0009004 | ParaView | (No Category) | public | 2009-05-11 21:09 | 2009-05-13 13:47 | ||||
Assigned To | Alan Scott | ||||||||
Priority | high | Severity | major | Reproducibility | have not tried | ||||
Summary | 0009004: Selections mess up rendering with plots | ||||||||
Description | ParaView trunk, XP client, 6 pvservers. Load can.exo, all variables, apply. Surface with edges. Select point on the base of the plate. Filters/ Data Analysis/ Plot selection over time. Apply. Click on the 3d window again. <<Bug>> Select Point - select another point. Notice that the blue line, bottom right, will jump. <<Bug>> Select Point - select a different point again. The base of the plate will flash with white areas. I think this should be fixed for 3.6. | ||||||||
(0016403) Alan Scott (manager) 2009-05-12 13:07 |
I cannot replicate with Linux, and Utkarsh and Ken cannot either. Guessing it is a bad build or driver issue. |
(0016404) Alan Scott (manager) 2009-05-12 13:07 |
Closed. |
2009-05-11 21:09 | Alan Scott | New Issue | |
2009-05-12 13:07 | Alan Scott | Note Added: 0016403 | |
2009-05-12 13:07 | Alan Scott | Status | backlog => @80@ |
2009-05-12 13:07 | Alan Scott | Resolution | open => fixed |
2009-05-12 13:07 | Alan Scott | Assigned To | => Alan Scott |
2009-05-12 13:07 | Alan Scott | Note Added: 0016404 | |
2009-05-12 13:07 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:44 | Utkarsh Ayachit | Target Version | => 3.6 |
