0008076 | ParaView | (No Category) | public | 2008-11-10 18:26 | 2016-08-12 09:57 | ||||
Summary | 0008076: Coloring with Partial Arrays | ||||||||
Description | When coloring a composite dataset with partial arrays, currently color is assigned to blocks without the selected array by making up a value (0). Instead, in such cases, no scalar coloring should be applied to the block (revert to solid coloring). | ||||||||
(0023448) Utkarsh Ayachit (administrator) 2010-11-19 14:02 |
This is fixed now. |
(0023569) Utkarsh Ayachit (administrator) 2010-11-29 10:05 |
Try this pipeline: Cone->Elevation | |-> Group DataSets -> Color By Elevation Sphere | You'll see that the Sphere shows up with some color. this is happening since vtkOpenGLScalarsToColorsPainter changes the OpenGL state and does not restore all variables back to previous values resulting in bleeding of some state attributes affecting the color. This can be misleading and should be fixed. |
(0024921) Utkarsh Ayachit (administrator) 2011-01-19 11:39 |
This almost works now, except that the last used color bleeds into the block where the array is missing. |
(0033628) Cory Quammen (developer) 2014-10-10 10:53 |
The last color still bleeds into the block where the array is missing. |
(0037603) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-11-10 18:26 | Utkarsh Ayachit | New Issue | |
2008-11-10 18:26 | Utkarsh Ayachit | Status | backlog => tabled |
2008-11-10 18:26 | Utkarsh Ayachit | Assigned To | => Zhanping Liu |
2009-02-17 15:00 | Utkarsh Ayachit | Category | 3.6 => 3.8 |
2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-11-19 14:02 | Utkarsh Ayachit | Note Added: 0023448 | |
2010-11-19 14:02 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-11-19 14:02 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
2010-11-19 14:02 | Utkarsh Ayachit | Resolution | open => fixed |
2010-11-29 10:05 | Utkarsh Ayachit | Note Added: 0023569 | |
2010-11-29 10:05 | Utkarsh Ayachit | Assigned To | Zhanping Liu => Robert Maynard |
2010-11-29 10:05 | Utkarsh Ayachit | Status | @80@ => backlog |
2010-11-29 10:06 | Utkarsh Ayachit | Status | backlog => tabled |
2010-11-29 10:06 | Utkarsh Ayachit | Fixed in Version | 3.10 => 3.10.shortlist |
2010-11-29 10:06 | Utkarsh Ayachit | Fixed in Version | 3.10.shortlist => |
2010-11-29 10:06 | Utkarsh Ayachit | Target Version | 3.8 => 3.10.shortlist |
2010-11-30 16:33 | Utkarsh Ayachit | Priority | normal => high |
2010-12-01 16:52 | Robert Maynard | Assigned To | Robert Maynard => Utkarsh Ayachit |
2011-01-19 11:39 | Utkarsh Ayachit | Note Added: 0024921 | |
2014-10-10 10:53 | Cory Quammen | Note Added: 0033628 | |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | => 4.3 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037603 | |
2016-08-12 09:57 | Kitware Robot | Status | backlog => closed |
2016-08-12 09:57 | Kitware Robot | Fixed in Version | 4.3 => |
2016-08-12 09:57 | Kitware Robot | Resolution | fixed => moved |
