0008693 | ParaView | (No Category) | public | 2009-03-06 12:57 | 2009-05-13 13:46 | ||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0008693: (Venus - Low) Bad characters are allowed in naming variables in the calculator | ||||||||
Description | ParaView allows unacceptable characters as input into the calculator. Trunk ParaView, local server, XP. Open disk_out_ref.exo Calculator. Name the Result Array Name the following (the vertical bars are part of the variable name): |Ex-1| Formula: Temp. Apply. Try coloring by the variable |Ex-1|. Bad things happen. This bug is reported to damage ParaView's .ini file. ParaView should check for, and not allow, characters that are bad inputs. | ||||||||
(0015669) Ken Moreland (manager) 2009-03-12 10:46 |
The widget responsible for choosing the variable to color by was using | as a delimiter in a list of values. Changed to storage to a QStringList so no delimiters are necessary. You should now be able to name variables to whatever you want. /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayColorWidget.cxx,v <-- pqDisplayColorWidget.cxx new revision: 1.38; previous revision: 1.37 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayColorWidget.h,v <-- pqDisplayColorWidget.h new revision: 1.16; previous revision: 1.15 |
(0015687) Alan Scott (manager) 2009-03-13 17:53 |
Great! Tested client/ remote server. |
2009-03-06 12:57 | Alan Scott | New Issue | |
2009-03-11 17:25 | Ken Moreland | Status | backlog => tabled |
2009-03-11 17:25 | Ken Moreland | Assigned To | => Ken Moreland |
2009-03-12 10:46 | Ken Moreland | Note Added: 0015669 | |
2009-03-12 10:46 | Ken Moreland | Status | tabled => @80@ |
2009-03-12 10:46 | Ken Moreland | Resolution | open => fixed |
2009-03-13 17:53 | Alan Scott | Note Added: 0015687 | |
2009-03-13 17:53 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
