0008622 | ParaView | (No Category) | public | 2009-02-25 21:33 | 2009-05-14 21:42 | ||||
Summary | 0008622: (Venus - high) Line plot has missing segments | ||||||||
Description | I have a dataset that has missing segments when doing a line plot. I cannot figure out why, or what is missing in the file. ParaView local server, XP. File: simple-sheath.e.2.* (I will send this to Berk.) Filters/ Data Analysis/ Line Plot. Z Axis. Apply. Note that the line plot has missing data around 48 to 50. Is this in ParaView or the data? | ||||||||
Attached Files | vtkPointSet.cxx.patch [^] (1,599 bytes) 2009-03-11 19:01 [Show Content] | ||||||||
(0015663) Ken Moreland (manager) 2009-03-11 19:06 |
The problem is that the connectivity of the topology is wrong in the middle of the data set and that messed up how vtkPointSet::FindCell traced through cell neighbors to find containing cells. To see the messed up topology, run the data through the Extract Surface filter and then clip the data with the default plane. If you look carefully in the middle of the data set, you will see some "external" faces on the interior. If you run the data through Clean to Grid, the coincident points will be resolved, the topology will be corrected, and the plot over line will work as expected. I have attached a patch to vtkPointSet.cxx so that it will correctly find the cell even when the data has these type of coincident points. It adds some overhead, but it is pretty minor. |
(0016401) Ken Moreland (manager) 2009-05-12 12:23 |
Commit to directory "ParaView3/VTK/Filtering" lies in external project VTK /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkPointSet.cxx,v <-- vtkPointSet.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkPointSet.h,v <-- vtkPointSet.h new revision: 1.6; previous revision: 1.5 |
(0016466) Alan Scott (manager) 2009-05-14 21:42 |
Great! Tested local client. |
2009-02-25 21:33 | Alan Scott | New Issue | |
2009-03-05 20:19 | Alan Scott | Priority | normal => high |
2009-03-05 20:19 | Alan Scott | Summary | Line plot has missing segments => (Venus - high) Line plot has missing segments |
2009-03-11 19:00 | Ken Moreland | Status | backlog => tabled |
2009-03-11 19:00 | Ken Moreland | Assigned To | => Ken Moreland |
2009-03-11 19:01 | Ken Moreland | File Added: vtkPointSet.cxx.patch | |
2009-03-11 19:06 | Ken Moreland | Note Added: 0015663 | |
2009-05-12 12:23 | Ken Moreland | Note Added: 0016401 | |
2009-05-12 12:23 | Ken Moreland | Status | tabled => @80@ |
2009-05-12 12:23 | Ken Moreland | Resolution | open => fixed |
2009-05-13 13:44 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-05-14 21:42 | Alan Scott | Note Added: 0016466 | |
2009-05-14 21:42 | Alan Scott | Status | @80@ => closed |
