0008894 | ParaView | Bug | public | 2009-04-16 14:40 | 2016-08-12 09:57 | ||||
Priority | normal | Severity | feature | Reproducibility | have not tried | ||||
Summary | 0008894: See flat 2D projection of slice | ||||||||
Description | A user requested the ability to drag a slice through a volume and to be able to see the result of the slice in a second 2D window. The views would be "linked" in some way so that the 2D slice window gets updated when the slice is moved in the 3D volume The request makes sense; oblique angles and shading could make the projection harder to see. | ||||||||
(0037640) Kitware Robot (administrator) 2016-08-12 09:57 |
2009-04-16 14:40 | Ken Moreland | New Issue | |
2010-11-05 14:04 | Utkarsh Ayachit | Severity | minor => feature |
2010-11-05 14:04 | Utkarsh Ayachit | Category | => Bug |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037640 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
