0008653 | ParaView | (No Category) | public | 2009-03-02 13:38 | 2009-05-13 13:46 | ||||
Summary | 0008653: (Venus) Confusing message for log 0 data with scalar bar | ||||||||
Description | ParaView trunk, Local server, XP Open disk_out_ref.exo (We need to make data with a 0 in it) calculator. Result Array Name: badData Formula: PedigreeNodeId-1 Apply. Color Legend on Edit Color Map Use Logarithmic Scale Close Rescale to Data Range. Note that the message is incorrect and not clear. This should be fixed. | ||||||||
(0015523) Alan Scott (manager) 2009-03-03 15:58 |
The request from the customer is that we allow the user to select what "invalid data" should be replaced with. Note that the scalar bar basically goes nuts. |
(0015671) Ken Moreland (manager) 2009-03-12 15:23 |
Consolidated the log range checking to pqScalarsToColors, which watches for any changes to either the UseLogScale or RGBPoints properties on the scalars to colors proxy. /cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleEditor.cxx,v <-- Components/pqColorScaleEditor.cxx new revision: 1.53; previous revision: 1.52 confused about file pqColorScaleEditor.h -- ignoring /cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarsToColors.cxx,v <-- Core/pqScalarsToColors.cxx new revision: 1.19; previous revision: 1.18 /cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarsToColors.h,v <-- Core/pqScalarsToColors.h new revision: 1.16; previous revision: 1.15 |
(0015686) Alan Scott (manager) 2009-03-13 17:41 |
Nice job. Tested local server. |
2009-03-02 13:38 | Alan Scott | New Issue | |
2009-03-02 22:05 | Alan Scott | Summary | Confusing message for log 0 data with scalar bar => (Venus) Confusing message for log 0 data with scalar bar |
2009-03-03 15:58 | Alan Scott | Note Added: 0015523 | |
2009-03-11 19:35 | Ken Moreland | Status | backlog => tabled |
2009-03-11 19:35 | Ken Moreland | Assigned To | => Ken Moreland |
2009-03-12 15:23 | Ken Moreland | Note Added: 0015671 | |
2009-03-12 15:23 | Ken Moreland | Status | tabled => @80@ |
2009-03-12 15:23 | Ken Moreland | Resolution | open => fixed |
2009-03-13 17:41 | Alan Scott | Note Added: 0015686 | |
2009-03-13 17:41 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
