0008626 | ParaView | (No Category) | public | 2009-02-26 12:43 | 2009-05-13 13:46 | ||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0008626: (Venus - Low ) Calculator tabs are nuts | ||||||||
Description | Calculator tabbing is nuts. Specifically, edit the Result field. Hit tab There is no logic to the tab order. A user noticed, and complained, about this. | ||||||||
(0015616) Ken Moreland (manager) 2009-03-10 12:12 |
When you said nuts, I was expecting some crazy tabbing through all of the buttons. The only problem I found was that the focus for the tanh button was not properly skipped. Fixed that. /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqCalculatorPanel.ui,v <-- pqCalculatorPanel.ui |
(0015705) Alan Scott (manager) 2009-03-16 16:53 |
It seemed to be nuts when I wrote up the bug... Looks good now. Tested local server. |
2009-02-26 12:44 | Alan Scott | New Issue | |
2009-02-26 12:45 | Alan Scott | Summary | Calculat tabs are nuts => Calculator tabs are nuts |
2009-02-26 14:53 | Ken Moreland | Status | backlog => tabled |
2009-02-26 14:53 | Ken Moreland | Assigned To | => Ken Moreland |
2009-02-26 18:15 | Alan Scott | Summary | Calculator tabs are nuts => (Venus - Low ) Calculator tabs are nuts |
2009-03-02 20:21 | Alan Scott | Priority | normal => low |
2009-03-10 12:12 | Ken Moreland | Note Added: 0015616 | |
2009-03-10 12:12 | Ken Moreland | Status | tabled => @80@ |
2009-03-10 12:12 | Ken Moreland | Resolution | open => fixed |
2009-03-16 16:53 | Alan Scott | Note Added: 0015705 | |
2009-03-16 16:53 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
