0008464 | ParaView | (No Category) | public | 2009-02-04 05:18 | 2011-09-01 13:31 | ||||
Reporter | Stephane P | ||||||||
Target Version | 3.8 | Fixed in Version | 3.12 | ||||||
Summary | 0008464: tile-display : tile size not correctly set | ||||||||
Description | paraview is started in tiled display mode (mpirun -np 16 pvserver -tdx=4 -tdy=4 -tmx=-360 -tmy=-246) each tile size is 1920*1080 when the client connects to the server, the background seems ok, but at the first display of an object, the tile size is reset to approximately the half of what it should be. | ||||||||
Project | ParaViS | ||||||||
(0018099) Paul Melis (reporter) 2009-10-19 08:45 |
The resize of the tile displays doesn't happen for all kinds of scenes, e.g. adding a Mandelbrot source directly after startup of the PV GUI does not cause a resize. This might be due to the 2D rendering used in that case? Removing the Mandelbrot source and adding a Cone source leads to the GUI suddenly getting two views separated by a splitter. Some really weird stuff going on there... I'm interested in getting this fixed on the short term, but I have no idea how much work that would be or where to look in the PV sources. Any hints are appreciated... |
(0018322) Utkarsh Ayachit (administrator) 2009-11-02 16:37 |
This has been fixed in CVS. |
(0018678) Alan Scott (manager) 2009-12-02 20:23 |
Assuming fixed, since I don't have access to a tile display. Please reopen if this is not fixed on the trunk. |
2009-02-04 05:18 | Stephane P | New Issue | |
2009-02-17 16:46 | Utkarsh Ayachit | Category | Development => 3.8 |
2009-05-13 13:40 | Utkarsh Ayachit | Target Version | => 3.8 |
2009-10-19 08:45 | Paul Melis | Note Added: 0018099 | |
2009-11-02 16:37 | Utkarsh Ayachit | Note Added: 0018322 | |
2009-11-02 16:37 | Utkarsh Ayachit | Status | backlog => @80@ |
2009-11-02 16:37 | Utkarsh Ayachit | Fixed in Version | => Development |
2009-11-02 16:37 | Utkarsh Ayachit | Resolution | open => fixed |
2009-11-02 16:37 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-12-02 20:23 | Alan Scott | Note Added: 0018678 | |
2009-12-02 20:23 | Alan Scott | Status | @80@ => closed |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
2011-09-01 13:31 | Utkarsh Ayachit | Fixed in Version | Development => 3.12 |
