0008608 | ParaView | Bug | public | 2009-02-24 20:26 | 2012-02-17 23:47 | ||||
Assigned To | Robert Maynard | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0008608: (Venus - Low) Chart Layout "New Label" is confusing | ||||||||
Description | ParaView trunk, XP, local server. Open disk_out_ref.exo filters/data analysis/ plot over line. Chart Options/ bottom Axis/ Layout/ Specify Each of the Axis Labels. New Label. You get no indication that there is an edit window here - no cursur, no colored box, no initial number, nothing. | ||||||||
Project | Sandia | ||||||||
(0015356) Alan Scott (manager) 2009-02-24 20:31 |
Additionally, now type something - such as 0.00. Hit the Apply button. Now, try to edit this number to 0.01. If you put the cursor in the box, it won't work, if you hit the enter key, the window goes away, if you double click, it sometimes will edit, sometimes not. |
(0025816) Utkarsh Ayachit (administrator) 2011-03-18 14:00 |
There are some usabiliy issues with this dialog. |
(0028299) Alan Scott (manager) 2012-02-17 23:47 |
I am going to close this one. It works pretty well. We now have a blinking cursor, letting a user that there is input here. If the user doesn't put anything in the window, it basically ignores it. Tested Windows, local server, master. |
2009-02-24 20:26 | Alan Scott | New Issue | |
2009-02-24 20:31 | Alan Scott | Note Added: 0015356 | |
2009-02-26 17:44 | Alan Scott | Summary | Chart Layout "New Label" is confusing => (Venus - Low) Chart Layout "New Label" is confusing |
2009-03-02 20:24 | Alan Scott | Priority | normal => low |
2009-03-02 20:26 | Alan Scott | Category | 3.8 => 3.6 |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-08-25 12:01 | Ken Moreland | Category | => Bug |
2009-08-25 12:01 | Ken Moreland | Target Version | 3.6 => 3.8 |
2011-03-18 14:00 | Utkarsh Ayachit | Note Added: 0025816 | |
2011-03-18 14:00 | Utkarsh Ayachit | Assigned To | => Robert Maynard |
2011-03-18 14:00 | Utkarsh Ayachit | Status | backlog => tabled |
2011-03-18 14:00 | Utkarsh Ayachit | Target Version | 3.8 => 4.0 |
2011-09-01 10:56 | Utkarsh Ayachit | Project | => Sandia |
2012-02-17 23:47 | Alan Scott | Note Added: 0028299 | |
2012-02-17 23:47 | Alan Scott | Status | backlog => closed |
2012-02-17 23:47 | Alan Scott | Resolution | open => fixed |
