0008979 | ParaView | (No Category) | public | 2009-05-06 21:48 | 2009-06-09 21:18 | ||||
Summary | 0008979: (Venus - High) With plots, the Use Data Array input doesn't work. | ||||||||
Description | Trunk ParaView, XP, local server. Open disk_out_ref.exo, turn on all variables. Filters/ Data Analysis/ Plot over Line. Apply. Go to the Display tab. Change Use Data Array to CH4 (which has a range of 0 to 0.0011). Notice that the X axis has not changed. Now, select disk_out_ref.exo in the Pipeline Browser. Note that the X axis has changed. This is unacceptable behavior. It needs to be fixed for 3.6. | ||||||||
(0016324) Alan Scott (manager) 2009-05-06 21:51 |
Also, arc_length is slightly unclear. Should it be line_length? Or are we preparing to use a "Plot over Arc" filter in the future? |
(0016331) Ken Moreland (manager) 2009-05-07 09:43 |
This appears to be an update problem. The changing of the array is working fine, but it is not causing a redraw of the plot. Anything you do to redraw the plot (for example, toggling a series to plot) will update the display with the chosen data array. For what it is worth, I think arc_length is a fine name. |
(0016333) Utkarsh Ayachit (administrator) 2009-05-07 10:40 |
There was a missing "render" request when the x-axis array was changed. Fixed that. /cvsroot/ParaView3/ParaView3/Qt/Components/pqLineChartDisplayPanel.cxx,v <-- Qt/Components/pqLineChartDisplayPanel.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqLineChartDisplayPanel.h,v <-- Qt/Components/pqLineChartDisplayPanel.h new revision: 1.3; previous revision: 1.2 |
(0016389) Alan Scott (manager) 2009-05-11 20:32 |
Not sure if this is close to the same bug, but I am reporting it here. Do as listed above, including change Use Data Array to CH4. X axis looks good. Now, change Use Data Array to AsH3. Note that the X axis will have the right most number (0.16) trashed. If it doesn't look bad, toggle to other Use Data Array values, then come back to CH4. I suppose this could slide to 3.6.2 or 3.8, but is really obnoxious behavior. |
(0016412) Ken Moreland (manager) 2009-05-12 20:05 |
There might be a redraw issue on Linux (at least, I saw nothing on my Mac). It looked like a few pixels from the previous number were not erased and stick around in the background of the new number. |
(0016683) Alan Scott (manager) 2009-06-09 21:18 |
I tried this again tonight, and could not replicate it. I really beat it up. Thus, I am closing. If we find something like this again, lets write up a new, unique bug for it. Tested local server, Linux. |
2009-05-06 21:48 | Alan Scott | New Issue | |
2009-05-06 21:51 | Alan Scott | Note Added: 0016324 | |
2009-05-07 07:40 | Utkarsh Ayachit | Status | backlog => tabled |
2009-05-07 07:40 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-05-07 09:43 | Ken Moreland | Note Added: 0016331 | |
2009-05-07 10:40 | Utkarsh Ayachit | Note Added: 0016333 | |
2009-05-07 10:40 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-05-07 10:40 | Utkarsh Ayachit | Resolution | open => fixed |
2009-05-11 20:32 | Alan Scott | Note Added: 0016389 | |
2009-05-11 20:32 | Alan Scott | Status | @80@ => @20@ |
2009-05-11 20:32 | Alan Scott | Resolution | fixed => reopened |
2009-05-12 20:05 | Ken Moreland | Note Added: 0016412 | |
2009-05-13 13:44 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-06-09 21:18 | Alan Scott | Note Added: 0016683 | |
2009-06-09 21:18 | Alan Scott | Status | @20@ => closed |
2009-06-09 21:18 | Alan Scott | Resolution | reopened => fixed |
