0008924 | ParaView | (No Category) | public | 2009-04-22 19:57 | 2009-05-13 13:47 | ||||
Summary | 0008924: (Venus) Plot over line X axis | ||||||||
Description | Plot over line X axis should be using distance down the line in physical space - not as a percent down the line. Should we make this user selectable/configurable, or just default to distance? | ||||||||
(0016235) Alan Scott (manager) 2009-04-28 21:00 |
OK, I just learned a bit more. This is an option, found under the Display tab. You can say "Use Data Array", then Points (Magnitude). I would like to propose that this be the default. The other option would be to make this selection "sticky", such that a user has to set it once. Since I suspect this is easy, lets try to get it into 3.6? |
(0016254) Ken Moreland (manager) 2009-04-29 15:49 |
I concur that this should be the default. I thought at one point that it was. |
(0016274) Utkarsh Ayachit (administrator) 2009-05-01 11:17 |
Charting views now use better defaults. Adding new filter to add arc-length to plot-over-line filter. /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqBarChartDisplayPanel.ui,v <-- Qt/Components/Resources/UI/pqBarChartDisplayPanel.ui new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqLineChartDisplayPanel.ui,v <-- Qt/Components/Resources/UI/pqLineChartDisplayPanel.ui new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqBarChartDisplayPanel.cxx,v <-- Qt/Components/pqBarChartDisplayPanel.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqBarChartDisplayPanel.h,v <-- Qt/Components/pqBarChartDisplayPanel.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqBarChartDisplayProxyEditor.cxx,v <-- Qt/Components/pqBarChartDisplayProxyEditor.cxx new revision: delete; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Qt/Components/pqBarChartDisplayProxyEditor.h,v <-- Qt/Components/pqBarChartDisplayProxyEditor.h new revision: delete; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/pqLineChartDisplayPanel.cxx,v <-- Qt/Components/pqLineChartDisplayPanel.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/pqLineChartDisplayPanel.h,v <-- Qt/Components/pqLineChartDisplayPanel.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/CMakeLists.txt,v <-- Qt/Core/CMakeLists.txt new revision: 1.105; previous revision: 1.104 /cvsroot/ParaView3/ParaView3/Qt/Core/pqChartRepresentation.cxx,v <-- Qt/Core/pqChartRepresentation.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqChartRepresentation.h,v <-- Qt/Core/pqChartRepresentation.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqStandardViewModules.cxx,v <-- Qt/Core/pqStandardViewModules.cxx new revision: 1.23; previous revision: 1.22 /cvsroot/ParaView3/ParaView3/Servers/Filters/CMakeLists.txt,v <-- Servers/Filters/CMakeLists.txt new revision: 1.192; previous revision: 1.191 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkAppendArcLength.cxx,v <-- Servers/Filters/vtkAppendArcLength.cxx initial revision: 1.1 |
(0016319) Alan Scott (manager) 2009-05-06 16:49 |
Excellent. Tested local client. |
2009-04-22 19:57 | Alan Scott | New Issue | |
2009-04-28 21:00 | Alan Scott | Note Added: 0016235 | |
2009-04-28 21:02 | Alan Scott | Summary | Plot over line X axis => (Venus) Plot over line X axis |
2009-04-29 15:34 | Alan Scott | Priority | normal => high |
2009-04-29 15:34 | Alan Scott | Severity | minor => major |
2009-04-29 15:34 | Alan Scott | Category | 3.8 => 3.6 |
2009-04-29 15:49 | Ken Moreland | Note Added: 0016254 | |
2009-04-29 15:49 | Ken Moreland | Status | backlog => tabled |
2009-04-29 15:49 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
2009-05-01 11:17 | Utkarsh Ayachit | Note Added: 0016274 | |
2009-05-01 11:17 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-05-01 11:17 | Utkarsh Ayachit | Resolution | open => fixed |
2009-05-06 16:49 | Alan Scott | Note Added: 0016319 | |
2009-05-06 16:49 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:44 | Utkarsh Ayachit | Target Version | => 3.6 |
