc/lib/libopen-pal.so.0 (0x00002b272c8b3000) libdl.so.2 => /lib64/libdl.so.2 (0x00002b272ca11000) libnsl.so.1 => /lib64/libnsl.so.1 (0x00002b272cb16000) libutil.so.1 => /lib64/libutil.so.1 (0x00002b272cc2c000) libm.so.6 => /lib64/libm.so.6 (0x00002b272cd2f000) libhistory.so.5 => /lib64/libhistory.so.5 (0x00002b272ce85000) libreadline.so.5 => /lib64/libreadline.so.5 (0x00002b272cf8d000) libOSMesa.so.6 => /usr/lib64/libOSMesa.so.6 (0x00002b272d0ca000) libpthread.so.0 => /lib64/libpthread.so.0 (0x00002b272d446000) libGL.so.1 => /usr/lib64/libGL.so.1 (0x00002b272d55d000) libXt.so.6 => /usr/X11R6/lib64/libXt.so.6 (0x00002b272d6db000) libSM.so.6 => /usr/X11R6/lib64/libSM.so.6 (0x00002b272d83d000) libICE.so.6 => /usr/X11R6/lib64/libICE.so.6 (0x00002b272d947000) libX11.so.6 => /usr/X11R6/lib64/libX11.so.6 (0x00002b272da62000) libXext.so.6 => /usr/X11R6/lib64/libXext.so.6 (0x00002b272dc71000) libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00002b272dd82000) libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00002b272df80000) libc.so.6 => /lib64/libc.so.6 (0x00002b272e08e000) /lib64/ld-linux-x86-64.so.2 (0x00002b272c207000) libncurses.so.5 => /lib64/libncurses.so.5 (0x00002b272e2bf000) libXxf86vm.so.1 => /usr/X11R6/lib64/libXxf86vm.so.1 (0x00002b272e423000) libdrm.so.2 => /usr/lib64/libdrm.so.2 (0x00002b272e528000) | ||||||||
(0016420) Alan Scott (manager) 2009-05-13 21:33 |
Volume rendering seems fairly stable with current Trunk. This bug has been fixed. |
2008-11-08 13:19 | Jan Ploski | New Issue | |
2009-02-17 14:55 | Utkarsh Ayachit | Assigned To | => Burlen |
2009-02-17 14:55 | Utkarsh Ayachit | Priority | normal => low |
2009-02-17 14:55 | Utkarsh Ayachit | Status | backlog => tabled |
2009-02-17 14:55 | Utkarsh Ayachit | Category | 3.4 => 3.6 |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-05-13 15:56 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-05-13 15:56 | Utkarsh Ayachit | Fixed in Version | => 3.6 |
2009-05-13 15:56 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2009-05-13 21:33 | Alan Scott | Note Added: 0016420 | |
2009-05-13 21:33 | Alan Scott | Status | @80@ => closed |
